Question about MTX Thunder 4500 T4510-04 Car Subwoofer
I got a mtx thunder 4500 12 and i only want to one for now but i am thinking about getting another down the road i was givin the speaker and dont know much about it i found a cheap amp at walmart and its two channel i need to know what i need to know if i can bridge the speaker for now without blowing it
3 Suggested Answers
tech48
  • 624 Answers
SOURCE: i need to no how
I hesitate to answer this question for fear that you will not like the answer even if it is the truth. I have received a bad rating from a couple of people in the past just because the right answer was not what they wanted to hear.
This is a mono sub-woofer amp, which means that it is already bridged internally. You only have one speaker output in this amp, that means that the amp circuit is bridged inside, it is not split into two channels.
To bridge any output, it requires 2 channels, otherwise there is nothing to bridge.
I have been repairing car amplifiers for over 18 years, and I promise you that there is no way to bridge a single channel amp. Bridging means to convert 2 channels into 1 channel. If all you have is one channel, then there is nothing left to bridge.
I hope this explains it for you, if you have any other questions feel free to post them here and I will answer as soon as possible.
And please do not punish me with a bad rating if you do not like the answer, it is the correct answer, and sometimes the right answer is not always what we want to hear, but it does not make it wrong.
Dave
Posted on Nov 09, 2008
  • 32 Answers
SOURCE: 2 MTX Thunder Problem.. Bridging?
Is there a option on the chanels that say ''Bridged''? If so, you can hook the subs up in parellel or series to get different ohm loads. Usually the lower ohms, the more power amp puts out. Those subs can handle 225 watts RMS whitch means the power it can handle constantly. If the amp gives more than 225 watts RMs, you could be at risk of blowing the sub. If you could give me the model # of the amp, I can be of more help.
Posted on Feb 12, 2010
How do I Bridge MTX Thunder 404 400 watts into one channel
The mtx thunder is a 4 channel amp. 4 channels can't be bridged to 1 speaker. You can only use one side of that amp to bridge your speaker. Unfortunately your now only using half your amp.
Nov 25, 2016 | MTX Car Audio & Video
I have 2 different subs in one box, a 12" MTX thunder and a 12" Kicker CVR. the kicker is a dual voice coil while the MTX I dont believe is. Can I use one amp for this set up? And how would it be wired?
im guessing both speakers are 4 ohms ..mtx 4ohms and kicker dual 4ohms..now if your amp can go down to 1 ohm wiring the kicker dual coils in parallel (2ohms) and the mtx connected together (4ohms) should leave you with a final impedance between 1 and 2 ohms ...i suggest you use one or get another
Oct 08, 2013 | MTX Car Audio & Video
8 INCH MTX ROAD THUNDER SUBWOOFER WON'T WORK NO SOUND NO NOTHING
has it ever worked, if so did you ever use it in the cold because in the cold it is possible for the wiring inside the speaker to crack and break
Oct 29, 2012 | Velodyne CT-80 Subwoofer
I just bought 2 12 inch mtx thunder tc512 to replace my old school mtx blue thunders, everything worked great, but when i hooked up the new 12s i get nothing, zero, zip, nadda, there is nothing wrong
use a d cell battery and touch + of speaker to + of battery and hold it by doin the same with the -'s too if move they work if not there junk
Sep 09, 2012 | MTX Car Audio & Video
Rotten foam rubbers
You can have "The Speaker Factory" re cone them. Call for an est.first Generally gonna be less expensive to replace.
Jun 25, 2009 | MTX Road Thunder RT-1240 Car Subwoofer
MTX Thunder problem
Make sure that your connection at the battery is still good-sometimes the wire corrodes up front when your system is installed for a long time-so check that out and of course the fuse that you installed a foot away from the battery so that you dont burn your vehicle down if a short occurs somewhere down the line
Jun 03, 2009 | MTX Thunder 421D Car Audio Amplifier
MTX Thunder 4500 T4510-04 Car Subwoofer Logo
Top MTX Car Audio & Video Experts
hoyzee1
Mark Skinner
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
