Question about GE (PSS26MSRSS) Side by Side Refrigerator
The temperture gets too cold even after I reset it to 40 it will get to 32 and freeze my veggies.
    Sergeant:
    Champion:
  • 351 Answers
Damper has gone bad not controling air from frezer
Posted on Oct 08, 2010
Testimonial: "I'll check it, thank you so much. I didn't know where to start!"
  • freeze1 Nov 15, 2010
    I have exactly the same problem. Wher is the damper located? Is it covered under the 5 year compressor and sealed system GE warranty?
Why is it warm on top shelves and freezing veggies on bottom?
Cold air sinks. Meanwhile there has to be some sort of fan moving the air around in there so temps are pretty even through out. See if it operating properly.
Oct 08, 2016 | GE Refrigerators
Model SJF750SP. Refrigerator temperature 6 degrees Celsius. Why does everything freeze, even veggies in the veggie bin?
First try adjusting the thermostat inside the refrigerator to a lower number. If this does not work, you have lost some refrigerant from the system, due to a leak. The system would then need more refrigerant installed to correct the freezing problem and repair the leak.
Oct 19, 2015 | Sharp Refrigerators
My refrigerator Kenmore model 795 77563600 freezes up the vegies on the left side drawerand werever I store on top of that drawer. What can it's wrong with it?
Your refrigerator as cooling tubes that allows the cold air or the freezer to go to the refrierator side. If one becomes blocked with frost all the cold air is then forced to route through the other cooling tube. And that what it sounds like is happening to you.
Jan 04, 2012 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
A while back the refrigerator was freezing everything even though it was set on low. Even the veggies in the veggies drawers would freeze. Now, it stopped doing that but once in a while it will start...
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Jul 26, 2011 | Magic Chef CTB1722 Top Freezer...
My refig keeps freezing items in the veggie bins and even above that
Lower the settings to 1 or 2. If you have veggie bins with the sliding adjusting air vent (door thingy) check them and make sure the settings are cold and not colder. it brings more air to the bottom. Cold air drop to the bottom because it is heavier than warm air.
Mar 30, 2010 | Refrigerators
The bottom crisper in my refrige freezes my veggies
To repair this problem I dont think just toggling a lever is going to work. You need to locate what is suppose to sense the temp in the fridge section and how it stops the air flow to the fridge section. Basically most refrigerators cool in the freezer using the freon coils and transfer the cold to the fridge section using the fan in the freezer. Then your thermostat (temp sensor) stops the air flow by either turning off the fan or closing a small door going to the fridge section. This door is called the baffle and if you put your hand up to it and can still feel air coming thru when the temperature is 39 degrees or lower its not doing its job. With a model number I could help better but my guess is if its not freezing everything only the veggies your thermostat is off or the baffle is unable to close all the way and may have ice or debris in it. Either way I hope this helps.
Jan 24, 2010 | Refrigerators
Why are my veggies freezing even thought the temp is set to 40?
Most fridges have crisper drawers that have a selection lever on either the front or side of the drawer that allows you to select eiher veggies or meat. Veggie setting is supposed to keep the crisper drawer warmer, while Meat setting makes it the coldest possible.
If you don't have the selector slide levers, I would suggest you use the highest possible crisper drawer available, as the lower in the frdge compartment you go, the colder the air will be. That should resolve the problem you're having, other than lowering the fridge temp setting slightly.
You might notice a cold air exchange vent next to your crisper, which supplies cold air from the freezer section into the fridge section, so that could be contributing to the colder temps in the crisper where you keep your veggies.
Hope you find this Very Helpful and best regards!
Aug 20, 2009 | Jenn-Air JBL2088H 20 Cu. Ft. Cabinet-Depth...
Temperature too cold even when on lowest
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Jul 12, 2009 | Refrigerators
Food freezing in frig
Go to the link below and the choose line 22 and click it. That link page helps identify most common problems you may have with your refrigerator, Thanks Sea Breeze.
 http://www.applianceaid.com/refrigerator.html
Sep 11, 2007 | GE Profile PSI23NCR Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
325 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
