Question about Brother FAX4100E
Error 77 - Brother FAX4100E
  • Brother Master
  • 783 Answers
I just got the same message on my mfc-8500 after a brief power outage.
I opened the front panel, removed the toner and closed the panel. The printer tried to warm up and then said to open the panel door. I then opened the door, inserted the toner, closed it and the machine error was cleared.
Perhaps all you need to do is remove the toner and put it back in.
Posted on Jan 30, 2014
What does a 77 error code on a Bernina sewing machine mean?
Machine error 77 means you hade either a Machine error 76 or Machine error 78 and turned the machine off. Sometimes the machines will give a false code and can be reset
that answer has been posted vk88
Mar 28, 2012 | Sewing Machines
Machine is on and showing "error message #77 and says to unplug machine and call dealer. What is error 77?
Error #77 refers to a mechanical problem, but I'd say about 7 times out of 10 it's a mistake. Fortunately, Brother fax machines have override commands :). Try this:
1. Turn the power off and unplug the power source.
2. Press and hold the menu button and plug in the power source (don't let go of the menu button!).
3. Hold the menu button for 5 seconds after plugging in the power source.
4. Release the menu button and press "91"
5. If the screen still shows the error code, press "99".
Hopefully this will override the error and you can get back to work :) .
Hope this helps! Good luck!
Aug 30, 2010 | Brother IntelliFAX 2800 Laser Fax
Error 77 message
The 77 error is caused by a fuser temperature sensor. The following steps can be used to possibly reset the Intellifax 4100 77 error.
1. Unplug machine then wait 15-20 minutes.
2. Hold down menu key. Plug in machine.
3. Release menu key at maintenance message.
4. press 91 then set button
5. press 99 then set button
6. Machine will warm up.
7. Press Reports key, then press 1. This will test if the machine can
print.
If these steps do not reset the error the thermal fuse would have to be replaced by a repair technician.
Jul 22, 2010 | Brother IntelliFAX 4100 Laser Fax
Error 77
Error 77 is fuser error . Shut off the power for 20 minutes . If that didn't reset the unit , then you need a new part . Call the local dealer to ask about new part price .
please rate !
Apr 13, 2010 | Brother IntelliFAX 2800 Laser Fax
What is "error 77"
Hello.
Error 77 indicates a reset condition.
I'd suggest to open the front panel, remove the toner and close the front panel. The printer will try to warm up and then display to open the panel door. Open the door, insert the toner, close the panel and the machine error should clear.
Hope this helps.
Jan 29, 2010 | Brother Office Equipment & Supplies
Error 77
FUSER UNIT PRBLM
Jul 14, 2009 | Brother IntelliFax-4100e Fax
Brother MFC-8500 Fax Error 77
Error 77 is a fuser error. If resetting the power doesn't work, then the fuser is bad and it will need replacement. Repair should cost around $200-250.
Jun 13, 2008 | Brother MFC 8500 All-In-One Laser Printer
Intellifax 4100 machine reporting error 77.
Error 77 is a fuser error. If shutting off the power for up to 20 minutes doesn't reset the unit, then you will need a new part. This repair could cost up to $200.
Jun 11, 2008 | Brother Office Equipment & Supplies
Error 77
related to a fuser error. Unit is detecting a too high or low heat internally. Try turning off for a few minutes. If error returns check voltage level at outlet or try a different outlet. Maybe too many items plugged in same outlet. If error returns, may need new fuser or thermistor.
May 09, 2008 | Brother IntelliFAX 4100 Laser Fax
Brother FAX4100E Logo
77 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
