Question about Diamond Multimedia ( VC500) Video Capture
Driver won't install.....getting "access denied".
Hi, I am now using the Lenovo S100 netbook. Since I prefre using Windows XP, so I downgraded the OS from Windows 7 Starter to Windows XP in my pc. However, I cannot reinstall the driver for the Wireless...
@siuchiwing
If you installed the wifi driver here or at consumersupport.lenovo.com then you have the right driver. The Access Denied prompt that you're getting though seems strange because most of the time, Access Denied error only comes up if you don't have access to a certain program, file, or directory and I'm assuming you have administrative priviledges. Try the following:
1. Unhide the built-in Administrator account (guide here) and log-in to it and see if you're still getting the same error. If you don't, you have a corrupted profile and you need to create another one.
2. Reboot into Safe Mode with Networking (press F8 upon boot-up) and check if you're still getting the error. If you don't, try to disable startup items (guide here).
If you still do get the error, you might wanna consider doing a re-installation of your Windows XP.
Good luck.
Sep 06, 2011 | Computers & Internet
I DENIED MY PARTION DRIVER BY ACCIDENT AND ACCESS WINDOWS 7
if you are using xp, go to device manager (right click, properties on my computer icon), then click on the scan for hardware changes icon on the top right of the same window. the driver installation prossess will come back again...
or download device doctore portable, and make a quick scan to locate drivers and a valid download mirror.
May 10, 2010 | Computers & Internet
When i try to install a critical update it was denied access by 7 zip. even after uninstalling 7 zip and installing winzip i still get the same response when trying to install updates 7 zip access denied....
Install Winrar, Here is the link
http://www.rarlab.com/rar/wrar391.exe
if you double click the file,the files will be extracted in the temp folder,so after installing winrar,right click on the file and select extract here. and try to install the update now,
Sometime when you extract files and it contains Malware or Trojan,Anti-Virus which support real time scan just block the files and the access denied message is displayed.
Scan the extracted files before installing so that you know it's Virus free.
Sometimes,even if you have administrator right,sometimes due to malware infection, you are denied access to some system hidden giles like folder under Local settings.
Dec 30, 2009 | Compaq Computers & Internet
Bluetooth driver (bluetooth hands-free audio) wont install, access denied
me too have that problem, i updated me XP SP2 to SP3 and failed to install bluetooth, then i removed SP3 and re install bluetooth, it worked fine, as my comment, reinstall ur OS to windows XP SP2 and try.
May 03, 2009 | Computers & Internet
Access denied when installing win xp service pack 3
Are you logged in as an administrator on your PC? Access Denied is almost always an indicator that the current logged in user does not have sufficient permissions to install applications. Let us know if this is not the case. Hope this helps!
Dec 28, 2008 | Microsoft Windows XP Home Edition
HP w1907 monitor driver software will not load
"Access is denied" is the key here. It sounds like your login in windows does not allow you the privileges for that installation. Try logging in as an administrator and re-installing. One thing bothers me though, if this was purchased as a system, why would you need to install drivers? that should have been pre-installed.
Dec 14, 2008 | Computers & Internet
Sound problem
Try to install the driver using different source of driver. Check your soundcard vendor website. Download the appropriate driver. Instal the driver.
Sep 06, 2008 | EliteGroup P4VMM2 Motherboard
Can't install a driver
i've lost my driver cd for my asus wl -167g, can i download it for free?
Apr 03, 2008 | ASUS (WL-167G) 802.11g/b (wl167g) Wireless...
Reltek insatallation failure - getting access denied error msg
hi realtek high Defifnition not work in your driver....you setup your sound driver --cancel then auto setup ....
Jan 31, 2008 | Microsoft Windows XP Professional With...
Access Denied
Just see are you login as Administrator or try to install manually with driver which is digitally signed!
Jan 23, 2008 | Office Equipment & Supplies
Diamond Multimedia ( VC500) Video Capture Logo
41 people viewed this question
Top Diamond Multimedia Televison & Video Experts
venugopal durairajan
David Gust
Lawrence Oravetz
Are you a Diamond Multimedia Televison and Video Expert? Answer questions, earn points and help others
