Question about Sony Grand WEGA KDF-55XS955 55" Rear Projection HDTV
Sony wega 61 inch (odessa, tx)
My tv was working just fine one evening and i turned it off, then about 30 minutes later I turned it back on and it wouldn't come on. I first thought it was my cable box so I checked it with another tv and it worked just fine. When it did come on I had multi color vertical lines running up and down my tv. That's all I see now I can't even get a sound much less a picture. I cant even see the little box where in the right hand corner where you can see the channels changing. My tv is about 2 years old and never had a problem with it until now.
  • darcy hicks May 11, 2010
    what model is the TV
    you say it is a 61"
    this is posted in the KDF55xs955 area
TV is a Sony WEGA 61" model # KDF-E60A20
Posted on Jul 07, 2008
Sony wega 55 inch tv turns on fine but after one minute tv shuts itself off and comes back on 40 seconds later by itself and this cycle continues - none of the error code lights blink
This kind of problem occurs when lamp becomes weak that means near to end of working life hours but still not dead nor broken.
Replacement of lamp in tv will solve your problem, lamp replacement procedure is easy and would be written in user manual.
Thanks.
Oct 30, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sony wega 28 inch colours wrong, circle on screen
It sounds that there is some magnet near by TV that is affecting picture tube. Please remove any extra speaker or any thing that has strong magnet inside, unplug TV for 20-30 minutes, replug back in, turn it ON, hope that will solve your TV problem.
Thanks.
Nov 16, 2009 | Sony WEGA KV-28HX15 28" TV
Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
shaun
Oct 25, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Turns off and on its own every minute or so.
hi..
This problem will be there in ur tv until you put in a new Lamp. Working fine since then.I Got it through Amazon from www.vanns.com..
thank u
rate me
Aug 23, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
I have a sony grand wega model kf-42we610 I will be watching tv and it will turn off on it's own and then come back on 30-60 seconds later. If I turn it off the light under the power button will blink 5...
Check your lamp cover on the rear it may be loose which will cause the tv to turn off. Also the light under the power light is the lamp indicator. If it is blinking it may be getting ready to fail.
Jan 29, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
TV won't turn on and green light is solid.
My Dad suggested unplugging the television as it might need to reset itself. We unplugged it, let it sit while I cleaned the back with the vacuum cleaner, plugged it back in and it works fine now.
Jan 16, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Tv turns off and then back on
as the anwer to the customer with the short lamp live you must replace the lamp but first make sure your tv fans ar not cloged & replaced if needed other wise your lam life will be reduced dramatically
Nov 16, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Tv cuts off and green light flashes
Yup, it seems a lamp problem can give a blinking green light over the 10 times (1 - 10 times for diagnostic codes), but in my case rather than replace the bulb if it works for a minute then resets with the green light blinking, do what I did.
Take the lamp out and inspect it, it has breather screens top and bottom, if it cant breath because there clogged with dust, clean them, and you can remove the screens, use q-tips and clean the inside. I saved the cost of a lamp and it's working fine!
Jun 27, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sony Grand Wega kdfe60a20
My 55 inch Grand Wega has developed a blue stripe on the right side approximately 1 inch wide going up about 1/3 of the way up.. Please help..
Nov 13, 2007 | Sony Televison & Video
Sony Grand WEGA KDF-55XS955 55" Rear Projection HDTV Logo
140 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
