Question about Whirlpool LER4634J Electric Dryer
My dryer will not heat up and the timer does not move no matter how long it runs.
  • Whirlpool Master
  • 3,740 Answers
Hi and welcome to FixYa. I am Kelly.
No heat and the timer not advancing is usually caused by an open cycle thermostat. (Item 20) This link: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5151792&diagram_id=956658#d956658
It can also be caused by a defective high limit thermostat (Item 15 above link) and an open heating element item 17 above link.
Before you even try to take the dryer apart or attempt ANY repairs go to the main CB panel and cycle the dryer CB off by physically pushing the thermostat to OFF (manually resets CB) then back to ON, Test the dryer for heat. Sometimes one of the 2 breakers trips allowing the dryer to run but not heat.
You can download this job aid to assist in locating / replacing the failed part.
http://www.servicematters.com/tech_ref/catalog/pages1-27.pdf
Disassembly order is Top, Toe Panel and Front Panel. Make sure to remove the 2 screws in the lint filter befor attermpting to remove the top.
Make sure to unplug the dryer before attempting any repairs.
Testing of each thermostat is done at room temp with one terminal disconnected with an Ohm meter. They should read continuity (ZERO Ohms) across the 2 terminals.
The heating element should also read a very low resistance across the terminals.
Note item 18 in the first link. Heating element wires are notorious for getting hot and failing at the heating element connections.
I do not at this point think you have a timer problem. There is a very remote possibility that you could have a bad motor switch.
Also check all connections at the dryer cord terminal block connection. These are known to also get hot from a loose connection. See item 42 this link for wire kit to fix the terminal block wires
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5151792&diagram_id=950307#d950307 (Last item on the page)
Thanks for choosing FixYa,
Kelly
Posted on Oct 06, 2010
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
Dryer runs with no heat and never shuts off on its own
what are you running it on?auto or more or less,if so the timer will not advance to off without heat,usually the heat comes on,the dryer heats up until it reaches temp.the heater shuts off and then the timer will start to advance to off,when the heat comes back on the timer will stop advancing and the heat will come on,it will do this until the clothes are dry,so no heat the timer will not move,now if you put it on time dry the timer should count down no matter what just like a clock.if you open the door and look around the opening where you put the clothes in you'll see a tag with the model number send this and i can help you.
Oct 08, 2013 | Kenmore 63942 Dryer
I have a Whirlpool LER4634PQ1 it was working just fine then all of a sudden the dryer just keeps running the knob on the dryer doesn't move and the air isn't warm. Any suggestions on what to s
there is a cycling thermostat in line with the high limit thermostat and timer circuit,on timed dry its disabled and the timer will run no matter what,on any sensor dry setting it uses the heat of the element to heat this cycling thermostat to move the timer as the clothes get drier as the heating element heats the timer doesn't move,when the heater cycles off from the high limit thermostat then timer moves again,you need to find out if its a bad heating element,thermal fuse or possibly even a circuit breaker in the homes electrical panel tripped out on one of the 2 phases that gives you the 240 volts required to operate the dryer element,the breaker may not show its tripped,so shut it off and back on and try this first
Dec 11, 2012 | Whirlpool Dryers
Timer will run dryer but does not time
if the dryer has no heat the timer will not move on auto,when the heat shuts off the timer moves,when the heat comes on the timer stops,it will do this until clothes are dry
Oct 08, 2010 | Kenmore Dryers
63942 Dryer: runs air no heat , timer does not move...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
May 18, 2010 | Kenmore 63942 Dryer
The timer doesn't work. The dryer just runs until
is the heat working?when the dryer heats up and then the heat will shut off then the timer advances,when the heat turns back on the timer stops,heat shuts off the timer will move again,if the heat is working you could have a bad timer
Mar 12, 2010 | Frigidaire GLER341A Electric Dryer
Dryer won't heat and the timer doesn't move. It runs forever with no heat.2 different problems?
if you have timer on time dry and it doesn't move timer is probably bad, if you have it on auto dry or some say more or less the timer will not move if there is no heat
Nov 10, 2009 | Kenmore 63942 Dryer
Our Whirlpool Dryer Will not heat at all and not
Your timer may be the cause of both problems. Not cycling and no heat.
Whirlpool makes a excellent dryer and is worth repairing. Replace the timer first. If you still have a heat problem most of the other parts are around $30.
Nov 09, 2009 | Whirlpool Dryers
Dryer won't heat
you spent a lot for a timer when you needed to check your heating. check the heating element, the high limit, and the thermofuse
Sep 25, 2009 | Whirlpool LER5636P Electric Dryer
Dryer will not heat and timer doesn't budge when running
First of all if this is a gas dryer you should have a tecnician fix so you have no gas problems. If not it sound like you definitekly need a new timer, that is why it does not heat up. All of your cintrols run through the time. It lets the machine know when to go on or off and get hotter or cooler depending on what type of cycle you chose. I hope this helps.
Jan 08, 2009 | Dryers
Whirlpool LER4634J Electric Dryer Logo
169 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
