Question about Acer AL1716 F Monitor
My monitor won't stay on, comes on goes black, comes on goes black.
  • 11,361 Answers
Look for bad caps first, then the rest of the components in the power supply/inverter circuits.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Oct 07, 2010
Dell st2410b monitor won't stay lit
Ok, same issue here as well. Monitor would come on for 1/2 second and then the backlighting will go off. It's next to impossible to tell, but if you shine a bright flashlight at the screen, you can make out the video signal/desktop.
I have now replaced all the Capacitors except the very large one (didn't come with the kit that was available.) None of my caps looked bad (bulging) including the large one. Unfortunately, I still habe the same issue
So my question is....large capacitor replacement or something else?
Nov 29, 2012 | Dell ST2410 Monitor
The monitor comes on and then goes black.
Sounds like your LCD panel lamps are shutting down, this could be either due bad tubes, or more likely lamp driver power supply is faulty.
Jan 12, 2010 | Dell E173FP 17" LCD Flat Panel Monitor
Monitor will not stay on. It comes on when
someone set the refresh rate or the resolution to high for the monitor to display - start up in sage mode and change the resolution to 1024 X 768 this should work
Dec 08, 2009 | Acer AL1715 17" LCD Monitor
Black screen
try another working monitor on your computer, if it works good than you know you have a bad monitor. If the other, working monitor does not work, than you know the problem lays with the computer. That could be a bad video card, or failing RAM.
Jun 18, 2009 | HP w1907 LCD Monitor
Monitor flashes on then goes black.
I think you have the display shut off. the button on the bottom left will shut screen off. It will come on for a few seconds if you touch the screen, but will shut off again. just push the display button again and it should stay on.
Apr 02, 2009 | ViewSonic OptiQuest Monitor
Monitor comes on, I can see everything perfect then goes black
"Most" newer monitors will let you know if the are no longer receiving a signal. Sounds like the backlight is burnt out. Try getting a bright (LED works best) flashlight and shining it at the screen at all angles to see if you can see any of what you were doing. If the backlight is on the fritz, either return it on warranty or buy a new one.
Jan 31, 2009 | Westinghouse L2046NV Monitor
Monitor Turns Black
Try reseating the Graphics card first..It may be loose. Or try it in a different slot.
May 21, 2008 | LG Flatron L1715S 17" LCD Monitor
My monitor will not stay on. Gateway FPD 1530 15 in.
problem of smps some time it happen the power supply con't give the complet supply.
if still problem then replace RAM
or replace the display card.
Nov 17, 2007 | Gateway FPD 1730 17" Flat Panel LCD...
Acer AL1716 F Monitor Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
