Question about Ford Tractor Grill 2600 3600 4600 5600 6600 7600
Need a detailed wiring diagram for a Ford 4600 year 1978, Ford Safety Cab
    President:
  • 2,777 Answers
This is going to be difficult to get, I can try to get it for you but your best bet is going to be to call Ford directly and request it. I am going to try to track it down now but in the mean time call Ford at 800-392-3673 and ask if they can locate the manual for you.
Thanks
Tim
Posted on Oct 06, 2010
  • lroyjr
    lroyjr Feb 11, 2013
    him tim did you by chance come across the engine wire diagram for the 4600 ford with cab
  • lroyjr
    lroyjr Feb 11, 2013
    hi*
    Top Expert:
  • Ford Master
  • 76,649 Answers
We have no wiring diagrams here at fixya for this series truck, suggest you try and find one on line used, but suspect the search will be futile.
I am looking for a wireing diagram
At an auto parts store like advanced auto,auto zone, oriellys,you can buy a "Haynes manual" for the year of your vehicle and in the back of it is all the wiring diagrams for everything.
Dec 16, 2014 | 1978 Yamaha XS 400
Ford parts diagrams
lots of engines. at least 5, and all are different. (engine needs)
and not stated.
the FSM (factory serv. man.) cover this in extreme details. bu y one
or login to alldata.com
there are coolant and wiring, related. need both, same answer.
if you need details for 1 part of it we can post it but not the whole
huge cooling system chapter, no way.
Jul 07, 2014 | 1996 Ford F150 Regular Cab
Diagram for distributor cab and wires for datsun 510 1978 wagon
Firing order is 1 3 4 2. Distributor rotor turns counter-clockwise.
Standing in front of car looking at engine, number one cylinder tower is in the 4 o'clock position, number 3 cylinder tower is at the two o'clock position, number 4 cylinder is at 10 o'clock, and number two cylinder tower is at the 8 o'clock position.
Sep 10, 2012 | Cars & Trucks
1971 ford f100 pickup neutral safety switch wiring color code
Ford Neutral Safety Switch; Ford Reverse Light Switch; Backup Light Switch.
The Neutral Safety Switch wires in my 1971 Ford F100 are orange with a blue stripe.
The Reverse, or Backup Light Switch wires are black with a red stripe.
There are two sets of two wires across this combined neutral safety and backup light switch, for a total of 4 wires. Photos are at the end of this post.
The switch for the 1971 Ford F100 pickup truck is the same as in many other years and models. For details, including parts numbers, see the following quote from an expert at Ford Truck Enthusiasts:
http://www.ford-trucks.com/forums/287185-back-up-light-and-neutral-safety-switch-2.html#post5601846
The neutral switch also controls the backup lights, and is the same 1967/77.
C7TZ-7A247-A .. Neutral/Backup Switch (Motorcraft SW-600)
There is no separate backup light switch..except on 1967/68 F350's.
Neutral switch location 1967/77:
The plastic half moon shaped neutral safety switch mounts on the outside lower portion of the steering column (NOT on the transmission!).
It's activated by an inverted Y shaped lever that snaps on the shift tube
D0TZ-7B097-B .. Lever, Neutral Switch Actuator = From FTE sponsor DIRECT FORD PARTS: Ford suggested retail price: $18.72 / FTE member net: $13.23.
The switch is also still available from Ford, but the website is down so I can't post the list & net prices. .
1978 is the FIRST year the F100/350's have the neutral switch mounted on the transmission. __________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
IMAGES
Driver side of the neutral / reverse switch showing the travel slot for the switch arm, the return tensioning spring, and the arm.
The front, steering wheel side of the neutral / reverse switch after removal from the steering column. The switch's two functions are actuated when the lever in the column moves the switch lever shown here to different positions as gears are selected.
The neutral switch is installed on the steering column near the firewall, with 5/8" bolts into the steering column (visible hole) and down column from a rectangular opening in the column housing. The actuating lever for the switch is attached to the gear shift shaft inside the housing; the lever is visibly protruding from the opening in this image.
Back of neutral / reverse switch, showing the wiring attachments. Black with red stripe is the backup light wiring, Orange with blue stripe is the neutral safety switch, it prevents starting in gears other than neutral & park.
Aug 03, 2010 | Ford F-100 Cars & Trucks
Cant locate the turn signal relay
From Central Junction Box (F2.23 , 10Amp)
More details about wiring diagrams can find in autozone.com (free register), select the year, make, model and engine for access to this info.
Hope helps with this. Good luck.
Dec 29, 2009 | 2003 Ford F250 Super Duty Crew Cab
Need assistance with wiring
The RH (Passenger's) side Cylinders 1, 2, 3, and 4 The LH (Driver's side) Cylinders 5, 6, 7 and 8107127755
May 27, 2009 | 1998 Ford F150 Regular Cab
Replacing key switch on 85 ford tractor 4600
Hi..my name is Keith..i restore old ford tractors..but i dont have a wiring diagram for a 1985...but usually the connectors on an ignition switch(im assuming that what you are refering to) is labled with an I for ignition..a B for battery..a G for ground and an L for lights..and you can trace the wires to these these componets...i hope this has helped..if not please write me back
Apr 09, 2009 | Ford Garden
1998 ford f150 4.6L V8 2wheel auto, spark plug wiring diagram
you can get it online or go too auto zone and look it up in the manual
Feb 19, 2009 | 1998 Ford F150 Regular Cab
Ford Tractor Grill 2600 3600 4600 5600 6600 7600 Logo
586 people viewed this question
Top Ford Garden Experts
Dennis Key
Dennis Key
fordexpert
donald boissonneault
Are you a Ford Garden Expert? Answer questions, earn points and help others
