Question about Cambridge Audio Azur 340A 2-Channel Amplifier
I have a Cambridge audio turntable which looses sound quality about halfway through record, as though it looses one of the channels (on the right hand side). I've tested the speakers, the amp, even had it sent off to Cambridge to be tested by them but with no success. Has anyone else had a problem like this and could you suggest anything that may help fix it?
    Sergeant:
  • 198 Answers
Might be a weak relay or transistor in that channel, they both will stop and reset when overheated. make sure you're ready to test it when it does this again, this may help you locate the bad component. I'm leaning towards the transitor, because they also amplify sound signals in radio frequency.
Posted on Oct 06, 2010
Only one speaker works
Check the connections at the rear of the pickup. They tend to work loose over time
Sep 30, 2012 | ION Audio Vinyl Recording Turntable
Got record and it is not loud. never had any problems with other vinyl records sound quality. I want the songs to be converted to MP3 but the sound on them is so flat. other records I have converted sound...
Hi, maybe the record is worn and that's why the sound is low. By using third party audio editing software (i.e. cool edit [paid] or audacity [free]) you can improve quality and volume of digital sound.
Aug 11, 2011 | ION Audio Vinyl Recording Turntable
I am only getting one channel when recording from Numark Ion Usb turntable, using Audacity software. The software is configured for stereo, but left track is not recording (and no sound from speaker...
Set your Audacity software to STEREO MIX on the main window. Go into EDIT, Preferences and set the recording device to your sound card and the channels to 2 stereo.
Mar 07, 2011 | ION Audio iTTUSB Turntable
I only hear the left side of my one turntable. the right side sound just barely comes in
Remove the wires to the cartridge. With the turntable connected to an audio source, touch the ends of the loose wires with your finger (one at a time). You should hear a good buzz on either channel on at least two of the wires. If you still get a weak channel, the problem is either inside the turntable, a bad connection, or a fault on the audio source. If the buzz is good on both channels, then the cartridge is to blame.
Sep 23, 2010 | Numark TTX1 Turntable
I have a ION iTTUSB turntable. When i record a vinyl record to my computer hard drive i am only getting the left track. This can also be seen on the computer screen while the computer program is running,...
It sounds like you've connected it to the computer's MIC input instead of LINE IN input.
Check your sound card connectors. The icon for LINE IN will be an arrow pointing in to three curved lines. More-or-less like this:
Dec 27, 2009 | ION Audio Vinyl Recording Turntable
The mic does not record stereo anymore. when playing back a stereo works fine but when recording in stereomodus only the left channel records, the right channel seems to record silence/noise
This Mic is not a stereo Mic. If you're using a windows computer, check your sound control panel to see if the mic wasn't suddenly set to two channel device.
Sep 30, 2009 | Samson G-TRACK USB RECORDING MICROPHONE...
Help
Hi if you click on control panel, click on hardware+sound,then click on the recording tab find it will show up as microphone USB Codec click on it, click the properties button,click on advanced tab,
in the default format make sure that " 2 channel,16-bit,44100Hz (cd quality)" is selected, the incorrect default is for 1 channel.
Hope this is of some use to you.
Regards leo21682
Dec 29, 2008 | ION Audio TTUSB10 Turntable
Sound very distorted
This turntable has a preamp switch on it, which is probably on and what is causing the distortion. Take off the metal record platter by lifting up on the two holes gently. Turn the pre-amp switch to 'off' and then try it again. This is probably it...
Or you can plug it into an input that doesn't have a preamp and that should work.
Dec 25, 2008 | Audio Technica AT-PL50 Turntable
Cambridge Audio Azur 340A 2-Channel Amplifier Logo
128 people viewed this question
Top Cambridge Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Cambridge Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
