Question about Dream Maker Spas Dream Maker Ez Spa Hot Tub
I have a fantasy dreammaker spa that plugs into a regular 120v outlet. At times the spa will run properly for weeks. Then it will constantly trip the switch on the spas plug. When I reset and test it works fine and starts back up. Sometimes it will run for a weak. Currently it is running for 1 to 3 minutes then shuts off. Any advice or suggestions would be appreciated
  • 990 Answers
This is a GFCI and will trip at the least bit of water at the plug or at the wiring inside the spa controls. Just go through the system and make sure all is dry. Use a hair dryer in the outlet and on the controls and wiring. If you still have problems you may need to call an electrician.
Posted on Oct 07, 2010
How to I increase the temperature to 101 on the drreammaker spa fantasy model?
This may be a little late as you may have already found the answer. But most "Fantasy" spas have "Balboa" control system. They are either a heat control knob, or Up/Down arrows on the spa side control system.
If you have the know & it is all the way turned to max position, and still not hot enough, then you may well have a faulty "Temperature Sensor". Get a replacement from your local DreamMaker dealership. Easy to replace.
Dec 20, 2012 | Dream Maker Spas Dream Maker Ez Spa Hot...
My dreammaker X400 just stopped working no power. The outlet that its plugged into works fine. What could be the problem?
check to GFI on the cord where it plugs in, check for any pop-out breakers at the spa pack. If you cannot find something simple, you may have a problem with the heater or other components.
Nov 08, 2010 | Pool & Spa
Breaker on the end of spa plug-in trips overnight. I can unplug it and plug back in, tub runs to it's 100 degree default settings. Will stay on and maintain all day, but overnight I will find the tub off...
I have had a few troublesome units over the year that did as you describe due to 'dew' overnight collecting around the tub and the increased moiture sent the motor of the circ pump "over the edge" iinto a grounded state. A leaking pump seal was adding to the problem. Once the seal leak along with the dew got high enough the GFI would sense the grounded condition and trip. Fixing the pump seal and drying/cleaning the motor fixed the problem every time. If you find any other leak sources around the pump you will need to fix them as well.
Oct 12, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
We have a dreammaker spa, how do we drain it? the model is Fantasy
The Fantasy has a drain located in the toekick of the spa. You have to first remove the drain cap, attach a hose if you wish, spin the outer black ring counter clockwise to start the water flow, then pull the outer ring out away from the tub to increase the drain to full flow.
I understand that a screw driver is often needed to pull the outer ring out to achieve full flow. Therefore, I suggest another method. Take a garden hose and place it in front of the jet while the spa jets are on. This will force water flow thru the hose and prime the hose. Once you see water running from the other end of the hose, drop the hose in front of the spa jet into the footwell and as long as the loose end is lower than the end in the footwell, a siphon will drain the spa as fast as the spa drain will. Remember to turn off electric to the spa once you have established a siphon. You may have to bucket the last bit of water in the footwell. Goodluck.
Oct 31, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
New set up
Do you have power at outlet? If yes, check for 120v at control pack (follow cord to terminal board ). If no power at terminals and gfci on cord won't reset then power cord is defective. Replace
Apr 13, 2009 | Qca Spas Dream Series Dream Master Hot Tub...
Dream Maker Spas Dream Maker Ez Spa Hot Tub Logo
521 people viewed this question
Top Dream Maker Spas Pool & Spa Experts
Ian Kime
Ian Kime
john h
Craig Butler
Craig Butler
Are you a Dream Maker Spas Pool and Spa Expert? Answer questions, earn points and help others
