Question about Kenmore Dryers
Our kenmore series 80 dryer stopped working yesterday, it has power, gas, but will not start at all where do I start looking to find the problem? Thanks
  • chef86s Oct 06, 2010
    the model is a 110 made by whirlpool per another site. the omms on the thermal fuse reads 00.1 to 00.2 so does that mean it is good to go? and the door switch does not help as the whole light unit is missing ( used dryer) any advise? thanks
  • 5,911 Answers
The most common cause of a dryer that will not turn on, is a blown thermal fuse, bad power cord, or a broken drum belt. If the voltage at the wall receptacle is correct, check the voltage again at the terminal block where it connects to the dryer. Make sure you UNPLUG the dryer and remove the the small access cover where the power cord is installed. If good, the problem is INTERNAL to the dryer. If bad, you need to replace your power cord.
If the problem is internal, the thermal fuse will be mounted on the blower fan housing. It is a small plastic looking component (usually white in color) with two wires attached to it. Disconnect the wires before taking any resistance checks. If the fuse is good, it should read something close to zero ohms. If bad, you will read an infinite reading. These fuses DO NOT reset and must be replaced if bad.
Some dryer's are equipped with a "Broken Belt Switch", that disables the dryer from running if the drive belt breaks. This keeps the belt from becoming wrapped around the drive motor shaft and causing damage to the motor. Since you did not include a model number, I cannot verify if your dryer is equipped in this manner.
Another cause of a dryer that will not turn on, is a broken door switch. An easy method to test the switch is to open the door and press by hand. If the dryer drum light is working, you should be able to toggle the light on and off. If the switch is found to be defective, it must be replaced.
Replacement parts can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites are reputable and have competitive pricing, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations that you can use to locate and properly identify any parts you may need. If the model number is correct, the part number you may need are as follows:
If you have any questions about these repairs, or need instructions on how to access any of these components, please post back with your MODEL NUMBER and let me know. I hope this helps you.
Posted on Oct 06, 2010
Testimonial: "nice to see a site that keeps trying to get it right by the user. thanks"
  • 2 more comments
  • Jeff Rockwell
    Jeff Rockwell Oct 06, 2010
    The Thermal Fuse is good. Unplug the dryer and see if you can access the door switch terminals. You should see the resistance vary between an open and short as you toggle the switch. If the switch is good, you need to check to see if the belt is still intact.
    belt is good to go will check the door switch thanks
    sorry to say switch is good also, really at a loss on this one!
  • Jeff Rockwell
    For future reference, if you want Experts to assist you any further, it is adviseable to avoid leaving adverse ratings and try providing more feedback. All of us are VOLUNTEERS and consumers just like you. Most of us dedicate our time for FREE to try to provide you with technical answers based on our years of experience. The answers we provide are based on the input we receive. This link may help you in understanding how the process works:
    http://www.fixya.com/support/r4570256-ti...
    At a MINIMUM, you should ALWAYS include a brand name or model number. The "110" number you provided is the manufacturer code which indicates the appliance was made by Whirlpool. This is NOT the model number. I still do not have an model number and cannot give you precise answers without the ability to verify how your dryer is constructed.
Kenmore 70 series electric dryer. Has been working great. Just stopped working yesterday. Acts as if it's not getting any power
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 21, 2011 | Kenmore 72062 Gas Dryer
I HAVE A KENMORE 80 SERIES GAS DRYER. IT WORKS
Yes the moister sensor is at fault
Apr 29, 2010 | Dryers
Kenmore 80 Series Gas Dryer won't run unless empty
MORE THAN LIKELY YOUR TENSION PULLEY IS SHOT WAS IT MAKING ANY SQUEEKING NOISES
Aug 26, 2009 | Kenmore 73952 Gas Dryer
Kenmore 80 series Dryer: Door Light stays on and wont start
Mar 05, 2009 | Kenmore 800 7982 Dryer
Location of the thermal fuse on the kenmore gas dryer 80
Feb 03, 2009 | Dryers
Kenmore 80 series Dryer NOT working
I have a kenmore elite , smart pac,he3, it will run for 10 min then shut off and a code (F 70 ) will start flashing, what does that mean.
Feb 02, 2009 | Dryers
Dryer won't start
The start windings in your motor have gone out. To fix this you must replace the motor.
Justin Duby
T and N appliance Repair
Dec 08, 2008 | Kenmore 63942 Dryer
No Heat
Hi, I worked on one of these yesterday and have found that the thermal fuse blows first. If your dryer has the lint filter on top then the thermal fuse is behind the back panel and is located on the same duct as the lint filter.It will usually have blue wires on it instead of black or red.
Oct 17, 2008 | Dryers
Kenmore series 80 Gas Dryer: No heat
ck the thermo fuse then ck the gas valve for power and the igniter to see if its broken probley igniter if you dont see a glow comeing from it
Mar 18, 2008 | Dryers
Dryers Logo
227 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
