Question about Logitech Cordless Desktop EX110
Logitech wireless keyboard doesn't respond
I tried your solution but my keyboard still doesn't respond. Nothing happens when I type--the cursor remains stationary. The mouse works, though.
  • ramaswami May 28, 2008
    This didn't work either, so I guess the keyboard is defective. Thanks so much for your help, though.
  • thargor Jun 30, 2008
    Whenever I restart my computer, the keyboard screws up. I can use the function keys on the side (I'm using a Logitech EX110 keyboard) but no other keys will work leaving me unable to type.
    This problem has arisen before, however last time i was able to fix it by pressing the connect button on the keyboard and receiver repeatedly. As of yet this has not worked again. Note that the keyboard is connected.
    Any ideas would be appreciated.
    Cheers
    President:
  • 2,712 Answers
Ok, try this. Remove the batteries from the keyboard, just type anything randomly for about a minute on the k/b keys (doesnt have to make sense) Just press as many keys as you can. This will discharge the capacitors and reset the k/b. Reinsert the batteries, making sure they are in the correct alignment (try to use new batteries if you can) and connect to reciever. Press the connect button on receiver first, and then press the connect button under the keyboard.
If that still doesn't work, then your keyboard is most likely defective. Make sure you have reinstalled the k/b software first from Logitech..
Posted on May 28, 2008
  • Swilin Sampson
    Swilin Sampson Jun 15, 2008
    Kindly close this thread with a “Fixya” rating if you have been able to
    fix the problem, so that I can remove it from my work queue.
    If the issue is not resolved, please post back with latest developments, what
    steps you took, etc. and I will assist you further as best I can.
    Thank you for understanding,
    IrishDruid
I also had a non-responsive keyboard that worked for a couple of days after installing. I purchased the unit over a year ago due to a great price. Since it was most likely out of warrantee and new batteries did not help, I open the unit and found a cracked solder connection on the positive battery terminal. I re-soldered the connection and it now works great.
Posted on Jun 06, 2008
Mouse buttons spontaneously click themselves
I'm afraid that keyboards and mice don't like tea much at all. You can pick up keyboards and mice cheap enough and to be honest they are just not worth repairing. Even a tin of Servisol Video 40, which you can spray on the contacts to clean them will cost you as much as a mouse would!
Mar 12, 2017 | Logitech Cordless Mice 910001822 M510...
My logitect wireless keyboard will not work.
HI,
Please reinstall the drivers of your keyboard.This should fix the problem.
Sep 17, 2008 | Logitech LX 710 Keyboard/Mouse
The keyboard shows a connection but nothing happens on screen.
Delete device. reinstall. There may be a setting in the device manager that lets you use only one input method. So if the original keyboard will over ride? All this guess work would be eliminated if you give the os pc specs. If it's an external keyboard on a desktop then you may need to disconnect it? A laptop lets you use more than one input keyboard or wifi mini etc.
Oct 17, 2017 | FAVI Entertainment Mini Wireless Keyboard...
Setting clock and date on logitech mx3200 wireless keyboard - need instructions
To adjust the LCD's time and date:
  1. Make sure that the time and date are shown on the LCD. If necessary, press (FN + F9) until the time and date are shown on LCD.
  2. Press (FN + F10). You are now in 'Set mode' (you can exit this at any time by pressing the Esckey).
  3. Set the correct hour by either typing the numbers on the numeric pad or using the cursor up and down keys, followed by Tab or Enter.
  4. Set the correct minutes by either typing the numbers or using the cursor up and down keys, followed by Tab or Enter.
  5. Choose either 12-hour clock or 24-hour clock by pressing the cursor up or down keys to switch between the options. Then press Tab or Enter.
  6. Set the correct month either by typing the numbers or using the cursor up and down keys, followed by Tab or Enter.
  7. Set the correct day either by typing the numbers or using the cursor up and down keys, followed by Tab or Enter.
The time and date on the LCD should now be displayed properly.
Aug 18, 2009 | Logitech Computers & Internet
Keyboard isn't responding but mouse is
open the Logitech utility and try to reconnect the keyboard and pair it with the mouse. if it doesnt work uninstall/reinstall the software for your wireless mouse/keyboard.
May 27, 2009 | Logitech Wireless Access Duo Optical...
Wireless keyboard won't work
Check the cabling from transmitter unit to the back of your pc, unplug and plug the cable back in, perhaps to another USB port. When you do the connect button I have always down the transmitter first and then the device, like they keyboard or mouse. Make sure the batteries you used work. If you have another computer you could try it as a test.
Jan 17, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Need instructions for change time on Logitech MX3200 wireless keyboard
Mar 17, 2008 | Logitech Wireless Access Duo Optical...
Set correct time on Logitech MX 3200 wireless keyboard
Cordless Desktop MXTM 3200 Laser
Dec 31, 2007 | Logitech Wireless Access Duo Optical...
Keyboard not responding
The keyboard has probably died. (It happens often). Here's a great inexpensive combo to replace your current one. https://www.amazon.com/Logitech-MK270-Wireless-Keyboard-Mouse/dp/B00BP5KOPA/ref=sr_1_1?ie=UTF8&qid=1491364851&sr=8-1&keywords=Logitech-MK270-Wireless-Keyboard-Mouse
Apr 03, 2017 | Dell Wireless Keyboard Optical Mouse w0147
Logitech Cordless Desktop EX110 Logo
3,834 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
