Question about HP w1907 LCD Monitor
How do I open up the monitor hp w1907 to look at caps?
  • 11,361 Answers
Power on off problem
3 capacitors are probably bulged pn the monitor motherboard. I just fix my vs17x hp monitor, but now I have another problem. but thats your problem, the 3 bad caps in the monitor. search it up.
Jan 13, 2011 | HP w1907 LCD Monitor
My screen goes to sleep without my asking it to. Even if I move the Mouse around it will not come on. When it does finally come on. It's only for a short time and disappears in the middle of what ever I'm...
Bad CCFL or bad caps.
http://www.tomshardware.com/forum/54570-3-opening-w1907
If you GOOGLE 'W1907 CAPACITORS', you will see a lot of people with sam problems.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
http://www.badcaps.net
Aug 13, 2010 | HP w1907 LCD Monitor
Hp w1907 monitor stays on for a second when turn computer and then screen goes black; have turned on and off; reconected cables and turn on and off. Power light is blue and then turns orange.
It acts like it is not getting signal from the video card or it goes into shutdown mode to protect itself.
Try it on another PC first, if it still does not work then you will need to open iy up.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed HP monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
May 19, 2010 | HP w1907 LCD Monitor
Hp W1907 SHUTS OFF AFETR 2 MIN
Caps in the power supply will be the first place to look, but you can have bad lamp asemblies also.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed HP monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
May 14, 2010 | HP w1907 LCD Monitor
sir u should go to control panel then change the monitor timing i think u have adjusted it 2 minutes...........expand it ....... bye bye if any problem occurs mail me at vicky.akon11@gmail.com
Mar 23, 2010 | HP w1907 LCD Monitor
My hp w1907 monitor goes dim after start up. It
More likely to have problem in the power supply, back light inverter circuits, or worst will be bad lamps. Look for bad caps with bulging top first, post back what you see so we can guide you further, see example of failed monitors mostly due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 19, 2010 | HP w1907 LCD Monitor
On bootup monitor comes on for about 3 secinds or
Look at the power supply first for bad caps with bulging top/seal, it can also be in the inverter circuits or lamps. Report back what you see inside first so we can guide you further, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 08, 2010 | HP w1907 LCD Monitor
HP Monitor w1907 problem
First place to check will be the power supply section, look for bad caps with bulging top or bottom seal, post back what you see so we can guide you further, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Jan 27, 2010 | HP w1907 LCD Monitor
HP w1907 LCD Monitor Logo
474 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
