Question about Microsoft Xbox 360 Console
Need help I have ip conflicts how do i fix that?
    Sergeant:
    Champion:
  • 427 Answers
You will either need to forward ports on your router, or you will need to make sure that your xbox 360 is properly connected to your router. For more assistance, call 1800-4MY-XBOX.
Posted on May 28, 2008
Tip
IP Conflicts in a work place
An IP address conflict occurs when two computers on a LAN or the Internet have been assigned the same IP. IP conflicts between two computers normally render either one or both of them unusable for network operations.
How IP Address Conflicts Happen
Two computers can acquire conflicting IP addresses in any of several ways:
· A system administrator assigns two computers on the LAN the same Static IP Address.
· A system administrator assigns a computer a static IP address within the local network's DHCP range (dynamic IP range), and the same address is automatically assigned by the LAN DHCP server.
· A malfunction in the network's DHCP server allows the same dynamic address to automatically be assigned to multiple computers.
· An ISP accidentally assigns two customers the same IP address (either statically or dynamically).
· A mobile computer is put into standby / hibernate mode and then awakened later.
Note that other forms of IP conflicts can also occur on a network. For example, one computer may experience an IP address conflict with itself if that computer is configured with multiple Network Adapters. System administrators may also create IP conflicts by accidentally connecting two ports of a network switch or router to each other.
Recognizing IP Address Conflicts
On most Microsoft Windows computers, if you attempt to set a fixed (static) IP address that is already active on the local network, you will receive the following pop-up error message:
The static IP address that was just configured is already in use on the network. Please reconfigure a different IP address.
On newer Microsoft Windows computers having dynamic IP conflicts, you should receive a balloon error message in the Taskbar as soon as the operating system detects the issue:
There is an IP address conflict with another system on the network.
Sometimes, especially on older Windows computers, a message similar to the following may instead appear in a pop-up window:
The system has detected a conflict for IP address...
On Mac or Linux computers, a similar message will normally appear on screen.
Resolving IP Address Conflicts
Try the following remedies for IP conflicts:
1. For networks where IP addresses are fixed (statically assigned), ensure each local host is configured with a unique IP address.
2. If your computer has a dynamically assigned address, releasing and renewing its IP address can workaround IP address conflicts.
3. If your home router is believed to have a faulty DHCP server causing IP conflicts on the home network, upgrading the router firmware may resolve this problem.
on Nov 24, 2010 | Computers & Internet
How to fix Ip address conflict problem?
This is due to same IP address has detected in the same network. Change your local PCs IP address by clicking Settings > Network Connections> Local Area Connections. Right click on Local area connections and Properties > Select Internet Protocol [TCP/IP] > properties > Use following IP address enter new IP address (eg; 192.168.0.250). Let me know for further assistance
Feb 17, 2012 | Computers & Internet
I have a message that say Ip address conflict, what can I do
Ps3 throws my xbox 360 off line. why
Could be an IP conflict.
For example say on your network the xbox is 192.168.0.12, then if your ps3 has the same IP address, when you turn it on it makes an IP conflict over your network and one has to go, and usually the newer powered on device kicks off the original item.
Quick way to fix this if it is indeed an IP issue is to manually change one of the IP addresses, from the PS3 or Xbox360. its more easy to manually set the IP of the xbox360 then it is the ps3.
Jan 02, 2010 | Sony Playstation 3 (PS3) Console
THERE IS AN IP ADDRESS CONFLICT WITH ANITHER
Identify the peripheral conflicting with the router and change the network address on one of the two. Their setup programs should give you the possibility to do so. The address should look like: 192.168.2.x
x ranging from 0 to 9
Aug 02, 2009 | NetGear WGT624 Wireless Router
How can i fix an ip adress conflict?
If you Router has DHCP running then please check that no any computer which you conect has Static Ip configured.
There are few viruses around as well which cause the ip conflicts in the networks...
Nov 27, 2008 | D-Link AirPlus Xtreme G DWL-2100AP...
IP Conflict
use static ip higher than the dhcp range so dhcp doesnt assign it to other pc causing ip conflict .. rename computers on network. imaging can cause this issue as the master image can have same comp name assigning it same ip.
Jun 06, 2008 | ParkerVision Signal Max USB1500 1 Mile USB...
Need Driver: Aopen Ethernet mini Hub AOH-528
Hi joshua,
1.For a hub you don't need any driver.Just simply plug anything onto it.
2.I think the error message being throw by you computer was
"conflicting IP" not "conflicting ISP" .So if incase of "conflicting IP" that mean you have more than 1 computer using same IP number.So the solution is to change the IP number so that they don't get conflict.
3.make sure you use the same group of IP.like if your first computer is 192.168.0.1 then your second should be 192.168.0.2 and so on...3,.4.,5.....
Bye,takecare.
Apr 11, 2008 | Computers & Internet
Microsoft Xbox 360 Console Logo
22 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Mike Neath
Mike Neath
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
