Question about Garden
My Ryobi string trimmer (CS26) starts fine but bogs down when it gets hot.
    Scholar:
  • 150 Answers
Try turning high speed screw (furthest out from engine) clockwise 1 quarter turn. Also check spark aresster screen. You will find it at muffler exit. Usually 1 screw holing it in. Remove it and clean, I use a bernzomatic torch to burn out deposits.
Posted on Oct 06, 2010
Need service manual for Ryobi Gas Powered String Trimmer CS26
Search ebay prob your best bet for a service manual for cheap
Nov 04, 2013 | Ryobi Garden
Ryobi cs26
Mike it sounds like the head has sheared where it goes onto the shaft. You may be able to get the head off and see if there is any way of re attaching the shaft but it may be tricky. You could use the modelling clay that is also a resin that sets rock hard. (milliput) works for me.
Oct 18, 2013 | Garden
Ryobi cs26 won't start
My 39500 will not start. I change the plug and replaced the fuel lins and bubble
Aug 13, 2010 | Ryobi 26CC, 22 In. Hedge Trimmer
How to start a Ryobi Gas trimmer CS26 RY26500B? I
turn switch to on possition press primer bulb 5 to 7 times choke pull rope then turn choke off
Jun 27, 2010 | Garden
Getting the Ryobi Started
You don't mention what model. On mine, CS26, it says, Turn handle switch to on (right as your holding it), press primer bulb 7x, turn choke handle to start (down), pull till unit starts. Run 6-10 secs then turn choke handle to run, (up). Do not squeeze the throttle trigger during start procedure. Hope this helps
Apr 23, 2010 | Garden
Bought a Ryobi weed trimmer CS26 from Home Depot. The second time I used it string broke both ends. Could not take it apart went to Home depot after 30 days they could not take it apart. They would not...
just cheap equipment. Mark it up to experience and do not purchase equipment fro home center or box stores ever again.
This is just one of the many problems of dealing with
the box stores rather than a full service qualified dealer. If you can
find one in your area, patronize them. Not just when the box store
lets you down but for everything. These type dealers are
disappearing and are not being replaced and soon they will all be
gone.
Sep 05, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
The motor want turn the attachments i.e. string on the trimmer or blade on the edger
there is definitely a problem in the drive shaft. check to make sure there's nothing blocking the mal and female ends. if there is, clean it out and lubricate it so that the male will attach to the female slot. also check to see that both ends are not stripped. if the motor portion of it is stripped, which most liekly is out culprit, then it needs to be replaced, or you need to get a new trimmer. if you do, i recommend the Ryobi model CS26 gas trimmer.if the atachment shaft is stripped, the the attachment needs replacement. if you replace the motor portion you need not lubricate the attatchment slot. if the attachment is stripped, it needs to be replaced, but im quite sure the female end in the motor shaft is our problem. it could also be broken inside the shaft. make sure nothing falls out if you hold the attatching ends to the ground.
May 31, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Garden Logo
790 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
