Question about Xerox WorkCentre M15i Laser Printer
Xerox m15i cant you help me find my ploblem my printer cames and error my error is open head error but my fuzer is new what dit you tink its that ploblem .thank you .
    President:
  • 2,072 Answers
The heat rod is bad in the fuser.
You need to replace the fuser.
Look at this site.
https://www.partsdrop.com/store/
Posted on May 30, 2008
How do you replace the fuzer and what is the fuzer?
Its the heater section of the machine which melts and presses the toner on the paper and no need to replace the fuser section as it it a 100 dollar disposable machine so better buy a new machine.
Jun 18, 2014 | Xerox Phaser 3100MFP/S Laser Printer
Xerox M15i has a paper jam 2 error, how to fix
Hi, open the right side as if you were removing a jam. You will see 4 silver phillips screws. Remove them, unplug the fuser and slide it out. I think you will find either a paper folded up in the fuser or in the paper path just past the fuser.
The fuser itself probably needs rebuilt or replaced.
Take care
Jul 19, 2010 | Xerox WorkCentre M15i Laser Printer
I am using a Xerox WorkCentre M15i connected to a server via a USB cable. I am trying to configure the scanner so that each user can perform a scan from the workstations without accessing the server...
There is a device called a Pocket Pro that attaches to the machine and you can then hook it via a RJ45 connection. I believe Troy makes that device. I have used it several times with success. Its basically a print server device.
Feb 02, 2010 | Xerox WorkCentre M15i Laser Printer
Reads open heat error
This sounds like a problem with the fuser or possibly the fuser lamp. You can try turning the printer off for about ten minutes to cool the machine off and then turn back on. If that doesn't work you would need a new fuser unit. The fuser is located behind the door on right side of the machine. There are four screws used to hold the fuser in place. Good Luck, I hope this helps.
Aug 21, 2009 | Xerox WorkCentre M20i All-In-One Laser...
My Xerox Work Centre M15i is not compatible with my mac mini.
I still cannot get it my Xerox Work Centre M15i to work.  It is not compatible with my mac mini.
Apr 08, 2009 | Office Equipment & Supplies
Xerox WorkCentre M15i squeals when printing and copying.
Do not only lubricate metal shafts, but promptly lubricate the "pulleys" on the right and left side.  the will look very similar to a wheek and pulley mechanism.  The squeal happens when one "bar" connects two "wheels" and one side moves faster than the other.
Jan 23, 2009 | Xerox WorkCentre M15i Laser Printer
Xerox M15 PCL6 error
I would go to the xerox website and try downloading the PCL5e driver. It works just as well and even better in most cases. I hope this helps.
Dec 07, 2008 | Xerox WorkCentre M15i Laser Printer
Xerox WorkCentre M15i Laser Printer Logo
139 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
