Question about Kenmore Washing Machines
I have a top load kenmore washer the spin cycle works but it wont fill up with water.
    President:
  • 1,430 Answers
First you should remove the hoses and clean the screens in the ends of the hose, some hoses have screens in both ends. While the hoses are removed look inside the water inlet valve there should be a screen in there also remove and clean the screen out. Some screens will not be removable so you will need to clean in place or remove the water inlet valve. If all is clear you will need to check the solenoids on the water inlet valve for power.If the solenoid has power when put in a fill cycle and no water eneters your washer you will need to replace the water inlet valve. Most water inlet valves must be replaced as a unit, so if one solenoid fails you replace the hole valve assembly. These are inexpensive and easy to replace. Here is a video at that will walk you thru the testing a water inlet valve. It may be a different model but the testing will be the same. If you need help disassembling there are also videos of disassembling most styles. You can also enter your model # for diagrams and illustrations of your specific model. Not all models will be available. All parts come with installation instructions.
Posted on Oct 06, 2010
My 21882 top load Kenmore washer will start the cycle but stops after filling up; i can restart the cycle by pushing the knob in and going a little further in the cycle then starting again. But after a...
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Jan 29, 2011 | Kenmore 24032\24036 Top Load Washer
    Washer filles with water but wont change cycles
    start filling the washer on the warm cycle,turn washer off,if the water keeps filling then you have a bad water inlet valve,if it turns off then you have a loose water level hose or the water level switch is bad-mike
    Jul 21, 2009 | Kenmore 22422 Top Load Washer
    Washer fills with water and just sets there spin cycle works
    The timer is failed in this case.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
    Mar 17, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
    We just purchased a top load Kenmore 800 washer machine. We have washed 2 loads of clothes and Now it has stopped filling up with water. It will not do it to wash or to rinse. We have gone thru the mannual...
    The first thing seems to be the timer,or the water level switch. Try filling the washer with water by hand, if it starts to agitate after being filled its the timer, if not it is the water level switch, let me know if you need further assistance.
    Mar 13, 2009 | Washing Machines
    I have a kenmore elite washing machine and the spin cycle will not work.it both fills up and drains water but it wont spin.
    I have a kenmore elite washer. whwn on spin cycle it does not spin and als o will no agitate. There is a loud noise wen on spin cycle. Please help
    Dec 20, 2008 | Kenmore 24032\24036 Top Load Washer
    Kenmore washer Model# 11024642300
    Dear Customer
    Please perform the following checks
    Does it drain and spin if not lift the lid and close it slowly did you here a click? no click check lid switch. if it drains but wont spin and the motor is running most likely a bad motor coupling. fills and nothing but it dose drain and spin look a the water level switch. need more info model # Please rate this,Thank u
    Dec 16, 2008 | Kenmore 24032\24036 Top Load Washer
    Washer will not fill
    not your timer / if anything its eather the water valve or the water slector switch
    Nov 23, 2008 | Kenmore 24032\24036 Top Load Washer
    Washer stopped in the middle of the cycle
    sounds like motor if nothing stuck between tubs or in pump ,check these first if ok you have bad timer
    Nov 12, 2008 | Kenmore 22422 Top Load Washer
    Washer doesnt spin
    ck the coupling between motor and gearcase it is probably broke and won't drive the transmission
    Nov 08, 2008 | Kenmore 24032\24036 Top Load Washer
    Washing Machines Logo
    96 people viewed this question
    Sal DeAngelo
    fordexpert
    Ed Mac
