Question about Dishwashers
Instructions for the hfd46w homeking dishwasher
My homeking hof605ss suddenly stopped working yesterday, the timer is all that works. Any ideas? Thank you, maria.
download this and then check pages 24 and 25
http://www.waterline.co.uk/pdfmanuals/hof605ss%20280111.pdf
Jul 05, 2015 | Cars & Trucks
Homeking oven hof605ss
Try turning off the circuit for a minute, then set timer again.
Often a little picture/icon of a "baking tray with heat" when timer is passing power on to the thermostat.
Also, those timers fail often enough, is the oven brand new (or recent blackout)?
Oct 17, 2013 | Ovens
Homeking zeros are flashing and oven not working
the power in your house unplug your oven then plug back in.
Oct 16, 2012 | Kenmore Ovens
Baumatic Homeking HWM 1005W washing machine does not always want to spin.
The most common problem that I have come across is that the pump outlet is blocked or the pump is jammed.
You should have instructions on pump clearing but if not, there should be a hatch in the front of the machine at floor level. Open this and there should be a small hose with a tap that allows you to empty the water. When all the water has gone (be patient - it is a small pipe) unscrew the stopper and shine a torch down the pipe.
If there is any obstruction, remove it with something long enough to reach the pump blade and check that the pump rotates.
Re-assmble plug and replace cover.
Jun 04, 2012 | Washing Machines
No instruction manual
The instructions are available in
http://www.fagor.com.au/manuals/dishwashing/versionw/FI-48W,%20FI-64W.pdf
Hope this helps. Please post a comment to say if you found this useful or not.
Apr 20, 2010 | Fagor 24 in. FI-48W Dishwasher
Hi, my mum has just had a homeking frost free fridge freezer delivered and the delivery driver has instructed her not to switch on the appliance for up to 6 hours due to possible gas emissions. Please...
this does not sound right to me i have never heard of that kind of problem unless the fridge has been laid on it side for a long period of time then you should only have to stand it up for about two hours before plugging in to use it.there should be no reason why you can not use it now.i hope this helps good luck.
Jan 22, 2010 | Refrigerators
I have a homeking fridge freezer and there is a really bad smell coming from the fridge which is not because of food. i have emptied the fridge and thoroughly cleaned the fridge but the smell is still...
Hi, i have the same problem with my Homeking fridge. Because it is a frost free firdge, there is a little resevoir at the back, with a small little tube leading from the base of the fridge into it. There are 2 screws holding it in place. Unscrew these but keep the resevoir firmly in place as the nasty parmesan-type smell is actually stagnant water and you really really dont want to spill it. Empty it and then what i did was bleach and anitbacterialise the resevoir tray and the little tube thing. Though I had the problem solved but now it is doing it again less than 2 months after this, so I'm going to contact the people who sold it to me. This is how you get rid of the smell though!!
Good luck
Laura
Aug 14, 2008 | Refrigerators
Instruction book
need the manual for the belling idw604 dishwasher
Jul 04, 2007 | Belling 24 in. IDW602 Built-in Dishwasher
Dishwashers Logo
85 people viewed this question
Top Dishwashers Experts
Owen Barnes
