Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
Where do u attach the the hose to get suction for cleaning furniture?
  • 377 Answers
Tried to track this down, but did not find anything specific. I did find a URL that shows the detachable hose with written instructions (very short) about attaching it to the unit. If you have the owners manual and go to the URL, you might be able to answer the question.
http://www.vacuumpartstore.com/mof59f59f59f.html
Paul
Posted on Oct 06, 2010
Lost manual. How do i hook up the suction part of the furniture upholstery attachment? I know where to plug it in to spray cleaner on the furniture but where does it plug in to **** it up? Model...
on the attachment where you put the attachment remove the lid, then remove the back panal, and slide the suction thing down not much pressure, re apply the lid then put back in vacuum, turn on and there you go...
Sep 02, 2011 | Hoover F5906-900 Upright Steam Vacuum
My attachments tool has no suction. I made sure I have selected tools and I cleaned the lint filter. There is definitely suction in the machine, but it does not come through the attachments hose.
Check the attachment hose for any hindrances like clogged with dirt or object. Also a big hole cracks in hoses will cause suction to divert it outside. Clean the machine to make sure it will provide suction powerfully. Regularly clean it and you will assure it's will perform better.
Thanks for asking.
Jul 17, 2011 | Bissell 9500 ProHeat 2X CleanShot Upright...
I have a Hoover Deluxe Spin Scrub carpet cleaner that has lost suction. I read the solution by Chris Jones of GoVacuum.com, in which he described the design flaw whereby the tool attachment hose tears at...
A tear in the hose will only affect pick up through the hose when using it to clean furniture, stairs, and such. It will have no effect on the carpet cleaning operation. If the hose cannot be replaced for a while, black electrical tape is one solution to seal the crack.
Mar 29, 2011 | Hoover SteamVac F5914-900 SpinScrub...
Blocked suction
Here is a tip that I wrote about my Bissel ... the hose should just pull out... it is just stuck in there tightly...
Bissell Bagless Upright Vacuum not working
http://www.fixya.com/support/r4387950-bissell_bagless_upright_vacuum_not
heatman101
May 28, 2010 | Royal 088500 Featherlite Upright Vacuum
My Hoover Steam Vac Spin Scrub aw/ Clean Surge
Greetings,
A few more things that you can try on your SteamVac. First remove the dirty water solution tank from the machine completely. You should see where the solution tank was just sitting, a plastic casing with a whole in it. This is actually where the suction from the motor goes into. Turn the machine on and feel the hole there for any suction coming out. Did you feel suction coming from the hole? If yes, then your issue is going to be something with the dirty solution tank, because without the tank it's sucking fine. If you didn't feel any suction from this hole, it may indicate that there is something more serious that needs to be taken care of.
One other place you may look on your machine (as long as the upholstery hose for stairs and furniture is already attached to the machine, and you don't have to hook anything up to the dirty water tank to use the attachments) while the dirty solution tank is out of it, is where the attachment hose makes connection with the vacuum. If you recline the handle down while you have the dirty water tank out, look in the back of the handle housing for a hose that enters the housing 3/4 down the housing. Now follow the hose on the inside of the handle not the outside, follow it up to the point where it goes into the neck, near where the suction hole is. Right at the end of the hose, right before the hose cuff, is this ripped, or damaged here?
Please feel free to request a clarification to this repair if you still need addtional help. If you can leave me the model number exactly that would help me help you, lol. I hope that this was helpful to you. If this was helpful to you, may you please click the helpful Thumbs Up Icon in the lower right hand corner of this repair?
Thank you so much,
Chris J.
Mar 21, 2010 | Hoover SteamVac F5914-900 SpinScrub...
I have a dirt devil featherlite deluixe carpet shampooer and lost manual, how do i use to clean my furniture?
remove the "remove to attach hose" plate.. that is where the hose connects, plug the solution line into the little nipple below the tank on the right side. then you turn it on. Suction will be redirected to the hose, and the trigger on the hose sprays the solution.
Oct 28, 2009 | Vacuums
I have used my Steam Vac for carpeting, but until today, had never tried cleaning upholstery with the spin-scrub brush. I spent a miserable afternoon trying to control the spray, which seemed to go...
I can sympathize. My vac came with two handheld attachments. I have better luck with the handheld attachment that doesn't have the spin-scrub pads. To keep the water from going all over the place, you need to keep the part the you hold only about 1 inch from the surface of the upholstery; if you hold it higher it gets everywhere; if you hold it lower the spray doesn't spread out wide enough and it just makes big water droplets that roll down the upholstry.
If the vac isn't sucking up the water, it is likely you have it set up wrong. Take off the attachment; if you put your hand over the open end of the tube, do you feel suction? When you are using the handheld attachments there is a rectangular piece you remove (attached to the dirty water tank) and you stick the rectangular part from the hose in there. If you are getting suction but it's just not sucking up any water try these 1) maybe you aren't laying down enough water, spray it more heavily OR 2) you need to **** up the water right after you lay it down. Don't let it soak in for more than a few seconds.
good luck!
Aug 17, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Dirt shoots out the vacuum when I unhook the hose to clean furniture
Sounds like you have a small clog in the hose in the head cleaner. Unplug the machne, turn it upside down on the floor with the brushed facing up. Look at the hose that comes from the underneath to where it connects to the expandable hose. Most of the time the clog is in that area. The debris stays in the hose ans it just does not have enough power to go all the way to the bag area from lack of suction. When you disconnect the hose the particles fall back down and the spinning brush kicks it all over the place. If it has a screw holding the hose in place unscrew it and push something solid through the hose. No not use anything sharp or use eccessive force as you can tear the hose. Try losening it then hook up the hose and turn it on to see if the suction from the hose clears it out.
Hope this helps.
Joe
May 26, 2009 | Bissell 3594 CleanView PowerTrak Bagless...
Cleaning uphoustry
Furniture cleaning isn't a science: try out a few techniques before choosing the one that is right for your belongings. This step-by-step guide explains how to clean a sofa:
  1. Before using any upholstery cleaning products, vacuum the sofa or chair first to remove as much surface dirt and dust as possible. Be sure to use the correct attachments to avoid damage to the material - a soft brush attachment is ideal.
  1. Spot Clean. Using baby wipes or vinegar poured onto a strong microfiber cloth, apply to any obvious stains, wiping gently as you go. Remember to test the upholstery cleaning products on an inconspicuous area first.
  1. Overall Clean. Using soapy water and a microfibre cloth, gently wipe your sofa with the solution, allowing it to soak into the fabric and tackle the dirt beneath the surface. You only want to use a very small amount of water - don't saturate the material.
  1. Dry. Some people use a hairdryer to quickly dry a sofa, but allowing it to dry naturally is always the better option, if you have the time. To speed things up, open windows and allow the breeze to help with the drying process.
House Office Carpet Residential Commercial Cleaning Geelong Commercial...
Apr 23, 2008 | Hoover SteamVac F5914-900 SpinScrub...
F5888 900
Doesn't attach at the bottom. If your hose has a block on the one end, take the lid off of the dirty water tank, pull out the block on the front on it and install the block on the end of the hose. Don't forget to put that other block back in when you are done or you won't have any suction.
Nov 11, 2007 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
53 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
