Question about Samsung LT-P227W 22 in. HD-Ready LCD Television
Samsung ltp227w will not turn on tried different cords light will not even come on. think it is power supply how do i fix this
4 Suggested Answers
SOURCE: Samsung LTP227W
I believe the internal adaptor board is available from partstore.com, specifically: http://www.partstore.com/Part/Samsung/Samsung/LTP227W/Samsung/Samsung/BN4400109A/New.aspx
Posted on Apr 27, 2008
SOURCE: No power to Samsung FP-T5084
I had the same problem twice with my Samsung FPT 5084 and it was the 12 AMP fuse on the power board both times. The bad part is you have to remove the whole back plate to get to it but once off it sits on the power board (dead center) towards the lower left hand side of it. Replace the top fuse or you can replace both. They're just regular ceramic sealed 12 AMP fuses that cost about 50 cents each.
Posted on Apr 23, 2009
  • 6 Answers
Usually the power supply is bad. Just 3 capacitors 1000uF 35volt rating. The 3 electrolytic caps will be puffed out, simply replace tham and you will be back in business.
Posted on May 22, 2010
Samsung tv won't turn on
try the main PCB. This has your CPu on it which controls this circuitry.
Try this web site, but use your COMPLETE model number as various sub models use different parts. https://www.encompassparts.com/model/SMGPN51F4500AFXZA/_/_/Samsung/PN51F4500AFXZA/51-INCH_PLASMA_4500_SERIES_TV_720P
main PCB: BN96-24574A
MAIN PCB BN96-19471A
http://www.samsungparts.com/Products/Parts_and_Accessories/PN51F4500AF/Default.aspx
MAIN PCB: BN94-06195C
Mar 03, 2014 | Televison & Video
Samsung nc110 dead no power
If it won't power up even with the power plug connected, you may have a power supply issue. It could be the AC/DC converter on your power cord. You can confirm the power cord is working by using a volt meter to ensure it is producing the power as labeled on the cord.
Jan 20, 2013 | Samsung NC110 Netbook
Bought new power supply, no difference power button will not even go on or light up ; however small green light on mother board lights up. als accidentaly disconnected the switches wiring to the mother...
The green light just show that the motherboard is getting power.
The power button of the front of the case is connected to the mother board, not to the power supply, usually in the extreme lower left corner along with the with the HDD and Reset Button cords; Power button wire are labeled and usually red/black.
If all wired correctly, possible bad or stuck power button or reset button.
Hope this helps.
Please rate this answer by check rating "Hands"
Feb 08, 2011 | E-Machines T3958 (827103050974) PC Desktop
The ac adapter red light stays on and the counsole will not work
This problem occurs when the external power supply has detected a fault. The power supply has several built-in safeguards to help prevent damage to either the console or to the power supply. The power supply will turn off if one of the following conditions is true:
• There is too much current.
• The voltage is too high.
• The temperature of the power supply is too high.
When any of these conditions are true, the light on the power supply turns red. Here are some steps that you can use to try to fix the problem.
Step 1: Make sure that the power supply is cool
The red light might indicate that the power supply is too hot or that it has overheated. Follow these steps if the power supply light is red:
1. Make sure that your Xbox 360 console is turned off.
2. Disconnect your Xbox 360 Power Supply from your Xbox 360 console and from the wall outlet.
3. Let the power supply cool for two hours in a well-ventilated space. Do not connect the Xbox 360 power supply to the console or to the wall outlet during this time.
4. After the power supply has cooled for two hours, reconnect the Xbox 360 Power Supply to the console and to the wall outlet.
If cooling the power supply does not resolve the problem or if the problem persists, use the steps in the next section.
Step 2: Make sure that the power supply is plugged in correctly
Make sure that the power supply is directly plugged into a working wall outlet. You may have problems with the power supply if you use an extension cord or a power strip if the extension cord or the power strip is faulty or cannot supply the required power to the console.
If the power supply is still not working as expected, use the steps in the next section.
Step 3: Plug the power supply into a different wall outlet
To eliminate the possibility that the wall outlet you are using is faulty or that there is a blown fuse, plug the power cord into a different wall outlet in a different area of your place of residence.
If this does not resolve the problem, use the steps in the next section.
Step 4: Try another Xbox 360 Power Cord and Xbox 360 Power Supply
If you have a different Xbox 360 Power Cord and Xbox 360 Power Supply, try to use them to test the console. If the console turns on when you use a different power cord and power supply, you need to replace the faulty power cord and power supply. If the console does not turn on, the issue may be with the console itself.
Step 5: Obtain a replacement Xbox 360 Power Supply
If the steps in this article did not resolve the issue and the Xbox 360 Power Supply light continues illuminate red, you need to obtain a replacement power supply.
let me know how you get on or if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Sep 18, 2010 | Microsoft Xbox 360 Console
Will not turn on even tho plugged in
Try a different power cord or test the power cord on a different piece of equipment.
If it still does not work then the printer has a power supply problem and needs to be repaired or scrapped. A new printer may be a better cost effective solution.
Unless you have electrical knowledge I suggest you do not try to fix mains powered equipment. Mains voltage is dangerous.
Mar 06, 2010 | HP LaserJet 2605dn Printer
Jan 22, 2009 | Samsung FPT5084 50 in. Plasma HDTV
Hp photosmart c4580 won't print
Your problem indicates that your printer is not getting the power supply .
  • Check the power cord for any physical damage. If the power cord is damaged, replace the power cord.
  • If the power cord is not damaged, plug the power cord into a different electrical outlet without using a surge protector. The product power light should turn on.
  • If the product power light does not turn on, the power cord should be replaced.
Dec 09, 2008 | Office Equipment & Supplies
No picture or sound. Red light comes on then goes off.
I had the same problem with my LTP227W and it is also about 4 years old. Took it in to be fixed and they found it was two capacitors in the power supply. Parts for this TV are not available anymore but they were able to repair the power supply. The TV works fine now. Hopefully I can get another four years out of this. Repair cost was $150.
Oct 24, 2007 | Samsung LT-P266W 26 in. HD-Ready LCD...
Samsung LTP227W
Sep 21, 2007 | Samsung LT-P266W 26 in. HD-Ready LCD...
Samsung LT-P227W 22 in. HD-Ready LCD Television Logo
162 people viewed this question
Jerry Greenberg
Jerry Greenberg
