Question about Frigidaire Kitchen Ranges
BRAND NEW GAS STOVE MODEL#FFGF3023LB--INSTALLED YESTERDAY--IGNITOR WILL NOT SHUT OFF--TOP BURNERS LIGHT,BUT WHEN I SHUT OFF THE BURNER,THE LIGHT GOES OFF,BUT THE IGNITORS KEEP ON CLIKKING AND WILL NOT SHUT OFF---UNPLUGGED ELCT.POWER CORD FROM WALL,CALLED TECH,SAID MIGHT BE SOME LIQUID SPILL OR SOMETHING--TO CALL HIM TOMORROW--HE INSTALLED THE STOVE YESTERDAY--WHY DOES IT KEEP ON CLIKKING?
  • ozuna21891 Oct 06, 2010
    HAD A BRAND NEW FRIGIDAIRE GAS STOVE INSTALLED YESTERDAY--CONVERTED TO PROPANE AND TECH ADJUSTED EVERYTHING TO SPECS.--TODAY LIT ONE OF TOP BURNERS AND EVERYTHING OK--SHUT FLAME OUT,THE IGNITION JUST KEEPS ON CLIKKING--WILL NOT QUIT--HAD TO DISCONNECT ELECT POWER CORD FROM WALL--WHAT COULD BE THE PROBLEM?COULD IT BE A PROBLEM WITH THE IGNITOR?
    WILL GIVE THIS INFO TO MY TECH -WILL BE HELPFUL--THANKS
  • 11,800 Answers
In this model the clicker keeps working if you keep the Knob on Lite so make sure it's not there first.
The clicker is electrically triggered: when you turn one of the gas buttons a small contact situated on it is activated - this button powers the clicker module, starting it up. In your case the contact on the last burner that you used has failed - it happens on brand new appliances. It has been badly assembled in the factory and now it has become stuck closed, keeping the clicker functioning.
All you need to do is to access the switch and disconnect it. Later the switch will have to be replaced.
Posted on Oct 06, 2010
  • Frigidaire Master
  • 1,711 Answers
The ignitor is having inside an electric switch with contacts. So this switch has been stuck in on position. This usually stuck after along use or after some liquid spill oven it. In your case if you have not have the chance to use it yet then the ignitor was faulty from the beginning and it just stuck after a couple of uses. For electrical parts many times there is such a possibility. The only thing you should do just remove it from the mains when you don't use it until the supplier will replace it with new. Just advices if they try to fix it don't accept that you should demand to put a new one. Is not a big cost but if they fix it in some moths you have big chance to have the same problem and be in the same situation again which is very annoying.
Igniter glows but why doesn't burner light?
Igniter could still be faulty(not hot enough) or burner control valve
faulty. press the helpful button and check link videos below
Gas Stove Top Burners Not Lighting Not Working
Gas Stove Ignitor and Burner Not Lighting
Daddy Chores Gas range won ignite How to fix it
Jan 22, 2016 | Kitchen Ranges
The igniters for the 6 burner are not sparking. The igniter for the griddle does spark. i do small gas when trying to light-how do I get to the spark modules
Gas Stove Top Burners Not Lighting / Not Working - YouTube
? 5:20
https://www.youtube.com/watch?v=dP3l5AW3YrI
Jul 19, 2012 - Uploaded by Bill Newberry
... not lighting. These are the 3 main reasons for gas range burners to not light. ... I see the igniter sparking but not lights up the gas. One thing I ...
Gas Stove Ignitor and Burner Not Lighting - YouTube
? 1:10
https://www.youtube.com/watch?v=1ZXz8_Md8hI
Nov 20, 2011 - Uploaded by Mike Klimek
Here is an easy fix if you hear the ignitor "clicking" but not lighting the burner. For more information, go to ...
How to Troubleshoot Gas Stove Burner Ignition Problems ...
homeguides.sfgate.com > Landlords & Tenants > Landlord Problems
Dec 19, 2015 | Kitchen Ranges
We are cranking up this BRAND NEW Vulcan flat top. Weh have the convection oven below up and running, but we can't even see a pilot light for the flat top. Advice anyone? Culinary-yours Chef Geir
older ovens have pilots but the newer machines are electronic ignition,there are ignitors in the oven and electrodes or ignitors on the top burners,when you turn the knob for the burner you should hear a clicking sound and see a spark around the burner,that's what lites the burner,the gas comes in and the spark ignites it,i don't know much about your machine but it can't be any different from other stoves.if none are sparking there should be a spark module in there or they could have separate modules,if you send the full model number i can look it up for you
Oct 30, 2010 | Stoves 60" VULCAN RANGES GAS(CLICK HERE):...
When I turn any burner on, the ignitors work fine but it takes a very long time for the burners to ignite. Problem is worse the longer the top has been turned off. Once gas gets to the ignitor, it lights...
It seems like one of your burners is clogged. You made need to use some oen cleaner and a small toothbrush to clean the burner. If the problem occurs with all the burners, then you have a blockage in the gas supply line. you willm have to take it apart at the stove and clear it out. Check the main gas connection and at the burner(s) to spot the debris clogging. Make sure to shut your gas valve off behind the stove. Good luck... hope this helps.
Jul 15, 2010 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
Miele KM 3474 stove top lights but turns off after 30 seconds
Does the burner attempt to re-ignite after it goes out? If so, it's probably the therocouple. If not, it could be the burner valve. Be sure the caps and rings are correctly seated on the burners and be sure to firmly press the burner knob down to start the flame.
Feb 04, 2010 | Miele 36 in. KM3474 Gas Cooktop
Stove top burners won't light.
Susan, there is no pilot flame on the Spectra models of ranges. However, the possibility that the electronic ignitors have gotten soaked and are shorting out is quite likely.
You should disconnect the power to the oven and remove the burner grates, burner caps, and the burner assembly cores to expose the ignitor posts. Check to see if there is any remaining water there and clean off and dry the ignitors and burners completely, as they might have something on them causing them to short out against the stove top, rather than spark properly, as they should.
Once you've cleaned and replaced the stove top parts, restore power and try to light each burner, one at a time. If none of them spark or light, then you need to check to make sure you haven't tripped a breaker for the stove or a GFCI outlet that the outlet that the stove might be plugged into, somewhere in the Kitchen.
Hope you find this Very Helpful and best regards!
Sep 10, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Dcs gas oven/range, ignitor won't go off after burner or burners are lit
They probably cleaned the stove and in replacing the parts of the burner switched the rings on top of the burner. This happened to me. While they look alike, the round rings, not the flat disks, have to be on the right burner in order for the electron spark to ignite the gas. Good luck.
Oct 29, 2008 | DCS 24-24G-1 Gas Kitchen Range
I have a 4 yr. old Maytag stove model #PGR5715BDQ, the burners all work fine as well as the broiler. The bake ignitor glows red and after a while gas can be smelled but burner will not light. A match will...
I have a Jenn-air stove model # JGS8750BDS in the oven when I call for bake the ignitor come on and glow then the gas come on but the burner want light but I smell the gas what is the problem
Aug 26, 2008 | Kitchen Ranges
Ge spectra gas stove top not lighting
If your top burners are not lighting or will not work, it is possible that the burners have become dirty or wet. Please follow the troubleshooting directions below before calling service:
  1. Turn you burner to the Lite position:
    If you hear clicking or sparking, go to Step 2.
    If you do not, check your circuit breakers. If the circuit breaker is ok, we recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
  2. Clean the burner and electrode:
    First remove the burner grate, cap, and head. Use a needle or paper clip to poke through the holes on the burner head. Re-assemble and try the burner.
    Remove the burner grate, cap, and head. Even if it looks clean, wipe the tip of the electrode with a clean, dry paper towel and PRESS IT DOWN. Re-assemble and try the burner, again.
    Check to see if the burner works, If not, then go to Step 3.
  3. Re-assemble - Make sure that each burner top matches its burner bottom. The burner top will lay flat if put on correctly.
    Check to see if the burner works, If not, then go to Step 4.
  4. The spark igniter is operating properly, but the burner is still not lighting. At this point, we would recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
Aug 15, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
139 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
