Question about Canon SPEEDLITE 580EX TTL Flash
My speedlite keeps flashing the zoom control and freezes
My speedlite freezes 5 seconds after i turn it on and the indicators just keep blinking
  • the bucks Jun 06, 2008
    my 580ex speed lite also keeps blinking the zoom also. Any ideas???
  • Andrew Stain Jan 20, 2013
    Possibly the zoom motor is jammed, can you hear it make a funny noise when turned on? Here is a step by step of how to fix it if that is the issue:http://wp.me/p2HrbR-2e
Make sure the built-in diffuser is pushed in all the way... that diffuser is only designed to work when in "14-mm" mode so whenever that diffuser is down, even just a little bit, the entire display will flash and 14 mm will be shown as the focal length of the flash.
Posted on Aug 06, 2008
Is not working properly
A good possibility is the zoom head is causing the clicking sound. As we zoom the flash, the inside of the head moves to the back and forward. Gently tap it a few times see if that helps. My guess is it needs servicing.
Apr 18, 2014 | Canon SPEEDLITE 580EX TTL Flash
Text is blinking on my 430ex lcd screen zoom --mm. How do I get it to stop?
Check the diffuser is fully retracted. Pull it fully out then all the way back in.
Apr 10, 2014 | Canon Speedlite 430EX TTL Flash
Zoom flashing
This will come on if you manually activated it on the back of the flash. It's for the times when you want to manually provide wide or tele coverage.
Jan 17, 2014 | Canon SPEEDLITE 580EX TTL Flash
SPEEDLITE 580EX TTL Flash: flash is making a constant beating/clicking noise ...
Loosen the two small screws under the flash on the swivel head. Turn flash on. You may need to twist the head just slightly. Flash bulb moves back and forth in the swivel head when zooming. If you dropped the flash, this may have jarred it from the track. I had the same problem with mine, and the above solution fixed it. Zoom works again and no clicking noise. Let me know.
May 18, 2010 | Canon SPEEDLITE 580EX TTL Flash
430EX
your flash has a diffusion panel in front, make sure its in all the way
good day
yitzy
Oct 19, 2008 | Canon Speedlite 430EX TTL Flash
Canon Speedlite 430EX zoom issue
You're gonna kick yourself, but here goes, you know that clear plastic wide beam shield on the front, make sure it's fully inserted or else the auto zoom won't work while it's in use, (or the flash thinks it's in use)
Aug 07, 2008 | Canon Speedlite 430EX TTL Flash
Canon Speedlite 580EX Fault
same problem after a 30 cm falling on the floor. U must open the head of the flash and rearange the flash Bulb on the moving(zooming) track. images of how to u cand find HERE
Aug 21, 2007 | Canon SPEEDLITE 580EX TTL Flash
Canon SPEEDLITE 580EX TTL Flash Logo
392 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
