Question about Yard Machines 155 Torque Briggs Stratton Riding Lawn Mower (NonCARB Compliant) 13AM772F000
My yard machine wont start, i have spark, fuel, and compression. yes there is gas in it. has oil. starter cranks and I pulled the carb off and cleaned the float and everything. the starter almost looks like its not cranking hard enough, could this be a solenoid problem? im not sure what my next step is. can someone help?
    Scholar:
  • 150 Answers
Probably not the solenoid they usually work or they don't. Slow cranking could be due to weak battery or bad connections, check those. If all is ok starter motor could be bad. Always check simplest first.
Posted on Oct 06, 2010
  • nick karels Oct 07, 2010
    is it possible that the starter will turn the engine but not enough to start it?
  • wayne baldwin Oct 07, 2010
    Yes it is possible, but if its turning that slow it would be very noticeable. If you have amp meter you can check and see how many amps starter is drawing. You can also use a jumper cable and jump from positive post on battery to the connection on the starter motor, with the key in the on position it should start. See if it turns faster, if it does the problem is elsewhere. Sure battery is ok?
I got a Honda mantis rototiller,gx25 model 4 stroke,its got a new carb../ plug / gas / oil / fuel filter / ignition switch, its getting gas to carb/ getting spark but it wont start up .....help me..
If you have proper timing, compression, gas and a spark, the engine should fire/run.
Have you tried a spritz of starter fluid to see if it fires ?
The flywheel could have sheared the key and affected timing.
About the last thing I can think of is valve adjustment, specifically the intake valve, although I think it would be difficult to pull the crank rope if that's the problem.
Feb 13, 2018 | Honda Garden
I have a John Deere 425 riding tractor that sounds like it wants to start but wont actually fire
Is the engine being cranked by the starter but it won't fire? You say you're getting spark? You need air, fuel, spark, and compression to start so...
Pull the air filter and see if it is blocked.
Inspect the choke plate to see if it is working properly.
Are the plugs getting wet when you try to start?
Take the gas cap off the fuel tank and try to start.
Take the plugs out and move the wires where they can't ground. Stick your finger (thumb) in one plug hole and with the throttle wide open and no choke crank the engine. Is there compression? Try the other plug hole. A compression tester would be better than a finger or thumb.
No compression can be popped push rods or a cam problem among other things.
Aug 26, 2017 | John Deere Garden
Managemylife.com sears
You need three things. Spark, compression and fuel. Pull the spark plug and make sure it is not fouled and you have spark when cranking. Put your finger over the spark plug hole and feel for compression while pulling the engine over. There is a reed valve between carb and block that clogs and prevents fuel from getting to cylinder.
Aug 15, 2014 | Craftsman 27cc 2 Cycle Crank Straight...
Swisher 60" pull behind mower with 14.5 briggs engine. good spark and the starter will crank just fine. If I prime the carb with a little gas it will start imediately but wont continue. Any ideas..
Hi Andy, the carby will need to be removed and all jets cleaned out with compressed air. Basically its not getting enough fuel through the carby to keep running. Regards Phil.
Nov 28, 2012 | Swisher T14560 T - 60" Trailmower with 14...
Yard Machines 13.5 HP riding mower wont start. It turns over fast, has good spark, good gas, good filter, clean carb, just wont fire. It ran fine yesterday and i parked it last night and tried to fire it...
Hi, check that the choke is operating and make sure the plug is wet after cranking. If so replace the sparkplug as it may be breaking down under compression. Also make sure it has compression ad it may have a stuck valve. regards Phil
Jun 19, 2012 | Yard Machines 155 Torque Briggs Stratton...
My MTD Yard machines riding mower won't start.
Probably dead gas from sitting too long. Dump it out & put in fresh gas.Could have moisture in it. Pull out spark plug & crank it over several times after putting gas & let it sit a while to dry out or blow it out with compressed air. It should go.
Apr 04, 2012 | Mtd Garden
Handle on pull cord came off and cord went inside,
pull spark plug then pull cord see if fluid comrs out.if so check oil level,if over full see if it smells like gas if so you have a bad float in carb or dirt stuck in needle and seat in carb if all is good could have sheered flywheel key or if over head valve engine(has valve cover) valves may need to be adj or compression release mechanism in side engine broke. todays engines have very high compression and will not turn over without release. hupe this helpl
Aug 01, 2010 | Mtd Products Yard Machines 158CC Tiller
Poulan 6.75 Lawn mower will not start
Remove spark plug, clean and dry. Replace plug. Remove air filter. Spray WD-40 into carb opening; one second blast. Turn over engine, (pull handle). Engine should start briefly and run for 3 seconds.  If not, you are not getting spark to spark plug. If engine starts, you have a dirty carb and you can buy a rebuild kit from manufacture.
May 02, 2009 | Poulan Pro " Pro" Self Propelled Mower
1966 mustang engine cranks but wont start
Guide to starting a dead horse!
1- Spray a little starter fluid down the carbuerator. If it tries to fire, your timing and ignition is probably OK. This could indicate a carb or fuel pump problem.
2- If it doesn't fire, check out the points, condenser, coil, distributor cap and rotor. Look for condensation inside the cap. Check that the high tension wire from the coil to distributor is in good shape and not touching the engine or any brackets,etc.
3- Verify that your timing is correct. You may have a timing train problem (Worn or broken).
4- The distributor may have come loose and changed positions. Check for proper timing.
5- It may be a compression problem. If it has set long enough for the oil that coats the cylinder walls to drain down, you won't have enough compression to allow firing. Check your compression and if this seems to be the case, remove the spark plugs and squirt a little Marvel Mystery oil, or similar light weight oil into each cylinder. When it starts, it will smoke for a few minutes, but that will go away.
Hope this helps and if not, get back to me.
Have a super day!
Ron
Jan 11, 2009 | 1966 Ford Mustang
Yard Machines 155 Torque Briggs  Stratton Riding Lawn Mower (NonCARB Compliant) 13AM772F000 Logo
652 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
