Question about Kenmore 62602 Electric Dryer
I have a 26-62512 dryer, what are the electrical requirements.
  • 5,911 Answers
If this is a Kenmore model ELECTRIC dryer, you need a dedicated (220-240VAC) receptacle on a circuit capable of handling 30 to 35 amps.
If you need to know how to properly install your power cord, the following link explains how:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
If you have any questions or concerns, please post back with your complete MODEL NUMBER (located on a nameplate around the door opening) and let me know. I hope you find this information helpful.
Posted on Oct 06, 2010
Is this a gas or electric dryer (part of a stacked set) Frigidaire
Model No. GLGH1642FS has a gas dryer.
Model No. GLEH1642FS has an electric dryer.
Model No. GLGT1031FS has a gas dryer
Model No. GLET1031FS has an electric dryer.
Model No. FGX831FS has a gas dryer.
Model No. FEX831FS has an electric dryer.
Get a stack model that suits your needs and compatible with your home's utilities setup.
Gas models are more common with most people because most electric models
require 240v outlets that many houses don't have.
Feb 20, 2011 | Dryers
Tip
Choosing a dryer.Gas or Electric
A gas dryer saves electricity cost, but requires an installed gas line to the home and special installation. If gas is available for a dryer, the outlay for a gas dryer model may be a good option if your dryer usage is high. An electric dryer costs less, but requires installation and energy costs for a dryer varies with usage. Both types of dryers require proper venting to the outside. Always follow the dryer manufacturer's installation recommendations.
on Aug 17, 2010 | Refrigerators
Wire connections for electric dryer. How to
The following link explains how to connect a 220VAC appliance cord to an electric dryer:
There is a difference in how the 3-wire and 4-wire configurations are terminated. Read through the instructions throughly and let me know if you have any questions. I hope this helps you.
NOTE: Homes built after 2000 are required to have a 4-wire configured outlet to be in compliance with the National Electric Code. If you live in an older home that currently has a 3-wire configuration you are not required to upgrade it.
Feb 18, 2010 | Maytag Neptune MDE5500AY Electric Dryer
CAN A 220 BE CONVERTED TO A 110
If you mean can a 220 volt dryer be converted to run on 110, the answer is no. It needs the higher voltage to run the heating elements. It would be possible to make a 110 volt electric dryer, but it would require very thick wire and a very large breaker to handle the amperage that would be required. Sorry I couldn't give you better news.
Nov 14, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Diagram of wiring on Miele dryer
Hello cpopp101,
Please follow the link and goto page 30 for the electrical requirements. The manual is for the T8012 but all the dryers are the same for electrical. Goto page 30. There is usually a seperate fuse box for these (Depending on how old the dryer is) in which you may want to contact Miele to see if you have
http://www.mieleusa.com/manuals_pdf/Residential/Dryers/T8012C_8013C_us.pdf
Good luck
Sep 17, 2009 | Miele Novotronic T1515A Electric Dryer
Electric dryer not drying clothes
The electric dryer requires 220 volts to dry clothes but only 110 volts to turn the drum .reset your circuit breaker even if it looks ok ,if that dosent work, unplug from the wall and check where the plug wire goes into the back of the dryer and look for loose or broken wires.
Apr 26, 2009 | Estate TEDX640JQ Electric Dryer
Convert a gas dyrer into a electric dryer?
Sell the dryer and get an electric one. Conversion is not possible. Be advised that electric dryers run on 220 volts and require a special plug. hope this helps!
Jan 07, 2009 | Kenmore 73952 Gas Dryer
Electric plug for the dryer.
there is NO such adaptor.. you were given anelectric dryer, electric dryers require a 220v outlet, not an ormal 110v house outlet. you would need to call an electricin to run you a 220v line to use this dryer
Nov 25, 2008 | Kenmore 63942 Dryer
New Dryer was purchased -- Tenant tells me he now requires higher voltage
Hello Paulcolletti,
I am not sure what you mean with your question.. Electric dryers typically use either 3 pole or 4 pole plugs that mate with the corresponding receptacle. If you already had an electric dryer there before, you need to make sure your power cord matches the receptacle. If it does not, most home goods stores ( like Home Depoit/ Lowes) and others carry the molded cord sets for that application and are reasonably easy to install. I fail to understand the low voltage versus high voltage comment as it pertains to a dryer. Please elaborate on this and maybe I can assist with a solution.. Good Luck...
Oct 01, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Dryer
What are your power requirements? I lived in Europe for a while and all the appliances ran on 220 VAC, 50hz. Most American appliances that use 220 VAC (like dryers and electric ranges) have 60hz timers, clocks and motors. Now...if the European standard is still true (I haven't been there in years), you can probably use your dryer, but the timing will not be accurate. Your timer will probably run slower than required.
Feb 20, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 62602 Electric Dryer Logo
81 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
