Question about Sport & Outdoor - Others
My 1985 ez-go golf cart resistor coil is turning red hot almost immediately after I engage the motor. I have tightened all connections and made sure the forward and reverse selector is not contacting both connections at the same time. What can i do to correct this problem?
4 Suggested Answers
  • 6 Answers
SOURCE: electric golf cart, mash the pedal won't move
you have a broken belt .
Posted on Jun 03, 2009
Benimur
  • 6966 Answers
SOURCE: Where can I get a free owners manual for a 2000 ez
Hi and welcome to FixYa,
The owner's manual is dependent on the exact model of the E-Z-GO Golf cart. To start, pls click here and choose your model. The manuals are in pdf form and would require Adobe Acrobat Reader.
Good luck and thank you for using FixYa.
Posted on Jun 25, 2009
shocktroop40
  • 155 Answers
SOURCE: ez-go golf cart press accelerator pedal and nothing happens
The first thing I would do is lift the seat and check the battery connections. Those batteries are notorious for corrosion at the terminals. Make sure every connection is clean and solid, as in no loose, corroded or frayed battery cables. Next, if the batteries check out, toggle the run/tow switch, also under the seat to make sure it is fully engaged into the run position, and finally check the forward/reverse lever to make sure the connections are clean and tight.
Posted on Aug 03, 2009
2010 ez go electric golf cart steering wheel turns but wheels don't turn
You might have to loosen the bolts holding the steering arms to get the pole to line up, but if no piece is missing , sure connect it and secure with the locking bolt in the spiral.
Jun 12, 2017 | Golf
We have a 1999 gas club car golf cart just replaced the ignition coil. It now won't turn off
You need to run a wire to the coil from the hot wire coming from your key/ignition switch. This will ground the coil and eliminate the spark.
Sep 02, 2016 | Golf
I have an older electric ez go cart, like 84 I think. There are 4 wires running to back where one connects to a spring looking thing. That spring is glowing red hot. Any suggestions?
That is your speed resistor coils and they are supposed to get hot. Electric current passes though those coils on the way to the motor. When all coils are in circuit, then that is your slowest speed. Check the coils, no broken loops and no loops touching each other. and check the cable connections also (corrosion, loose, etc)
Jun 05, 2016 | Golf
Club car golf cart
If it was me, if it gets hot, that's usually a sign that the juice if flowing through it wrong. Sounds like you've got something hooked up backwards. or grounded out to something else. Check everything again. Get help from a professional if that doesn't fix it.
Nov 28, 2013 | Golf
I HAVE A 1999 ez go cart and we smelled burning
Look under the cart and make sure the wires to the motor are good.
Oct 01, 2009 | 1995 Volkswagen Golf
Ez-go golf cart press accelerator pedal and nothing happens
Aug 03, 2009 | Sport & Outdoor - Others
Ez Go 28115-G01 battery charger does not work.
I have an EZGO powerwise 36V charger, model 28115-GO3 that was installed onboard a cart. I want to use this charger for another cart, but the charger has 3 wires out. Why 3 wires? One is +, the other -. what do I do with the third wire? The wires are red, black and yellow; two odf the wires are 10-12 gauge, the other is around 16 gauge.
Mar 26, 2009 | Electronics - Others
Sport & Outdoor - Others Logo
490 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
