Question about KitchenAid KUDS301V Dishwasher
I can't determine the location of the sound absorber shaft. I have disconnected all electrical and rotate the four retainers. Motor & pump assembly still firmly attached to dishwasher. My dishwasher is a KUDI23HBO. This manual may not be the correct one. Please advise. Thanks, KG
3 Suggested Answers
reddyanantha
  • 205 Answers
SOURCE: Can't get screw loose on Kenmore dishwasher(665.1559579)impeller.
try it by using a high torck screw driver then the direction for loosening the screw is anticlock wise.
Posted on Jul 26, 2009
rylee_smith
  • 8619 Answers
SOURCE: need service manual KUDI23HBO KitchenAid
Hi
Thanks for using FixYa.
Please click on this link to download the service manual for your Kitchen Aid Dishwasher. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Oct 06, 2010
My rack and pion is leaking , how do i replace
To Remove:
  1. Before servicing the vehicle, refer to the precautions at the beginning of this section. NOTE: The wheels of the vehicle must be straight ahead and the steering column in the LOCK position before disconnecting the steering column or intermediate shaft from the steering gear. Failure to do so will cause the SIR coil assembly (clock spring) to become uncentered, which may cause damage to the assembly.
  2. Lock the steering column by installing the J42640 into the underside of the steering column.
  3. Raise and support the vehicle.
  4. Remove the tires and wheels.
  5. Remove the power steering gear heat shield.
  6. Remove or disconnect the following: CAUTION
    Failure to disconnect the intermediate shaft from the rack and pinion stub shaft can result in damage to the steering gear and/or intermediate shaft. This damage can cause loss of steering control, which could result in personal injury.
    • Intermediate shaft lower pinch bolt and coupling from gear
    • Pressure and return pipes from the gear
    • Electrical connector, if equipped
      Stabilizer shaft links at lower control arms
    • Remove the left stabilizer shaft insulator.
    • Rotate the stabilizer shaft to access steering gear bolts.
    • The outer tie rod retaining nuts.
    • Using J24319-B separate the outer tie rods from the steering knuckles.
    • Rack and pinion attaching bolts
    • Rack and pinion assembly through the left wheel opening.
  7. Transfer the outer tie rods if replacing the power steering gear.
To Install:
  1. Install or connect the following:
    • Rack and pinion assembly through the left wheel opening and tighten the bolts to 70 ft. lbs. (95 Nm)
      Pressure and return lines to the steering gear and tighten the fittings to 22 ft. lbs. (30 Nm)
    • Heat shield and bolts. Tighten the bolts to 7 ft. Lbs. (10 N)
    • Install the left stabilizer shaft insulator.
  2. Install stabilizer shaft Links to lower control arms
  3. Intermediate shaft to the steering gear and tighten the pinch bolt to 35 ft. lbs. (47 Nm)
  4. Install the outer tie rods to the steering knuckles.
  5. Install the outer tie rods retaining nuts. torque the nuts to 22ft.lbs(30 Nm) plus an additional 180 degrees.
  6. Install the tires and wheels.
  7. Lower the vehicle.
  8. Remove the steering column anti rotation pin from the steering column.
  9. Fill and bleed the power steering system.
  10. Adjust the front toe.
Lock the steering column by installing the Steering Column Anti Rotation Pin tool J 42640 into the underside of the steering column--Aurora
Steering gear mounting bolts--Aurora
Power Rack & Pinion Steering Gear Heat Shield Removal & Installation To Remove:
  1. Raise and support the vehicle.
  2. Remove or disconnect the following:
    • The stabilizer shaft links.
    • Rotate the stabilizer shaft downward.
    • The electrical harness clip.
    • Power steering gear heat shield mounting bolts.
    • The heat shield.
To Install:
  1. Install the power steering gear heat shield.
  2. Install or connect the following:
    • The mounting bolts And torque to 89in.lbs.(10 Nm)
    • Rotate the stabilizer shaft into position.
  3. Lower the vehicle.
Figure of heat shield removed from above rack bolts with location shown
Feb 11, 2011 | 2001 Oldsmobile Aurora
How to replace main heater fan
Blower Motor REMOVAL & INSTALLATION Front Fig. 1: Front heater blower motor assembly 89696g02.gif
Remove the glove box to access the front blower motor, which is on the firewall 89696p02.jpg
The blower motor vent tube helps to cool the blower motor for efficient operation 89696p04.jpg
A ratchet with extensions makes removal of the retaining screws easier 89696p06.jpg
  1. Disconnect the negative battery cable.
  2. Open the glove box door. Gently squeeze the retainers at the rear of the box inward and allow the box to swing downward. NOTE: If additional access is required, unfasten the glove box hinge retainers and remove the assembly.
  3. Label and disconnect the electrical harness from the blower motor.
  4. Remove the blower motor housing tube and/or blower motor cover.
  5. Remove the blower motor retaining screws.
  6. Remove the blower motor from the A/C evaporator. To install:
  7. Install the blower motor in the A/C evaporator and tighten the retaining screws securely.
  8. Install the blower motor housing tube and/or blower motor cover.
  9. Connect the electrical harness to the blower motor.
  10. Reinstall the glove box and close its door.
  11. Connect the negative battery cable.
Rear Fig. 2: Service cover push pin locations 89696g03.gif
  2. Remove both rear passenger seats.
  3. Remove the three push pin retainers from the lower edge of the auxiliary heater and air conditioning service cover.
  4. Lift the service cover outward and upward to remove.
  5. Label and disconnect the electrical harness.
  6. Remove the blower motor housing tube.
  7. Loosen the three retaining screws and remove the blower motor. To install:
  8. Install the blower motor and tighten retaining screws securely.
  9. Install the blower motor housing tube.
  10. Connect the electrical harness.
  11. Position the service cover and install the three push pin retainers from the lower edge of the cover.
  12. Install both rear passenger seats.
  13. Connect the negative battery cable.
Dec 19, 2010 | 1998 Ford Windstar
Installing blower motor
CAUTION
Before servicing any electrical component, the ignition key must be in the OFF or LOCK position and all electrical loads must be OFF, unless instructed otherwise in these procedures. If a tool or equipment could easily come in contact with a live exposed electrical terminal, also disconnect the negative battery cable. Failure to follow these precautions may cause personal injury and/or damage to the vehicle or its components.
  1. Remove the right side sound insulator.
  2. Pull back the carpet near the blower motor.
  3. Remove the Instrument Panel compartment.
  4. Remove the dash integration module from bracket.
  5. Remove the two rear dash integration module bracket screws.
  6. Reposition the dash integration module bracket to allow for removal of the blower motor.
  7. Disconnect the electrical connector from the blower motor.
  8. Disconnect he blower motor ventilation tube from the module (if equipped).
  9. Remove the blower motor retaining screws.
  10. Rotate and remove the blower motor from vehicle.
To install:
  1. Install the blower motor. Blower motor will need to be rotated to install into the housing. Ensure that the blower motor gasket is properly aligned.
  2. Install the blower motor retaining screws.
  3. Connect the electrical connector to the blower motor.
  4. Connect the blower motor ventilation tube to the module (if equipped).
  5. Reposition the dash integration module bracket to its original position.
  6. Install the two rear dash integration module bracket screws.
  7. Install the Instrument Panel compartment.
  8. Reposition the carpet.
  9. Install the right side sound insulator.
Sep 15, 2010 | 2001 Cadillac DeVille
Where is the a/c blower motor located on my 1997 pontiac sunfire?
prev.gif next.gif HEATING AND AIR CONDITIONING Blower Motor REMOVAL & INSTALLATION Fig. 1: Remove the sound insulator from underneath the passenger side of the instrument panel 91146p69.jpg
Fig. 2: Remove the retaining bolts for the blower motor assembly 91146p61.jpg
The blower motor and fan are serviced as an assembly only.
  2. Remove the passenger side sound insulator.
  3. Detach the electrical connections from the blower motor.
  4. Remove the blower motor retaining screws, then remove blower motor and fan assembly. To install:
  5. Install blower motor and fan assembly, then secure using the retaining screws.
  6. If equipped, connect the blower motor cooling tube.
  7. Attach the electrical connections to the blower motor.
  8. Install the right side sound insulator.
  9. Connect the negative battery cable.
Aug 03, 2010 | 1997 Pontiac Sunfire
I need to remove the cooling fan shroud from my 1995 Lincoln Continental. How is the easiest way to go about this?
Engine Fan REMOVAL & INSTALLATION 3.8L Engines
  2. Remove the radiator upper sight shield.
  3. Disengage the electrical connector, then remove the integrated relay control/constant control relay module assembly located on the radiator support.
  4. Disconnect the fan electrical connector. Fig. 1: Disengage the fan electrical connector 86873115.jpg
  5. If necessary, remove the air bag crash sensor.
  6. Unbolt the fan/shroud assembly from the radiator and remove. Fig. 2: Unbolt the fan assembly from the radiator 86873116.jpg
    Fig. 3: Remove the fan from the engine 86873117.jpg
    Fig. 4: Slide the fan as an assembly up and away from the radiator. Be careful not to dislodge the mounting stud on the left side. 93143p56.jpg
  7. Remove the retainer and the fan from the motor shaft and unbolt the fan motor from the shroud.
  8. Installation is the reverse of the removal procedures. Tighten the fan shroud retaining bolt to 23–33 inch lbs. (2.6–3.7 Nm). Tighten the fan shroud retaining nut to 71–106 inch lbs. (8–12 Nm). Fig. 5: Constant control relay module location — 3.8L engines 86873118.gif
4.6L Engine
  1. Loosen the fan clutch-mounting shaft from the water pump hub.
  2. Loosen the fan shroud from its radiator mounting and remove the lower hose from the shroud.
  3. Lift the fan and clutch assembly and the fan shroud from the vehicle.
  4. If necessary, remove the fan-to-fan clutch retaining bolts and separate the fan from the fan clutch. CAUTION
    Closely examine the fan for cracks or separation, to avoid the possibility of personal injury or vehicle damage. To install:
  5. Assemble the fan and fan clutch. Tighten the retaining bolts to 15–20 ft. lbs. (20–27 Nm).
  6. Install the fan and clutch assembly and the fan shroud. Mount the fan clutch shaft to the water pump hub and tighten to 37–46 ft. lbs. (50–62 Nm).
  7. Slip the shroud into the lower mounting clips and install the shroud retaining screws. Fig. 6: Fan and fan clutch assembly — 4.6L engine 84173064.jpg
5.0L Engines
  1. Loosen the fan clutch-to-water pump hub retaining bolts.
  2. If necessary, remove the drive belt from the water pump pulley.
  3. Remove the fan shroud upper retaining screws. Lift the shroud to disengage it from the lower retaining clips.
  4. Remove the fan clutch-to-water pump hub bolts and remove the fan and clutch assembly and the fan shroud.
  5. If necessary, remove the fan-to-fan clutch retaining bolts and separate the fan from the fan clutch. CAUTION
  6. Assemble the fan and fan clutch. Tighten the retaining bolts evenly and alternately to 12–18 ft. lbs. (16–24 Nm).
  7. Install the fan and clutch assembly and the fan shroud.
  8. Install the fan clutch-to-water pump hub bolts.
  9. Slip the shroud into the lower mounting clips and install the shroud retaining screws.
  10. If removed, install the water pump drive pulley and adjust the belt tension; refer to Section 1.
  11. Tighten the fan clutch-to-water pump hub bolts evenly and alternately to 15–22 ft. lbs. (20–27 Nm). Recheck the belt tension.
Jul 14, 2010 | 1995 Lincoln Continental
How do i replace fuel pump on 1998 escort se 2.0
Removal & Installation WARNING Extreme caution should be taken when removing the fuel tank from the vehicle! Ensure that all removal procedures are conducted in a well ventilated area! Have a sufficient amount of absorbent material in the vicinity of the work area to quickly contain any fuel spillage. NEVER store waste fuel in an open container, as it presents a serious fire hazard!
This procedure will require a new fuel pump gasket for pump installation, so be sure to have one before starting.
  1. Relieve the fuel system pressure.
  2. Disconnect the negative battery cable.
  3. Remove the rear seat cushion and unplug the electrical connectors from the fuel pump.
  4. Unfasten the four pump access cover screws and remove the cover.
  5. If equipped, unplug the pump electrical connector located under the cover.
  6. Unfasten the fuel line clip(s) and disconnect the line(s) from the pump.
  7. Use a fuel pump locking ring removal tool or a brass drift and a hammer to unfasten the pump locking retaining ring.
  8. Remove the fuel pump and the gasket from the tank.
To install:
  1. Install a new gasket and place the pump into position in the tank.
  2. Install the pump locking retaining ring.
  3. Connect the fuel line(s) to the pump and install the line retaining clip(s).
  4. If equipped, attach the fuel pump electrical connection(s).
  5. Install access cover, then tighten the retainers.
  6. Attach the pump electrical connector(s).
  7. Install the rear seat cushion.
  8. Connect the negative battery cable.
  9. Start the car and check for proper operation.
May 13, 2010 | 1998 Ford Escort
Need location on blower motor resistor on 1994 pontiac bonneville
Fig. 1: The blower motor and fan assembly is mounted in the heater and A/C module, and is accessible from the engine compartment
GM Bonneville/Eighty Eight/LeSabre 1986-1999
Blower Motor - REMOVAL & INSTALLATION
(see Figures 1 and 2)
  2. If necessary, tag and disconnect the number 2, 4 and 6 spark plug wires from the ignition coil and move the coil out of the way.
  3. For 1993-99 vehicles, remove the nuts and cross brace bar.
  4. Detach the electrical connections from the blower motor.
  5. Disconnect the cooling tube from the blower motor.
  6. Unfasten the screws securing the blower motor to the blower module assembly.
  7. Remove the blower motor and fan assembly from the module.
  8. If necessary, unfasten the nut attaching the fan to the blower motor shaft, then pull the fan from the blower motor.
Fig. 2: You can disassemble the fan from the motor by removing the retaining nut
To install:
  1. If the fan was removed from the motor, position the fan on the shaft, then install the retaining nut. Tighten the nut to 12 inch lbs. (1.4 Nm).
  2. Position the blower motor and fan assembly to the module, then install the retaining screws. Tighten to 5 inch lbs. (0.6 Nm).
  3. Connect the cooling tube to the blower motor.
  4. Attach the electrical connector to the blower motor.
  5. On 1993-98 vehicles, install the cross brace bar and retaining nuts. Tighten the nuts to 18 ft. lbs. (25 Nm).
  6. If removed, install the coil and connect the spark plug wires, as tagged during removal.
  7. Connect the negative battery cable.
Hope this helped (remember rated and comment this).
Mar 26, 2010 | 1994 Pontiac Bonneville
How to r&r powersteering pump 1998 mercury grand marquis
Hopfully this will be ALL you need Besides Pulley REMOVAL TOOL It can be Rented @ AutoZONE
REMOVAL
  1. Remove drive belt.
  2. Raise vehicle on hoist. WARNING: TURN AIR SUSPENSION SWITCH (LOCATED IN LUGGAGE COMPARTMENT) OFF TO PREVENT VEHICLE DAMAGE OR PERSONAL INJURY.
  3. Remove power steering pressure hose bracket.
  4. Disconnect electrical connector at power steering control valve actuator.
    1. Install Steering Pump Pulley Remover T69L-10300-B on the pulley hub. CAUTION: Do not apply in-and-out pressure on the power steering pump shaft. Pressure will damage the internal thrust areas.
    2. Hold the small hex-head and rotate the tool nut counterclockwise to remove the power steering pump pulley.
    3. Disconnect power steering pressure hose at power steering pump and drain fluid into a container.
    4. Disconnect power steering return hose at power steering pump and drain fluid into a container.
    5. Remove four retaining bolts and power steering pump and power steering pump pulley assembly.
    6. Remove power steering pressure switch from pump.
    INSTALLATION
    1. Position the power steering pump on the mounting bosses of engine block and install the bolts at the side of the power steering pump. Tighten to 20-30 Nm (15-22 ft. lbs.).
    2. Connect the power steering reservoir pump hose to the power steering pump and reposition the hose clamp to power steering pump inlet fitting.
    3. Replace power steering pressure hose O-ring.
    4. Install the power steering pressure hose to the power steering pump fitting. Tighten the tube nut with a tube nut wrench rather than with an open-end wrench. Tighten to 34-46 Nm (26-33 ft. lbs.). NOTE: Swivel or end play of the power steering pressure hose end is normal and does not indicate a loose fitting.
    5. Place the power steering pump pulley on the power steering pump shaft and install Power Steering Pump Pulley Replacer T91P-3A733-A. The small diameter threads on the tool should be engaged in the power steering pump shaft. CAUTION: Do not apply in and out pressure on the shaft. Pressure will damage the internal rotating group.
    6. Hold the small hex-head and rotate the tool nut clockwise to install the power steering pump pulley on the shaft. CAUTION: Do not apply in and out pressure on the shaft. Pressure will damage the internal rotating group. NOTE: The power steering pump pulley face must be flush within 0.25 mm (0.010 inch) of the end of the pump shaft.
    7. Remove the Power Steering Pump Pulley Replacer T91P-3A733-A.
    8. Remove the shipping tube nut from power steering pump housing prior to installation.
    9. Connect electrical connector to power steering control valve actuator.
    1. Install power steering pressure hose bracket.
    1. Lower the vehicle.
    2. If equipped, turn the air suspension ON.
    3. Install drive belt on the power steering pump pulley.
    4. Fill the power steering pump reservoir with Power Steering Fluid Motorcraft MERCON(r) ATF.
Oct 04, 2009 | 1998 Mercury Grand Marquis
Ford Taurus 1999SE-Windshield wiper motor just hums.How to fix ?
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Disconnect the battery ground cable.
  3. Remove the wiper arms.
  4. Remove the 8 plastic retainers and the 6 clips holding the cowl vent screens to the inner panels. Turn the retainers 1⁄4 turn counterclockwise to remove.
  5. Remove the cowl vent screens.
  6. Disconnect the electrical connector from the wiper motor and remove the 4 bolts that mount the module assembly to the cowl.
  7. Remove the windshield wiper module from the vehicle.
  8. Rotate the wiper operating arm in a clockwise direction to gain access to the bolt retaining the arm to the motor. WARNING
    Always rotate the wiper operating arm in a clockwise motion or damage to the motor could occur.
  9. Remove the nut retaining the wiper operating arm to the wiper motor.
  10. Remove the three wiper motor-to-wiper module assembly retaining bolts and remove the motor from the vehicle.
To Install:
  1. Position the wiper motor on to the module assembly. Install the three wiper motor-to-wiper module assembly retaining bolts. Tighten the bolts to 115-151 in lbs (13-17 Nm).
  2. Position the wiper operating arm on the wiper motor output shaft. Install the mounting nut and tighten to 22-29 ft-lbs (30-40 Nm).
  3. Position the windshield wiper module onto the cowl. Install the mounting bolts and tighten to 106 in-lbs (12 Nm).
  4. Connect the wiper motor electrical connector.
  5. Position the cowl vent screens onto the inner panels. Install the 8 plastic retainers and the 6 clips holding the cowl vent screens to the inner panels. Turn the retainers 1⁄4 turn counterclockwise to install.
  6. Install the wiper arms.
  7. Connect the battery ground cable.
  8. Adjust wiper arms if necessary.
Here is the picture of the motor....it is the round object in the middle of the picture that looks like a can and has a square block on the end of it.
You have to remove the cowl vent panel....just under the windshield. $64.00 for a new motor.
Oct 01, 2009 | Ford Taurus Cars & Trucks
Ge dryer just stop working is there a circuit breaker in the dryer
basic problems]
First check these:-
1) Over load cut off (try running it empty)
2) circute failur and fuse blown
Sep 20, 2009 | GE DBSR453EBWW Electric Dryer
KitchenAid KUDS301V Dishwasher Logo
26 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
