Question about Sharp LC32D50U 32 in. HDTV LCD Television
Sharp LC-32D50U no sound through HDMI but does have video
  • 208 Answers
SOURCE: Sound, but no picture
The hdmi inputs on this unit go directly thru the main digital pcb. and the component inputs feed thru the av pcb then to the main pcb. If the composit hook up do not work and hdmi inputs do work the unit has a bad AV pcb.
Posted on Feb 05, 2008
jerryg50
  • 1667 Answers
SOURCE: Sharp 20" LC-20B4U-SM
I cannot say pariculary for this model, but on some models of TV sets, if the channels are not programed as part of the channel list, they are muted.
Turn on the TV, and perform the channel auto setup.
Jerry G.
Posted on Apr 12, 2008
ccmg60
SOURCE: Sharp Aquos LC-37D64U Skips HDMI
The problem was caused by ME not setting up my Harmony Remote correctly after buying the new TV. The remote was programmed to turn on SA8300>turn on Receiver>Turn on TV>Select channel 3.
Simple change from select channel 3 to select Input 4.
Posted on Mar 26, 2009
dsacco86
  • 1077 Answers
SOURCE: Sharp LC 46D85U TV with NO SOUND (but perfect picture)
Sound like the TV has a defective audio board. Opening up the TV would most likely void the warranty.
It's best to take the TV back and exchange it for a new one. Personally, I wouldn't want to be stuck with a defective TV ( that just came out of the box ) that they are going to repair for you.
Posted on Jul 05, 2009
  • 8457 Answers
SOURCE: sharp aquos no sound through hdmi
Reset all audio factory setting.Tries unplug,replug it well work,if ur backlight video board it still good.
Posted on Dec 17, 2009
Testimonial: "worked like a charm thank you so much, i was about to throw in the towel and get a new tv, now i don't have to thanks again"
When tv is turned on you get poicture and sound but there are broken horizontal lines from top to bottom of screen. this occurs on all hdmi inputsincluding roku and dvd player.
How to fix lcd lines on Sharp tv screen, hdmi video board ...
? 3:43
https://www.youtube.com/watch?v=cHki4D0EwOo
May 24, 2014 - Uploaded by Tampatec
How to fix LCD lines on Sharp TV screen, hdmi video board easy ... Make Money From Your Broken Cracked LCD LED PLASMATV ... TV Repair Help for Vertical & Horizontal Lines on Your TV Screen ... Sharp Aquos LC-32 37 46 52DH65E 66E 77E - NoPic/Sound with ... Get video URL at current time.
comments on LCD Display Symptoms and causes. - YouTube
https://www.youtube.com/all_comments?v=DedJvyNm_s4
We have frequent outages causing the TV to turn on from standby mode when power returns. (These ..... Sharp LC-70LE650U 70-Inch Aquos TV TURNS ON WITH PERFECT PICTURE AND ..... It has thin horizontal lines on the top quarter of thescreen. ..... hey there, bought a 52lg60-ua had no image/picture but had sound.
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Jan 28, 2016 | Sharp aquos 52 in lcd 1080p aquos 52...
Connecting cinemate seires II to sharp tv lc 52d64u
Please follow guidelines given in operation manuals of both, step by step.
Aug 06, 2012 | Sharp LC-52D64U 52 in. LCD HDTV
My Sharp LC-32SB24U says An incompatiable video signal has been recieved. Check the output device settings?
It sounds like an HDMI lead has standard video on it or the output from a digital unit is not the correct specification for your TV.
Check the instruction booklet for recomended signal sources and then check your DVD, Video, Computer for the right type of signals to be outputed to your TV.
Hope this helps.
Oct 29, 2010 | Sharp LC-32SB24U 32 in. LCD TV
No picture
It sounds like the Bluray player may be outputting the signal at a higher resolution than the TV supports. If the Bluray player has a scart or composite connection, connect with those first, and adjust its settings to output a lower resolution. Then reconnect the HDMI. Hope this works for you.
Jul 17, 2010 | Sharp LC-32SB23U 32 in. LCD TV
I've a Sharp Aquos 32'' tv
The flashes are an error code. Count them till they repeat. Get a service manual and look up the error code. Some error codes prevent the set from powering up to prevent more damage. You can reset the code for troubleshooting. Repair as required.
May 07, 2010 | Sharp Televison & Video
Sharp aquos no sound through hdmi
Dec 17, 2009 | Sharp Aquos LC32D41U 32 in. LCD TV
No sound from ps3 when connected with hdmi to sharp lc-42d64u lcd, connected to sony dav-hdx589w via digital optical cable
on your PS3 go setting>sound setting> audio output settings to adjust settings for the audio device (OPTICAL or HDMI)
Dec 05, 2009 | Sharp LC-42D64U 42 in. LCD HDTV
My sharp LC-19DV22U Will not connect to my PS3
well alex welcome to fixya technical support online.i just read your problems. there is an option to your problem you can use another cables with RCA inputs capable in your PS3 that can works on videos and also you can buy video converter. thanks!
Aug 14, 2009 | Sharp LC19DV22U 19 in. LCD Television
Sharp Aquos LC-37P50E connected to computer with HDMI cable
I got the chat , but some how it got disconnected.
But i would like to help you in this aspect.
HDMI stands for High Definition Multimedia Interface, and supports transmission of both audio and video in high fidelity.
First make sure these things,
Both your computer and your TV will need to support HDMI interface.
It's quite a recent thing in PC graphics cards, so you may have to resort to S-Video, DVI or VGA for the video, plus a 3.5mm stereo cable (or the optical TOSLINK equivalent) for the sound.
Let know your comments and i will follow up with the suggestions.
Thanx for using fixya,
Good luck.
Sep 28, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Nov 08, 2007 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Sharp LC32D50U 32 in. HDTV LCD Television Logo
59 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
