Question about Belkin Computers & Internet
I have set up my N1 Belkin Wireless modem router and the wired PC works fine, but i am not able to connect to the router through any of my wirelss devices, it tells me there is no signal being received. all checks and tests have been done, but still no joy. Please help?
  • jhuntermgs May 28, 2008
    the router is strong emough to cover the whole house, also the wireless adapter cards are specific N1 cards.
    Sergeant:
  • 336 Answers
Did you check how powerful the router is? How strong the receiver is? That is why you are not getting a signal. Also if you go to the connections you can search for wireless connections that the receiver can see.
Hope This Helps
All The Best,
RCF
Posted on May 28, 2008
Router greatly slows up/downloads to 25% of direct from modem
I am using a Belkin N1 Vision router with Vonage and i am having no issues with speed at the moment. What OS and connection are you using. If its Vista and Wireless make sure you are using AES encryption and not TKIP as my wireless network was painfully slow using TKIP and lightning with AES and WPA2
May 11, 2009 | Computers & Internet
When i first connect my daughters computer with an belkin wireless router than i stop working than i purchase an d-link not thinking it would make a different but it didn't and still not working do i ahve...
No you can't use two routers (without being an expert to set them up correctly!). Make sure the Belkin isn't plugged in while you're setting up the D-Link. To diagnose the culprit, try these steps:
1) Plug your daughter's computer directly into the ethernet port of the DSL or Cable Modem. You'll need to do this to rule out your Daughter's PC as the problem. If it works fine, then move to step 2. If her computer still isn't working, and another computer connected the same way DOES work - then you need to work on your daughter's computer, becasue that's where the problem lies.
2) Ok since you confirmed your daughter's PC is just fine - and also the DSL or Cable connection is working as well - this indicates most likely the router(s) are at fault. So let's work with the D-Link, since we're not sure if the Belkin is working. Like I said, be sure the Belkin is completely unplugged and powered OFF. Now plug the D-Link into your DSL or Cable modem ethernet port. Turn on the D-Link, make sure the correct indicators are lit on both the DSL/Cable modem and the router. Reboot your daughter's PC and right-click on the wireless networking icon on her taskbar. Choose view available wireless networks - if you see your D-link listed, then the router is working! If you still can't connect - try disabling WEP/WAP and try again. Most likely it's just a security setting that's off.
Good Luck!
Dec 31, 2008 | Computers & Internet
I have just got a Belkin N1 vision wireless modem router. I have set it up and have it working ok on a Unsecure wireless network. But as soon as I try to secure the network. I get the following message...
Right-click on the network icon in the bottom right hand corner of your screen, Press Connect to a Network. You should see your wireless network in the list. Before you secured it, you could automatically connect to it because it was unsecured. Now you will have to double click on it and enter the username and password you secured your router with.
Once you have done that, there should be a box for you to tick that says 'Automatically connect to this network'. Tick that.
Done.
Hope this helps
Chris (ziraffa)
Dec 20, 2008 | Belkin Computers & Internet
My computer doesnt seem to be working with my Belkin router. I have yahoo sbc and my modem works fine, but once I connect it to the router it can't make a connection
I use a belkin wireless adaptor for connecting my PC to the wireless router of trendnet, i observed that belkin adaptor does not work with standard windows wireless networking , i downloaded a separate suite provide by belkin for the purpose and voila- even my 8 yr old son and now reconnect if connection is broken :)
Sep 26, 2008 | Computers & Internet
Belkin N Modem Router If main PC which is ethernet wired to the modem router is swtiched off, laptops cannot access the internet. Does this mean that the PC to which the modem router is connected has to...
it will as long as the modem/router is connected to a phone line, instead of the pc, the only cable connected to the pc should be a ethernet cable; or you have the pc networking set that it connects via another pc instead of through a gateway, re run the wireless network wizard.
Sep 05, 2008 | Belkin Computers & Internet
CONNECTION PROBLEMS WITH BELKIN N1 ROUTER /MODEM
YOU CAN RESET THE ROUTER TO FACTORY SPECS IF YOU INSERT A PIN INTO THE TINY HOLE IN THE BACK. THEN YOU WILL NEED TO LOOK UP THE MANUAL TO TELL YOU HOW TO SET IT UP. Sorry about the caps. The button stuck.
Are you trying to go wireless? Wireless settings will need to be passworded as per the manual. Your computer will have to have wireless connection and it will need to be set up correct also. Default settings usually work. The drivers will allow you to set up the wireless card in the computer. Go to the web site and find the drivers and the manual. This can not be done by one of us here. We can help after you have done everything that I told you to do but it will work if you follow my directions.
May 30, 2008 | Belkin Computers & Internet
Belkin Wireless Modem Router problem
well, first of all the i also have the N1 belkin wireless modem router, in order for it to connect, there has to be a wireless connection in your area for you to connect to, if any of your neighbors so have wireless you can connect to their network, but if you are not getting a conection that means no one around you has wireless or lan, the belkin wireless is not a internet provider it just extends the distance of your internal wireless. some networks may be secured as well, sometimes you can only connect to unsecured networks unless you have the name and passcode for the secured network.
May 28, 2008 | Computers & Internet
Zyxel P660HW - Wireless Router adsl modem set up poblem
Check in network settings that the two computers have not the same IP address.
Feb 13, 2008 | Computers & Internet
Computers & Internet Logo
54 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
steve morris
steve morris
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
