Question about Ingersoll Rand Air Compressor Start Up Kit for 125 and 13 Hp Gas Powered Compressors
We are facing problem is loading and unloading system
    Champion:
  • 248 Answers
Web search-ingersal rand-find site for customer care should be able to solve your problem
Posted on Oct 08, 2010
I have a Model# SSR-EP10 IR compressor that wants to start loaded, if I release the load it fills up and then cuts off with out going to unload and then when it calls for air it try to start loaded.
How are you unloading it? There is an unloader valve that is usually a manual lever connected to the regulator. 0531-051 - DIAPHRAGM,UNLOADER for Ingersoll Rand compressors
May 24, 2015 | Air Tools & Compressors
HIGH TEMP ALARM, UNLOADING AND THEN LOADING OVER AND OVER.
Please check your cooling system including the oil. It may time to replace the oil.
Also please check and set your load - unload pressure to wider range to prevent load-unload in short cycle.
Regards, Jay
Apr 26, 2011 | Eaton 1" Air Compressor Check Valve
I HAVE ZT30 ATLASCOPCO AIR COMPRESSOR.THE FAULT PROBLEM ON IT NOW IS THAT IT DOES NOT COMPRESS(LOAD) AND DISCHARGE (UNLOAD) AUTOMATICALLY, IT LOADS AND UNLOAD ONLY IF I MANUALLY OPEN THE MANUAL VENT...
It sounds like the unload valve might be clogged up. Try taking it off anf cleaning it back up. If the compressor is older or has had a lot of use sometimnes when the rings wear oil and gunge will get into the valve and gum it up. good luck
Mar 10, 2011 | Air Tools & Compressors
Have a 6 cd changer that will not unload cd. the changer was loaded with cd and the battery went dead and once installed a new battery it s not showing any cd in the slots and will not let me unload cd s...
my 6cd changer will not run..unable to eject cd or load them..sounds like some motor is running and then stops..very upset..live my system need it to work
Jan 03, 2011 | 2006 Mercury Mountaineer
Compressor wont restart because of head pressure
Piston air compressors have to unload to permit a restart, the two mot common types are an unloader valve or free air unloaders.
with an unloader valve this system uses a check valve mounted in the discharge line as it enters the tank, when the pump stops this check closes and does not permit the tank pressure to return to the pump. a unloader valve also opens to allow air pressure in the discharge line to vent, this valve is either on the pressure switch or on some models is on the pump, and is a centrifugal type.
Free air unloaders or head unloaders are a set of fingers that hold open the intake valves on the cylinders to permit the piston not to pump air against a head load, and once the pump is running the fingers retract to allow the pump to function as normal.
Jan 19, 2010 | Air Tools & Compressors
I have a 125 hp air compressor and it will be running and shuts right down. shows starter fault. it had a fault that said check inlet system then it said check down load. replaced the inlet system cord to...
IS IT UNLOADING FULLY WHEN ITS REACHED CAPACITY. HAVE YOU WATCHED THE AMP DRAW ON THE MOTOR WHILE MOTOR IS LOADED AND UNLOADED. IS IT IN START-STOP MODE OR DOES IT CONTINOUSLY RUN? JODY
Jun 26, 2009 | Ingersoll Air Tools & Compressors
Ingersoll Rand Air Compressor Start Up Kit for 125 and 13 Hp Gas Powered Compressors Logo
126 people viewed this question
Top Ingersoll Rand Air Tools & Compressors Experts
elunsford
Joe Garcia
Joe Garcia
Eddie Tucker
Level 1 Expert
Are you an Ingersoll Rand Air Tool and Compressor Expert? Answer questions, earn points and help others
