Question about Microwave Ovens
The start button on my sharp R249 microwave doesnt work, all other buttons work fine apart from this
SparkGap
  • 363 Answers
SOURCE: microwave locked
Did you try removing the power for a minute or two?
Posted on Nov 04, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: Sharp R-510AK Microwave Oven Fuse Blows
If it went dead almost immediately after pressing the Start pad, that\'s usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that\'s usually a failing high-voltage transformer.
Here are some links you or a friend can use for test help, but read their safety warnings first:
http://www.microtechfactoryservice.com/cap_test.html
http://www.microtechfactoryservice.com/diode.html
http://www.microtechfactoryservice.com/mag_test.html
http://www.microtechfactoryservice.com/xformer.html
You can probably find an exploded view by entering your FULL model number here: http://www3.sears.com (the 3 is correct)
You can order Sharp parts from Sears or from Tritronics at http://www.wehaveparts.com
We\'re happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jan 13, 2008
Illeagle
  • 525 Answers
SOURCE: Panasonic microwave start button
You may have a sticky door switch. Try a simple "slamming" of the door, don't over do it, just a little harder than normal. This may help pop the plunger in the switch back up. The switch could have also become loose and moved out of its adjustment.
If this does not help, a technician should save you time and money with this sometimes perplexing problem.
Posted on May 24, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave won't work. The time is frozen, buttons dont work.
I have over 20 years experience with microwaves and over 25 with all other electronics, and I'll have to say it sounds to me also like some kind of power surge "scrambling" its "brains".
Or possibly its power is being interrupted for a fraction of a second and having the same effect.
A microwave should really be on its own circuit breaker.
Microwave ovens, refrigerators, toasters, and electric ovens are very high current devices.
There are power line (mains) surges created when they cycle on and off.
If the microwave can't be on its own breaker, then maybe you can try a power strip with a surge suppressor, or better yet, a power strip with a surge suppressor and a built-in noise filter.
Or it may be that there is a subtle bad connection on the circuit board or at the fuse holder.
These kinds of problems are difficult to diagnose, and even harder to do remotely. Especially since I'm in the US! *grin*
I would strongly suggest that if you can't cure this with a surge strip or similar, please carefully document when and how it fails, then while it is in a failed state, open the door (to keep it from starting on its own) and call Sharp customer service at 1300 13 50 22.
Or you could visit here and click on Service Centre Location search.
You should have a one year warranty, so you should get in touch with a Sharp-authorized repair center.
An over the range type will include home visits in the warranty, but not if it's a counter top model.
You'd have to take that type to the shop yourself, and of course that would mean unplugging it, which would reset it, and the repairman may never see if fail.
If you wait too long, your warranty will be expired, so I'd get in touch with the shop.
Good luck.
Posted on Dec 02, 2008
  • 140 Answers
SOURCE: Ge microwave model JVM1190WY buttons work but does not cook
The problem you are having with your microwave is a common one. Not heating is a problem that can be caused by three things. I'll list the most common solution first, the magnetron that actually does the heating is what is making that noise and has gone bad. It is possible for you to also have a bad high voltage diode that has opened up, solution two, or solution three is the high voltage capacitor is not working properly as well. From my experience with microwaves I am positive that it is your magnetron that is bad. If you are not do it yourselfer you'll need to take it to a repair shop to replace. However, if you know how to use a screwdriver and can unplug a couple of wires with spade terminals on them, then you can take it off yourself, find another one and replace it the same way you took it off. The magnetron sits behind the control panel of your microwave but on top. It has cooling fins on it and has 2 terminals maybe three depending and make and model that plug into it. It has 4 screws that are easy to get to that actually holds it in place. If you do not have a good local source like an electronic parts supply place then you can find the right magnetron at www.mwoparts.com. Be sure you always unplug the microwave before touching or trying to take the he cover off and then when you take the magnetron off also.Good luck and God bless.
Posted on Feb 11, 2009
Why Kenmore microwave oven (model 80089700) start/enter button not working while all other buttons works fine?
Safety system locking out the start switch. Door not closed, mode and timer not set etc.
Apr 10, 2017 | Kenmore Microwave Ovens
Microwave wont work
Call the manufacturer about resetting the electronics. If not possible the board needs to be replaced if the price is right.
check here Search Over 2 1 Million Appliance Parts
Sep 08, 2017 | Sharp Microwave Ovens
Start button does not work
If this is a Sharp R1500-series microwave (you didn't mention the model number but posted under that) then the most likely problems are:
- broken Start button see here
- bad door switch see here
- bad keypad or other problem see here
The service manual is here.
Mar 06, 2011 | Sharp R-1510 Microwave Oven
Diplay doesnt work r1450 sharp microwave
I have the same problem. I am checking with Sharp for a part and the diagram on how to take the panel apart.
May 09, 2010 | Sharp R-1405 / R-140 Microwave Oven
EM-G5596V Sanyo Microwave - Start button does not work
MY KIDS WERE USING THE SHARP MICROWAVE R-9H94B FOR A TIMER WITH NO FOOD IN IT. IT NOW DOES NOT WORK AT ALL. IS THERE A FUSE OR A QUICK FIX TO THIS?
Jan 01, 2010 | Sanyo Microwave Ovens
Microwave will not start
your safety door relay is way out of adjustment
Oct 01, 2009 | Sharp R-403HW Microwave Oven
Sharp R-1510 Start Button Not Working
This may not solve your problem, but on my Sharp R315J microwave, the little plastic pin that pushes forward on the inside of the start button, had broken off and it wouldn't start. The Minute Plus button would start the microwave, so I knew the microwave worked, so I tried to find a piece of plastic that I could glue into the start button hole, because the part doesn't exist and you have to buy the whole door for $100 plus shipping. Nothing I could find was small enough, so I started looking for a new microwave.
While ouside doing lawn work I noticed a small bird tail feather and the end looked to be the perfect size. I snipped off the pointed end and then up about 3/8" to make a little rod to replace the plastic one that broke. It fit perfectly!!! I didn't even have to glue the inside end, it stays put even after repeated door opens. This is sturdy material and looks to last a long time. When it wears out, I have a cat, there's always a few feathers around. I hope this saves someone else a hundred bucks, like it did me.
Mar 09, 2009 | Sharp R-1510 Microwave Oven
Unlocking child lock on the sharp microwave model R316FSC
The Sharp Microwave/Convection oven I have says to touch the Custom Help button, the number "1", then touch the Start Button. To turn off the child lock, press the Stop button.
Or just unplug it, wait 1 minute, and plug in.
Jan 06, 2009 | Sharp R-308J Microwave Oven
Sharp Carousel Microwave w/ESP sensor
when i touch the panel there are no response
Nov 09, 2008 | Sharp Microwave Ovens
Microwave Ovens Logo
52 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
