Question about Xerox FaxCentre F110 Plain Paper Laser
Black line on the page when printing fax or making copies
  • Xerox Contributor
  • 185 Answers
The lines may come from the toner/ drum cartridge. Try stopping the job by opening a cover, and see if the defect exists before it reaches the fuser.
The fuser for the F110 is PN 126N00235
The toner/ drum unit is 013R00605 (several alternate numbers exist)
And it could also be the transfer roller 022N02107
Hope that helps
Whit
Item, Inc.
Posted on Oct 06, 2010
2 Suggested Answers
  • 105 Answers
SOURCE: Brother Intellifax 1" black line on right in send & copy modes
lift up your document feeder and check for something on the **** glass
Posted on Nov 16, 2009
Testimonial: "Good call! The laser light bar does not light up all the way across its length. Looks like a service call. Thanks for the assistance."
Black line on copy and fax functions
Clean the paper path for the scan/fax portion. The original goes in and as the document is "read" a spot of dirt is causing the black line down the page because it is picked up in the copy area.
Dec 16, 2011 | Dell 948 All-In-One InkJet Printer
When I receive a fax, it prints out perfectly. When I make a copy or scan to fax/email, the page has multiple black lines running down the length of the page. I have recently replaced the drum and the...
As the fax receives and prints incoming faxes ok then the print engine is working ok. the fact that the problem arises when copying or scanning indicates the problem is with the scanner or software that controls the scanner.
First clean both scanner glasses and the white area (white reference) under the doc feeder. When you are happy all is clean, follow the following instructions:
Press menu, * 2864 within 3 seconds. the display will show "Maintenance"
now press 55. The scanner will initialise and go back to "Maintenance"
now press 99 and the machine will go back to the default screen showing date and time.
Now do a copy. if you still have the lines or its all black then you will need a new contact image sensor. If all is well then that was a good cheap repair.
May 26, 2011 | Brother MFC-7340 All-In-One Laser Printer
Copier, Printer black streaks on copy or all black page
Hello sir; Either drum cleaning blade or drum cartridge needto replace.
Aug 20, 2009 | Brother Office Equipment & Supplies
Won't print or copy black. won't send fax but am hooked up to a digital phone line with clear. Prints out fax report in black. test page doesn't print black ink.
for fax if u have a dsl line,u should have a dsl splitter,if analog line,its fine. u also need to claen printhead of printer and upgrade the firmware of printer,issue will be solved i tried it and it worked on my ESP-9
Aug 18, 2009 | Office Equipment & Supplies
When copying or printing a fax, a vertical black line 2-3 mm line
try cleaning the rollers with water in the feeder at the top check the glass too too see if it's dirty
Jun 27, 2009 | HP Officejet 6310 All-In-One InkJet...
When receiving a fax I get either big black plotches all over the page or thick black vertical lines running the whole length of the page to a point where I can no longer make out any of the information...
Try making a copy of something or printing a transmission report or journal from the "reports" menu. If the same problem is apparent on these printouts, then your drum unit or toner cartridge need to be replaced
May 06, 2009 | Brother IntelliFAX 4100 Laser Fax
Printer is printing black lines across all print jobs
Every print job, copy, and fax have the solid black line across the pages. I have changed the drum and the cartridge and even tried cleaning mode. Please help!!! I have a HP Laser Jet 2840 All in One
Mar 24, 2009 | Office Equipment & Supplies
Fax machine sending black pages
Make a copy. How do the copies look? You may have a bad LED assembly.
Also press Function 64 set, Are the prints black?
Nov 06, 2008 | Panasonic PANAFAX UF-6000 Fax
Black pages when making a copy or printing something
Have you tried both drum and toner supplies? cause it sounds like a drum fault, if you have tried a new drum and toner, and it is doing it when printing internal reports, receiving fax's and copying then you have a tecnical issue to do with charge and this would likely render machine unecomical to repair (unless you can find a bad contact with drum on machine). If it receives faxs clearly but copys black then it is different issue (ie optics).
Oct 16, 2007 | Brother IntelliFax-2820 Laser Fax
Xerox FaxCentre F110 Plain Paper Laser Logo
138 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
