Question about Pyle Car Audio & Video
In testing my pyle visor monitors (PLVSR10) prior to installation on my show truck I find the passenger side monitor works flawlessly while the drivers side fires up but continually shows "no signal" even when connected directly to the DVD player. Have tried switching the wiring harnesses side for side, no luck. Am I missing something, or did I get a bad monitor? Thanks for any insight.
  • jbb7691 Oct 06, 2010
    Thanks for the help. That's what I was afraid of.
  • 6,993 Answers
your are noting doing anything wrong. Since you connected the monitor directly to the DVD player and its still showing "no signal", then obviously, there is something wrong with the monitor. Maybe you did got a bad monitor.
If the monitor is still under warranty, take it back and replace with with another. This time, make sure it is tested.
But if it is not under warranty, then maybe you will have to take it to a repairman to fix the problem for you.
Good luck.
Posted on Oct 06, 2010
I need to know how to fix the passenger side sun visor lights in a 2009 chevy Impala driver side works passenger side does not how do i fix it
Is the bulb good ? Is there voltage at the light fixture , ground on the other side ! Check out voltage drop testing video on youtube ! Watch basic automotive electrical testing videos . How to use a DVOM - digital volt ohm meter . You mite want to buy a repair manual , show how to take parts of your vehicle apart to get at wiring etc.... http://www.autoshop101.com/ also go here to learn automotive electrical
Sep 22, 2016 | 2009 Chevrolet Impala
How do i install my Pyle PWD701 4-Button Remote Door Lock Vehicle Security System
Referring you inquiry directly to Pyle could yield installation instructions
Sep 03, 2013 | Pyle Home Security
Install rear backup camera
PYLE, 3.5 MONITOR INSTALLATION INSTRUCTIONS, INSTALLED IN SUV. As others have mentioned ThePyle Instructions are pretty much non-existant. As a formerly ASE Certified mechanic I am posting this to try to help others.THE PYLE KIT: Monitor + Camera Mount + Wiring Harness for hard wiring into vehicle electrical. --- Additional Materials Required to Install: 3ea. coils of automotive 18 ga. wire. One red, one black, and one white. 1/8" non insulated wire but connectors, wire shrink wrap (1/4", 3/16\', 5/16" AND 3/8" best to get assort. pack). Self taping sheet metal screws 1/2" long. Roll of electrical tape, Barbed Butt Connectors (2ea.- see illustration wiring Monitor posted this site). Rubber wire grommet 3/8" outside, 1/8" for wire, 1ea. req. Pull ties. --- Tools Required: Utility Knife, Drill w. phillips bit driver, wire tripper, volt meter, small pry bar. + Misc. ---
Mar 16, 2013 | 2004 Hyundai Santa Fe
HP W2007 + Xbox 360 = Constant Sleep Mode
the monitor is bad
if it will not power on,
or show NOSIG< with XBOX on then turned off the monitor must show NOSIG>
why not test the monitor on any pc made even laptops VGA jacks works, so that works, its not the monitor.
and bad xbox video caused. but is not it. as you said.
the menu needs sync lines active. to pops the OSD button menu.
so the monitor is bad.
or the cable.
what is w2007, lets see.?
its old. at 1680 x 1050 @ 60 Hz
this old monitor runs CCFL lamps.]
im shocked it glows at all up to now.
ever do flash light trick test?
see got data, but no back light, CFFL is dead.
HP W2007
users guide last page.
This HP product contains mercury in the fluorescent lamp
in the display LCD that might
require special handling at
end-of-life:
that means CCFL died, also all do, soon.
(as short as 2 years, full time , they die. 20k hours)
out of your service manual it shows.
ccfl-wcj1avqu0msqxnqr1cdquwfl-1-0.jpg what any running pc connected the OSD menu most work
not in sleep mode.
if there is sinc, H/V pins active
that OSD must work or the blacklamp is dead
use flashlight see, there is data there, see?
Sep 09, 2017 | HP W2007 LCD Monitor
Can you provide some install steps to the pyle view plcm7300bt?
only step that is missing is the red wire one the camera.Use the adapter that is in the kit and attach it to your back-up lights this is used for your night LED's
Dec 20, 2010 | Pyle PLCM7300BT Mirror Monitor
How do i install the visors in my dodge stratus 2000 SE 2.0, and where exactly do i connect the power cords to to get the power to get them to work, and how do i connect them to my car video stereo ? if u...
connect the red wire to the red/white wire here is the wiring diagram
2000 Dodge Stratus Car Radio Stereo Audio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink/Yellow
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Orange/Brown
Car Stereo Dimmer Wire: Black/Light Blue
Car Stereo Antenna Trigger: Orange/Red
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
pls rate
Aug 17, 2010 | Pyle PLVSR72GR Sun Visor Monitor
No signal from computer to monitor 8/13/08!
I had the exact same problem!! Drove me crazy for days. Couldn't find any answers online, contacted Gateway tech support and they told me my warranty was expired but they'd be happy to discuss my issue for $2 per minute. Gateway can **** it!!
At first I thought the problem might be a malfunctioning NVIDIA card, a problem with my DVI cable, or the monitor itself. But, after turning off the computer, unplugging the DVI cable, replugging the DVI cable and restarting the computer, I noticed I could get the firmware flash screen to show, including the BIOS menu boot and the Gateway system reinstall screen to show. As soon as the Windows flash logo would display, however, the monitor would drop out and display the dreaded "No Signal" error.
This indicated the problem was a software one and not hardware! The cable, monitor and video card were all working fine. Then I remembered that Windows installed its automatic update a few days prior. In fact...
THE PROBLEM TURNED OUT TO BE A WINDOWS UPDATE INSTALLED A FEW DAYS PRIOR.
After succesfully booting into safe mode (F8 during the flash/bootup screens), I went to Add or Remove programs in the control panel, clicked on the "Show Updates" box on the top, and uninstalled the Windows update from a few days prior to the occurance of the error. After a reboot the problem was solved.
I hope this will help anybody else struggling with this error!
Aug 15, 2008 | Gateway FPD2185W 21 in. LCD Television
Car Audio & Video Logo
419 people viewed this question
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
