Question about Dryers
No heat in Maytag Electric Dryer
My 240v plug to the dryer smoke checked and melted the old cord. An electrician fixed the outlet and the dryer cord, but now I have no heat. What should I check and what is most likely the problem. Thanks for the help.
  • 5,911 Answers
There should be a wiring diagram inside the operating console. Locate the thermal fuse and/or thermal cut-out and ensure they check good. They both should read close to a short if good. They are mounted adjacent to the heating element. If you have trouble locating the diagram and/or need further assistance isolating the problem, please post back with the dryer model number (located on the back of the console) and I will locate some diagrams to see if I can assist you further.
Posted on May 29, 2008
I change a three prong too a four prong power cord on my electric dryer now it wont heat
U tube how to install a power cord it will show u step by step. As long as you didn't modify the outlet witch you can do with out rd inning a new line a electrician is needed for that to be done safely
Mar 30, 2016 | Maytag Dryers
LG dryer DLE2516W - everything runs but no heat, 18 months old, checked lint trap and vent to outside, the plug over heated and melted slightly so bought a new plug and new house outlet, dryer worked for a...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Nov 15, 2010 | LG DLE2516 Electric Dryer
Kenmore Elite HE4 dryer- can I change the plug from the present 4 pronged utility plug to a standard 3 prong plug and still work safely?
NO, You will need to get an electrician to install a NEMA 14-30R outlet for your dryer, the electrician will know what you need, in anycase a 240V 30amp outlet is needed if you dont already have one. DONT replace the plug.
Jun 20, 2010 | Kenmore Elite HE4 Electric Dryer
Brand new dryer threw braker twice, then no heat and timer stopped working. Electrician tightened connections on wires to dryer settings dial, had heat for one load, then same as before. Replacement dryer...
might want to check your dryer outlet. If the terminals are loose in there it could cause you problems. If your dryer plug is a 4 prong you might be loosing one of your 220v legs due to a short . As the dryer runs the wires and connections will heat up and expand , if there is a faulty wire or connection then it may loose connection after a load. could be quite dangerous and a very possible fire risk so i would check it out ASAP . if the outlet is old they sell for about $20 at you local home depot or lowes home improvement. for a 3 prong plug you need to hook up the black and white wires on the brass screws and the copper ground wire to the green screw. in a 4 prong application you hook up the black and red wires to the brass screws, the whit wire t the silver screw and the copper ground wire to the green screw .
If your new dryer is supposed to be a 4 prong plug and you have it with a 3 prong cord then you will run in to issues . The difference being a 4 prong electric dryer is a dual voltage unit where it needs both 220v and 115v to operate correctly, where a 3 prong dryer only has 220v and the earth ground. if your not familiar or comfortable with electricity please call a qualified electrician to come hand handle the work. if not done correctly it can cause fires or possible electrocution
Oct 30, 2009 | Amana NED5500TQ Electric Dryer
Longer cord/age of washer & dryer
Is your dryer electric with the big plug.
If so, what kind of changes are you making?
The dryer needs to be by the vent outlet so you can't move it far unless you are going to cut a new venting outlet.
If it is electric (not gas) then do not try to extend the cord. Have a licensed electrician move the electrical jack.
The cord has a large amount of current running through it and the longer the cord, the more resistance the current has to flow through. More resistance means more heating of the cord and less voltage for your dryer. This can result in the cord overheating to the point of melting and starting a fire itself or getting hot enough to ignite the very fine and very dry lint particles that are present in any laundry room.
This is a situation where you spend the money and have it done professionally because of the danger of fire, death, etc.
Good Luck!
Oct 09, 2009 | Dryers
Dryer spins and blows out air, but no heat comes out. I had an old dryer before, and I replaced it with a fairly newer model and still, no heat is coming out of the dryer. I heard that it may be an...
Check connections at dryer terminal. sometimes they will melt and have now power and wont cause a breaker trip. plug needs 120v at L1 and 120 at L2 and equals 240 with L1 and L2 combined. can check at outlet with a meter.
Jun 08, 2009 | Maytag HYE3658AY Electric Dryer
Dryer works but no heat, have a multimeter but need to know how to use and what to test
no heat at all? open front to access heater box, set meter to ohms. (unplug dryer), test for continuity across element connections. (disco at least one wire at each part to ensure accurate results for each check. then reconnect when done) some ohms is good here. if OL on meter then its open/bad. check each thermostat on side. they should all be 0 ohms. post results.
At terminal block in rear check voltage while plugged in. set meter to volts AC. each outside terminal to center should show 120 V approx. then together 240v. if 120 only on one side or one side significantly less than 120 then check outlet. Missing one phase/leg of supply can cause motor to run but no heat.
May 03, 2009 | Maytag Neptune MDE5500AY Electric Dryer
How do you install a 3 prong power supply cord to a GE Dryer?
DO NOT CHANGE THE POWER SUPPLY CORD.
you can't change the power supply cord.
the cord came with the dryer is 240v. the three prong is 120v. the dryer will burn up. if you change the power cord without changing the regulator , motor, and the heating element.
you need to get a electrician to run a 240v double breaker from the panel to the dryer.
Apr 23, 2009 | GE DVLR223 Dryers
Maytag Neptune Dryer power cord
Need a multmeter to check voltage .. be careful 240v is very dangerous...red (120v) white (neutral) black (120v) hope it helps
Aug 13, 2008 | Maytag Neptune MDE6700A Electric Dryer
Maytag neptune dryer MD6
All you need to do is check the element for continuity with an ohm meter, if it has continuity the element is good. The dryer also will run on 110 volts of power but it needs 220 volts too run the element, so check and make sure all the conections on your cord are secure and that you have 220 at your wall outlet.
Jun 12, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
90 people viewed this question
Top Dryers Experts
