Question about Dayton Gas Furnace Heater
I have a Dayton model 3E470b NG furnice I need to know at what temperature the limit switch should shut down the furnace.
  • 455 Answers
At 180*f-200*f high limit saftey
Posted on Oct 07, 2010
Testimonial: "Thanks!"
Got a dayton furnace cuts on and off immediately think limit switch is bad can it be bypassed
stay away from the furnace and call for service,you will burn the house down,,who would try to bypass something that makes a furnace work right??
Jun 05, 2015 | Dayton Heating & Cooling
Dayton
You will need a convestion kit try national energy they are on line they could well do the kit you need .
Dec 21, 2011 | Dayton Gas Furnace Heater
My furnace fan will not shut down, and it is cold air
Check on your thermostat to see if the fan switch is set to on. Not knowing the model of the furnace it can be difficult to give more detailed instructions.
Jan 10, 2011 | Dayton Gas Furnace Heater
My Dayton NG furnace runs a couple minutes thens shuts down There is a fault code #4 after the burner shuts down Appears to be 3 limit switches, Can I checkeck these with an ohmeter as it is running to...
To check them you should power the unit down, then using your volt ohm meter check the limits. These limits should read normally closed or dead short, if it is open that is your culprit. If it happens to be one of the limits in or around the burner chamber please inspect the(burner chamber) heat exchanger for cracks or pin holes as this would leave carbon monoxide to be released in to your home.These limits are for over heating and that occurs once you have holes in the heat exchanger letting hot gasses escape out to the blower area of your furnace.
Jan 09, 2011 | Dayton Gas Furnace Heater
My furnace light is telling me that the limit swich is open so what can I do it is starting to get cold in here. Help please?
on most furnaces the limit switch will reset its self.not knowing which furnace you have i will guess that there is maybe a resetable switch in the fan compartment or the roll out switch at the burner opening. either of these problems need your furnace looked at. the limit switch is over heating,bad motor dirty filter blocked air return, and the roll out switch would mean something is wrong in the combustion chamber
Jan 08, 2011 | Dayton Gas Furnace Heater
Can i shut down the gas furnice to change the air filter with out touch the temotast??
Yes you can and if originally installed by code ther
should be either a fused disconnect or a breaker mounted on the furnace. The fuse will have a cover
and a black switch below or above it.
If nothing is there but romex wire cable, then it is
hard wired in and most likely will have to be shutoff
at the fuse or breaker panel.
It is more dangerous to turn off at the fuse or breaker
panel. I recommend shutting the thermodtat to
the off position. If the furnace is within 10 years
old you could remove the top door and then lower door. The lower door when in place holds a switch
in that lets the power pass through it, when removed
your furnace should not operate.
Take my advive3 and do the simple thing and turn
the thermostat to the off position.
Jan 16, 2010 | Dayton Gas Furnace Heater
My dayton NG heater fan will not shut off properly
Sounds like a bad fan switch. The switch is located on the heat exchanger and is 110 volt bi-metal switch. Follow the wires from the blower going back to the heatexchanger. Graingers can get you a new switch if you give them your model number. www.grainger.com.
Dec 12, 2009 | Dayton Heating & Cooling
Furnace flame goes low fan stays on
if the gas pressure is good on inlet and outlet of valve u might wanna chk the burner trays and manifold for flakes, dirt, spider webs ect... once u kno the passages are clear from obstruction you can focus on the mechanical. (sounds like gas valve may be getting weak and not able to open fully)
Mar 21, 2009 | Dayton Gas Furnace Heater
Dayton blower fan repeatedly kicks on and off
chech the air filter is clean and the fan limit switch look to change fan limit
Nov 01, 2008 | Dayton Gas Furnace Heater
Dayton Gas Furnace - Blower will not shut off
Try national energy they are on line and carry most spares
Apr 06, 2017 | Dayton Gas Furnace Heater
Dayton Gas Furnace Heater Logo
215 people viewed this question
Top Dayton Heating & Cooling Experts
paulcarew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
