Question about HP OfficeJet G85 All-In-One InkJet Printer
Black cartridge problem
Any time i on my printer it keep on showing remove and check the black cartridge. I did that, but still keep on saying that. It doset print again as well.Just bought.
  • 1 more comment
  • Anonymous Jun 02, 2008
    Will not print or copy. The message is "press enter to align cartidges". When I press the button the paper comes out with nothing on it.
  • adamsribe30 Jun 09, 2008
    Window says REMOVE AND CHECK COLOR CARTRIDGE. I remove it, check, re-insert it, and the same message appears. I can receive FAXES when this message is on the screen; however, I cannot send a FAX. Message screen says "BUSY", even though my phone line is free. Can anybody help?
  • Anonymous Aug 15, 2008
    My printer keep saying Remove and check black cartridge
  • 26 Answers
YOUR CARTRIDGE CIRCUTE IS DEAD TRY ANY OTHER BLACK CARTRIDGE IF STILL IT SHOWS SAME PROBLEM THEN IT MEANS YOUR CARTRIDGE CARRAGE IS FAULTY(MEANS PROBLEM OF CARTRIDGE HOLDER NOT OF YOUR CARTRIDGE.)
Posted on May 31, 2008
Why does my photos art C6230 all-in-one keep saying I need to replace the black ink when the back shows 100%? The printer says it is using colors to make black print
If the machine is just using magenta, yellow and cyan to make black then you get brown, not black, (that why you have a black image unit, because YMC will not make black, color system issue. unless the machine is using yellow,magenta, cyan, then black. Are you using 3rd party toner or OEM cartridges? Did you replace the cartridge before it was required?
May 23, 2015 | Office Equipment & Supplies
HPpro L7600 works for about 6 pages then says replace black but black is new so reinsert and again works for about 6 pages then says replace magenta then repeats
try this. Clean the place were the ink goes into the printer. On the printer with running alchol and a qtip. Be real gental, and try and leave any residue or cotton on either place. Also, check and see if the cartridge reset itself. Sometimes you have to go into the program and reset it manualey. Sorry about the spelling errors, good luck and let me kknow if this helped!
Nov 14, 2012 | HP Officejet Pro 8000 Wireless InkJet...
My hp psc 2410 keeps reading to remove and check black catridge i clean the contacts, i make reset but nothing. keep saying the same to remove and check black catridge
You could remove both cartridges.
Close cover and turn off printer.
Unplug printer for at least 10 minutes before plugging back into the outlet
Turn on printer and install cartridges.
If this does not correct the problem, the cartridge may be bad.
Dec 25, 2010 | HP PSC 2410 All-In-One InkJet Printer
Office jet 5510 keeps saying wrong black cartridge.
Look on the right side where the cartridge goes, if the spring on the right is hanging loose it might have poked a hole in the ribbon cable at the rear near the contacts. If so it's time for a new printer, if OK, check the exp. date on the ink cartridge and if it's been refilled or a generic ink you may just need another one.
Jan 30, 2010 | Office Equipment & Supplies
My 7410 keeps saying to add a black ink cartridge but i did
Remove black cartridge and check to insure the spring has not broken loose.
Jan 14, 2010 | HP OfficeJet 7410 All-In-One InkJet...
The printer won't print. It says that the color cartridge needs to be replaced and even though I replaced it, it is showing 0%.
its a procedure to solve this problem first try this.
1) turn the printer ON.
2)then remove both colour and black cartridges out.
3)then take a moist tissue paper clean the brown dotted circuit on the cartridge and its base from where ink comes out for printing.
4)also where you install the cartridge in the printer there you will see the brown dotted circuit clean that also in printer section.then
5)directly remove the power wire from the back of the printer.
6)then remove the usb wire from the back of the printer(its the wire connection between pc and printer)
7)then wait for one minute then reconnect both the wires.
8)then turn the printer ON.
9) then insert the cartridges and check out,.
10) if same error shows up insert new black cartridge also.
this will solve the problem.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Oct 31, 2009 | HP OfficeJet d145 InkJet Printer
I have a hp office jet v 40 series fax, scanner, and copier
Get rid of the HP 45, it is not compatable, even though it looks the same. Go buy the HP15 and the problem will be solved.
Apr 14, 2009 | HP Office Equipment & Supplies
Won't print in color
All cartridges are new...report shows 0 pages for yellow left yet all others added at the same time show thousands of pages left. Everything printed is in black with no color. BTW: I have 3,000 pages left with black cartridge and the display says I need black.
What should I do?
Nov 20, 2008 | HP LaserJet 2840 All-In-One Printer
Printer Issues
my hp psc 2210 after putting in new cartridge keeps saying press enter to align cartridge. it keeps repeating the same reading.
Apr 08, 2008 | HP PSC 2210 All-In-One InkJet Printer
Intellifax 1860c no cartridge or replace ink keeps showing up
I have 1860 fax machine. It says that the black cartridge needs replacing. I buy a new cartridge and put it in and is says to install a black ink cartridge. I reinstall the cartridge several times and it says to install a black cartridge. Any help before I smash this piece of **** fax machine in the driveway?
Aug 08, 2007 | Brother IntelliFax-1860C All-In-One InkJet...
HP OfficeJet G85 All-In-One InkJet Printer Logo
200 people viewed this question
Ben Johnson
