Question about Xerox WorkCentre M15i Laser Printer
Error code what is these open head error
  • 161 Answers
I believe your error message is "Open Heat Error". If that's the case, your fuser unit is bad. I understand that it is a new unit, although you do no specify if is is brand new or refurbished.
Now see, the open heat error comes when the temperature sensors on fuser detect a higher temperature than normal. I f that's the case you can easily confirm that by opening the side door (as if changing the toner) and feeling the intense heat coming out. If the fuser was new, then most probably you got a bad power supply board.
This is truly bad news, because for the power supply board to get damaged, a voltage surge must have ocurred. In most cases, there is also a need to replace the main board as well, for the copier starts working erratically, and loses some of its functions (such as duplex copying).
If the unit is under warranty, call Xerox. If you plan to get it repaired, or fixed by yourself, you can buy cheaper Samsung parts, for Samsung is the real manufacturer of the unit. The Samsung model is SCX-5115 gor a non fax unit, and SCX-5315f for a fax capable unit.
Good luck.
By the way, if you happen to fix the copier, or buy a new one, the only way to TRULY protect it from voltage damage is with an Innovolt SVSS protector. This is truly new protection technology and we sell them a lot here in Puerto Rico. Price is $74.95 plus shipping.
Posted on May 28, 2008
How do i clear error code c4154 on bizhub c250
Polygon Motor for the Black Print head LASER is bad, the motor is internal to the print head get a new print head for the black, requires tech to install, clear code bye open closing front door.
Oct 17, 2015 | Konica Minolta bizhub C250 All-In-One...
Print Head open error but it is not open. Calibration did not work
the flag inside the printer was moved out from sensor, you will have to adjust and tied the screw a litl bit as well.
Feb 26, 2014 | Zebra 105SL Thermal Label Printer
Printer heads errors
switch on the machine wait till error appears on panel, go to the system open internet explorer type IP address enter you can view the entire printer over view.. check which print head showing faulty, ask to replace the head open top cover of the printer open print head cover remove print heads clean print head contact pcb as well as carriage contacts insert print heads back then check for the print head recognition, printer will perform its own priming and all wait till ready mode comes onece ready mode appears.. print heads are OK.. if not replace faulty print head/s.Most of the cases cleaning is enough.
Jan 08, 2012 | HP DESIGNJET T1120 44 Printer
How to fix error code u051 cannon printer mp480 error code u051
Reset the Print Head:
Make sure that the power is turned on, and open the Paper Output Tray gently
Lift the Scanning Unit (Cover), then hold it open with the Scanning Unit Support (A). (The print head will move to the replacement position.)
Remove all the Ink Tanks in the following manner.
Push the tab (B) and lift the ink tank to remove.
Do not touch the Print Head Lock Lever (C).
Raise the print head lock lever.
for other more help click https://cbrtechsolutions.net
Oct 17, 2011 | Office Equipment & Supplies
I have a error with a tally 2440 - Park error / Head jam
when the printer is turned on, the head moves to its home position. normally go to left then right & stays at middle. by opening the top cover u will see HEAD. see what object obstructing the movement of head. try to lubricate the shaft where the head moves right-left.
Sep 13, 2011 | Office Equipment & Supplies
Error message "head open" any ideas why please?
Check the microswitch on the leftside of the print head.
Sometimes a part is missing or the print head is not correctly mounted
Jun 15, 2011 | Toshiba TEC B-4700-I/O-QM Thermal Label...
Getting "Error Number : 1403
Not sure what you are asking. You posted the solution?
Jan 24, 2011 | Canon Office Equipment & Supplies
What does error code 3820 mean for a kodak esp5 all-in-one printer
The error message "Carriage Home detection failed" (error code 3820) can be resolved by following these steps:
To resolve this error:
1.Open the printer access door.
2.Disconnect the power adapter from the printer.
3.Gently hold both sides of the carriage, located immediately behind the print-head, and make sure the carriage moves freely.
•If the carriage does not move freely, contact Kodak.
4.Remove the print-head and ink cartridges.
5.Reinstall the print-head and ink cartridges, making sure each clicks into place.
6.Connect the power adapter to the printer.
7.Turn the printer on, if necessary.
8.Close the printer access door.
If the error continues, contact Kodak.
Sep 07, 2010 | Kodak Office Equipment & Supplies
Opened my printer espson dfx 9000 and im getting an error 16 how do i overcome this?
OPENED MY PRINTER EPSON DFX-9000 AM GETTING AN ERROR 16 HOW DO I OVERCOME THIS
Jul 23, 2010 | Epson DFX-9000 Matrix Printer
Says paper is out says ribbon is out. Both are loaded properly. Says head is open. It's not. Turned off and on. Received error code bblock v23
I am having the same issue. Please help. Not having luck with this printer. I thought it was easier to print some labels.
Jun 23, 2010 | Zebra Thermal S4m Dt Zpl 203dpi Rs232/par...
Xerox WorkCentre M15i Laser Printer Logo
278 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Whit
Whit
Level 1 Expert
iteminconline
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
