Question about Metrologic Instruments Voyager MS9520 Handheld
Hi, I have MS9520 USB model. It has been stop working, no light just gives different sound for a second or two. Try other USB port also but same result. Is my instrument dead?
2 Suggested Answers
SOURCE: MS9520 serial connected to the terminal - does not send keys to the terminal server
Ok this is an old questions, but I had a similar problem recently. I found that I had to install Softwedge on the Remote computer.
I was trying to use the scanner over remote desktop. Remote dektop needs to have serial communication enabled. The computer that you are connecting to via RDP needs to have softwedge installed.
Posted on Oct 22, 2010
Mouse highlights everything
Your left-click button on the mouse sounds like it may be broken. A few things to try before buying a new mouse:
- If it is a wired USB mouse, unplug it from it's USB port. Wait 10 seconds and plug it back in.
- If it is a wireless mouse, unplug the small USB Dongle from it's USB port. Wait 10 seconds and reinsert the Dongle.
- If wireless, check the batteries in the mouse itself.
- Try another mouse. ( If the problem persists with a different mouse, it is a software issue and should be addressed in a new question. )
- Try another USB port. ( If the problem persists while using a different USB port, it is a software issue and should be addressed in a new question. )
Feb 01, 2014 | Computers & Internet
Hi - I have a shuttle xpc sxh57 core i7 model. A couple of days ago - it stopped sending a dvi signal to the monitors. I have replaced the video card, tried clearing the CMOS and cleaned dust. The fans and...
I suggest try the HDMI connection on your machine and see if its able to give display, since you purchase a new Video Card I assume it have a HDMI port. Or try different monitor with a DVI port if you really want a DVI connection, If it works it means the DVI port on your monitor is faulty.
Hope it helps.
Apr 20, 2011 | Shuttle Computers & Internet
Hi, every time i connect this to my home computer it turns it off! if i turn the computer on with it already connected it turns it off, have done initial set up on work computer and can access ok from...
sounds like your pc's usb socket has a problem, try the following...
1. Try a different usb port,
2. Using a small light (and possibly a magnifying glass) look inside the usb port on the pc for bent pins or distortion within the socket causing the pins to touch something they shouldn't.
3. check the usb cable for minor damage, try a different cable if you can, different machines use different ways of manufacturing sockets making some more sensitive to a damaged plug than others.
The pc turning off is a safety system which prevents power being sent through data ports. If the pc turns off immediately after inserting the usb cable then that's a sure sign that there is a bad connection/short somewhere between the socket and the cable.
Hope this helps.
Jan 16, 2011 | Verbatim 250GB USB Portable Hard Drive
I cant reset/connect my logitech wireless mouse to make it work... Put battery in and turn it on - green light stays on for 10 or so seconds then nothing?? I then press reset and hold fpr 5-20 seconds...
Try plugging it into a different USB port. also if you dropped it while changing batteries its probably junk. For what ever reason I've seen many of these that get dropped and they stop working.
Aug 11, 2010 | Computers & Internet
MX518 stops working for some seconds
The usb port might not be working fine, try the other usb port. Since the light goes off it signifies that the connectivity with the pc is lost.
Jun 24, 2010 | Logitech MX518 931352-0403 Mouse
Microsoft Metrologic MS9520 Voyager Barcode Scanner problem
If it is using the MX009 USB Cable it wont scan with the standard configuration. You will need extra configs such as enable Rs-232 Mode, Enable Xon/Xoff handshaking etc..
These can be found on the www.Metrologic.com website which will divert you to Honeywell website
May 25, 2010 | Microsoft Metrologic MS9520 Voyager...
I have a Wacom Bamboo Fun Medium Table with Cordless Pen. I've had it for about 3 months. It's been working great until this week. I notice it disconnects (the light goes out and it stops working). I...
It may be the USB port you're plugging into going bad. Try switching to plugging into a different USB port and see if that fixes the problem. If it doesn't it may be something faulty in the tablet itself and will still be covered by the manufacturer's warrenty. From my experience with Wacom, they're very prompt in fixing or replacing bad tablets.
Sep 17, 2009 | Wacom Bamboo Fun USB Tablet with Cordless...
Locked Metrologic MS9520-37 (keyboard wedge) after unintentional programming
You programmed it for usb interface, but the scanner is keyboard wedge. Try pointing the scanner at the "recall defaults" barcode in the manual as you plug the scanner back in.
Feb 12, 2008 | Metrologic Instruments Voyager MS9520...
Ms9520
try to reset a bar code ,from the manual
Jan 24, 2008 | Metrologic Instruments METROLOGIC VOYAGER...
Metrologic Instruments Voyager MS9520 Handheld Logo
52 people viewed this question
Top Metrologic Instruments Computers & Internet Experts
Gareth Cockram
Gareth Cockram
xak_tay98
Level 1 Expert
Daniel Dollive
Daniel Dollive
Are you a Metrologic Instruments Computer and Internet Expert? Answer questions, earn points and help others
