Question about Ingersoll Rand Air Compressor Start Up Kit for 125 and 13 Hp Gas Powered Compressors
Making air and tripping - Ingersoll Rand Air Compressor Start Up Kit for 125 and 13 Hp Gas Powered Compressors
    Champion:
  • 248 Answers
Web search -ingersal rand - find site for customer care should resolve your problem
Posted on Oct 08, 2010
What is the problem of lP and HP compressor trip immediately after start the machine?
Make sure your ground wire the green wire is not loose and make sure none of your wire are not grounding out tripping the reset button near or around the motor...Make sure your ground wire the green wire is not loose and make sure none of your wire are not grounding out tripping the reset button near or around the motor...
Jun 01, 2016 | Air Tools & Compressors
CIRCUIT BREKER KEEPS TRIPPING
Your house wiring in not capable of powering the unit. Try a different location to plug in. Check the unit to make sure it is not faulty and will trip breakers because it is damaged.
Sep 29, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Unit shuts off on hot days
It may be low on refrigerant. On hotter days, the compressor has to run longer to reach the temperature you have on your thermostat. Have it checked for the proper refrigerant charge and have them test how many amps that the compressor is pulluig as well. With the proper breaker installed, the unit should not be tripping out. Make sure that the breaker that is in there now is actually the proper one for your unit.
Best regrds, --W/D--
Aug 01, 2009 | Dometic Rooftop RV Air Conditioner
The window unit has ran for 3 years never tripped the breaker now it only trips the reset button on the cord does not trip the breaker when i reset it it works great for a while it stormed the night it...
well they do go bad was it eclectic storm it might have fired it. but make sure the unite is clean both front and back if have air compressor blow it out,Ok! hope this helps Paul
Jul 06, 2009 | GE AVX10AD Air Conditioner
MY AIR CONDITIONER TRIPPED ,NOW IT WONT COME BACK
Unplug unit let set till cool then turn on motor has heat trip button that will pop out so it wont over heat, It should pop back in when it cools off. Make sure filter is clean and condenser is not iced over by high humidity. If unit still wont come on check house fuse or breaker it should be on a circuit by it's shelf, flip it off and back on so it is closed all the way.
Jun 27, 2009 | Fedders A6P09S2A Air Conditioner
A/c was wrk.now it keeps tripping cord breaker .control panel not lighting up.when press reset can hear click in control panel but still trip cord breaker.jumped comp. tries to kick on but trips cord...
is it 220 if so check if you 120 on each pole and should be on a dedicated breaker at least 30 amps. make sure you have a good ground.even on 120 you must have a good ground. or the cord breaker is bad. but check all the above. make sure there no lose wires no arcing.
Jun 24, 2009 | Whirlpool ACD052MM Air Conditioner
Will not dry clothes,blows cold air.
need brand.most dryers have thermal fuse that protect the element from going bad.I would first check your breaker and make sure it isnt tripped.a dryer will run but not heat if breaker is tripped.
Mar 10, 2009 | Dryers
RV ROOF TOP AIR CONDITIONER TRIPS BREAKER
Possible low voltage condition would cause that kind of a problem. To small a cord without the ability to carry and maintain the voltage would cause a voltage drop. I would test the voltage supply and make sure it is within 10% of that required for your A/C to operate properly.
Jun 15, 2008 | Heating & Cooling
Coleman RV Rooftop Air conditioner
If the compressor is tripping the breaker, then its 1 of 2 things. First clean the coils and change the air filter. If the coils are dirty and/or the filter is clogged, it will make the compressor overload and the high amp draw will make the breaker trip. If this doesn't solve the problem, you need to check the compressor itself. remove the connections at the compressor, leaving only 3 posts on it. You will need a meter to check for continuity to all 3. They should all have continuity to each other. While there check the wires. Sometimes a burnt wire will come off and arc on something causing the breaker to trip, if you are lucky.
Mar 02, 2008 | Dometic Rooftop RV Air Conditioner
Ingersoll Rand Air Compressor Start Up Kit for 125 and 13 Hp Gas Powered Compressors Logo
Top Ingersoll Rand Air Tools & Compressors Experts
elunsford
Joe Garcia
Joe Garcia
Eddie Tucker
Level 1 Expert
Are you an Ingersoll Rand Air Tool and Compressor Expert? Answer questions, earn points and help others
