Belkin Wireless Modem Router problem
I have set up my N1 Belkin Wireless modem router and the wired PC works fine, but i am not able to connect to the router through any of my wirelss devices, it tells me there is no signal being received. all checks and tests have been done, but still no joy. Please help?
    Scholar:
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 77 Answers
Well, first of all the i also have the N1 belkin wireless modem router, in order for it to connect, there has to be a wireless connection in your area for you to connect to, if any of your neighbors so have wireless you can connect to their network, but if you are not getting a conection that means no one around you has wireless or lan, the belkin wireless is not a internet provider it just extends the distance of your internal wireless. some networks may be secured as well, sometimes you can only connect to unsecured networks unless you have the name and passcode for the secured network.
Posted on May 28, 2008
2 Suggested Answers
Ryan5443
  • 336 Answers
SOURCE: I have set up my
Did you check how powerful the router is? How strong the receiver is? That is why you are not getting a signal. Also if you go to the connections you can search for wireless connections that the receiver can see.
Hope This Helps
All The Best,
RCF
My belkin n series keeps losing internet connection hard wired to my computer and three wireless computers in the house. when hard wired to the virgin broadband modem everything works fine
I would suggest taking a look at your modem LEDs. What happens exactly when you lose connection? A look at the LEDs should give you some thought as what might be causing this. You can also try resetting your Belkin to default factory settings by pressing the Reset button at the back for 30 seconds, and then putting back your Belkin settings.
Nov 16, 2010 | Belkin N1 Wireless-N Wireless Router
Cant get connected with my belkin router...all i can get is "connected with limited access
HI
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} How to quickly install and use your Belkin wireless G router
1. Step 1 Position your Belkin wireless G router.
Place your wireless G router in a wide open and central location. Don't connect the power plug into the router, yet. Make sure your computer is turned off.
2. Step 2 Connect all the devices.
Find the Ethernet cable that connects your PC to the modem. Unplug the Ethernet cable from your PC and insert it into the wireless G router's WAN port. You should have an additional Ethernet cable that came with your router. Take this cable and plug one end into one of the LAN ports on the router. Then connect the other end to your PC's Ethernet port.
3. Step 3 Turn on your modem, router, and PC.
Plug the power plug adapter into the modem. Turn on the modem. It'll take approximately 30 seconds for the modem to boot up. Connect the power plug adapter to the router and the other end into a power strip or outlet. Like the modem, it'll take about 30 seconds for the router to boot. Turn on your PC.
4. Step 4 Verify lights are on for your devices.
Make sure the following lights are on for your router: power, WAN, and LAN light. If you don't see any of them lit, confirm these devices are turned on. Make sure the Ethernet cable connections are installed correctly.
Step 5 Install and configure software.
Use the setup wizard application to configure your Belkin wireless G router. Set up features, such as creating your password and setting up your time zone. Continue to follow the setup wizard so you can configure ?other settings
Oct 18, 2010 | Belkin N1 Wireless-N Wireless Router
My Belkin N1 router can't seem to establish connection with the cable modem - the router light flashes and connects but as the internet light flashes it loses the router light again. It is still allowing...
the modem is working fine. the connection might be dropping from the router side.
You can try to upgrade the Firmware of the router.
reduce the MTU on the router. If it is on 1500 the reduce it to 1400.
Click Here from more info about routers
Oct 31, 2009 | Belkin (F5D8231-4) Wireless Router...
Belkin N1 Wireless Modem Router I cannot connect to Tiscali HELP
I had this with Bt Internet and this exact same router, you have to phone Belkin up and they give you a complete set of new settings that you manually have to put in during setup. If i remember rightly its a free phone number and the operator who answered spoke semi-english so not all bad, hope this helps.
Chris E
May 17, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Belkin N1 wireless network not working
It might be an idea to upgrade the firmware which can be downloaded from manufacturers' website
Mar 20, 2009 | Belkin N1 Vision Wireless Router
I have set up my N1 Belkin Wireless modem router and the wired PC works fine, but i am not able to connect to the router through any of my wirelss devices, it tells me there is no signal being received....
Hope This Helps
All The Best,
RCF
May 28, 2008 | Belkin Computers & Internet
Belkin n1 wireless usb adapter
Dear Friend,
1. Connect your ISP modem to your PC and configure as Bridge mode.
2. Remove your ISP modem and connect your wireless router to your PC and configure as PPPOE mode. (refer http://www.wi-fiplanet.com/reviews/article.php/3645166 if any doubt on configuration)
3. Now connect your ISP modem to wireless router, The modem should connect to your WAN cable.
4. And Give the wireless router's IP in your laptop as Gateway (In TCPIP settings of your Laptop wireless adapter / or configure DHCP)
5. Now you can access internet on both systems.
Feb 02, 2008 | Belkin N1 Wireless USB 2.0 Network Adapter...
Downloads locks up - Belkin N1 Wireless Router
I had the same problem. My Belkin N1 Router was constantly dropping the WiFi connection (every few minutes). I tried several solutions I found on different forums:
Change the channel selection from Auto to a specific channel -- I tried all 13 channels, but no improvement.
Update the firmware to the latest (Beta) version -- still no improvement.
Finally I enabled "Protected Mode" and the connection seems fine now. Hope this helps, and good luck!
Nov 05, 2007 | Belkin (F5D8231-4) Wireless Router...
Computers & Internet Logo
120 people viewed this question
David Payne
David Payne
