Question about Gateway Belkin 54g Wireless DSL/Cable Router (DHF5D72304)
Unsecured network shows up as secure
My roommates and i have a belkin 54g wireless router set up with our cable modem, the roommate who's laptop is the host is away for the summer and has his laptop, my friends desktop computer works fine with the router, and my laptop worked fine with it for a few weeks as well, but now whenever i try to log on to the network my computer says the network is secure and asks me for a network key, my friends computer says the network is unsecured and connects just fine with no network key, we have tried resetting the router and the modem but nothing seems to help, how can i fix this problem?
  • dizdes May 28, 2008
    the router is not hooked up to a computer....if we were to hook the computer with the problem up to the router without the cd how could we fix the problem?
    Sergeant:
  • 336 Answers
The person who has the router attached to there computer must enter the IP for the router and you will be able to reset the password to enter the router. If you need Help doing this I can solve this issue with you through my computer.
Hope This Helps
All The Best,
RCF
Posted on May 28, 2008
Somehow my belkin 54g router is now a secured network and i didnt set it to be and now i cant get a signal because i dont know the security code. how do i put it back to being unsecured?
Please enter the IP address of the Router in the internet explorer and enter the user name and password of the router.(admin, admin). When the windows will open, you can see the wireless security. When you click on that you can see the security key. Other wise you can change the security key.
Aug 06, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
My roommates laptop is connecting to the internet, mine won't
Sometimes the key length would change for security purposes. What you have to make sure is that you are entering the correct network key.
Use a connected computer like your roommates laptop or hardwired connect you laptop to the router using an ethernet cable to access the setup page of the router.
In your browser's address bar, type 192.168.1.1. By default, leave the username blank, password is admin.
Go to Wireless -> Wireless security.
You will see the network key. Just copy that and enter it on your laptop.
I hope this helps!
Jul 12, 2010 | Linksys WRT160N Wireless Router
I have secured my router by connecting my laptop to the router by ethernet cable so now my network comes up as security enabled but I can't seem to connect to my wireless network although it shows the...
Remove the neighbor's network from the preferred network list.
add your own network in the list. If your router is old router then upgrade the firmware of the router. Firmware is the software of the router.
You have connected your laptop to the router, to secure the wireless network. When you connect the laptop to the router, make sure that the wireless network connection will be disabled.
Once you change the wireless settings, enable the wireless connection and connect to your network.
Apr 25, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
Upgraded to windows 7 and i am unable to connect to the internet. I get a limited or no connectivity
I'm thinking modem/router combination. first power down modem and router. Then leaving router unplugged, power up modem, make sure it's sync up then power up router. If this is a wireless connection search for your networks name on computer/laptop..ie View wireless connection. Windows allows a automatic setup if the wireless connection is unsecured. If it is secured Windows 7 will prompt a pass phrase/ or access code. Good luck. Repeat process if necessary
Jan 31, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
I a using cable net and not the dsl line.the net on my pc is working but when i try to connect ps3 wirelessly it show 100% signal from belkin but the internet connection fails.i have tried different...
check the wireless settings of the router .
Make sure that you are typing the correct network key if your network is secured.
May be you will need to open the ports on the router.
Click Here for more information
Jan 04, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
How do I put security on my Belkin 54g router
You set your security by enabling WEP.
When you get in the interface to configure WEP, set a pass phrase. Write down the 3 numeric keys it generates. Then connect to the wireless using your laptop, etc. When it asks for your passkey, do not enter the pass-phrase; enter one of the three keys that were generated by the router. That's the biggest mistake people make when trying to get wireless to work.
Oct 06, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Unsecuring my wireless router
http into it 192.168.0.1
if you set the password there is a small button somewhere at the back of the Bulken that will reset that ... You shiould be able to HTTP into the the setup menu and change any of it's configuration
Jul 26, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Router
you may need to set up a security item...can't remember what it is, but you need to set up a password as well, to make the network secure
Jan 07, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Wireless not working
Be sure Wireless Lan feature activated on your PC (check user manual).
Get network params from your Roommate PC (Protocol: WEP or WPA? Security key or Passphrase? Radio Band"A B G or N)
Replicate same info on your PC.
OR try connecting to a free access point (no password required)
if you have one available in range: Right click on Wlan Icon on Systray select "View available wireless network" connect to any unsecure network OR to a secure network if you know password
Dec 29, 2008 | Toshiba Satellite A135-S2276 Notebook
Belkin N Wireless Router doesn't connect to Modem
If router is brand new you should have a set up disk. the set up disk will walk you through it or you might log onto Belkin site to see a walk through set up. If you can access internet from modem to router to internet. That means router is functioning properly. To go completely wireless you will need to secure your network and setup your access codes. Definitely use the setup disk to do this. A unsecured wireless network is a nightmare waiting to happen. Good luck
Sep 01, 2008 | Belkin Modem connector (R6G064-R-50)
Gateway Belkin 54g Wireless DSL/Cable Router (DHF5D72304) Logo
339 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
