Question about GE Monogram ZISS420NRSS 42" Built-In Side-By-Side Refrigerator (ZIS-S420NRSS, ZIS S420NRSS)
Ge monogram zisw42emd, evap fan not coming on, Units been down a week, compressor seized,installed start kit. Compressor running 2.5 amps pressures 25/105 Replaced coil thermostats, evap fan not running.
  • carlos_de548 Oct 08, 2010
    When the box is first started,
    What will the start up pressures be considering
    The evap fan is not running and the box is warm?
  • carlos_de548 Oct 10, 2010
    R12, I put some hot shot in it, The evap is frosting. I replaced both of thermostats with 25/45 stats.
    The condenser is not hot but i assume its because the the evap is not running and picking up the heat. What should the psi be on start up. It was running at 0psi and i increased to 25 on the low side to make up for the heat load.
    Sergeant:
    Champion:
  • 351 Answers
That back pressures sound high to me and the hi side sound low may have a bad compressor not pumping right should run around 0 to 5 low 125 to 150 hi hope that helps
Posted on Oct 08, 2010
  • 1 more comment
  • sparks194520 Oct 08, 2010
    the pressures should be the same . thay will go down very fast the reason i think the fan is not running is because the evp is not getting cold enough you can jump out the thermostat the fan will run if the motor is good. there are to t stat on the evp 1 is the defrost tstat the other is fan . what gas dose this refer have in it 134a or f12
  • sparks194520 Oct 11, 2010
    after 5 to 10 min running the lo side should go down to about 5 LP i think there is to much gas in it or is not pumping right, sorry i missed the second post jim
Freezer plate not freezing
is the compressor on? if not, start coil may be bad. if yes, check the airflow through the condenser (on the bottom). if it's clogged with dust, clean it out with a vacuum hose. if the fan isn't running, it may need replacing. the condenser needs air flow to cool down. if all is running and the condenser is not warm or the compressor is not hot, you have a regfrigeration leak. if the compressor is very hot, it may be seized up. if nothing is on, there is a board problem
Jan 03, 2014 | GE Monogram ZDI15C Automatic Icemaker
My GE GSL 25JFPABS Refrigerator failed yesterday. No Comressor no evap or condensor fan
Fan motor starts with the compressor. Sounds like you need a main board and condenser fan motor. Call GE. It might be covered under warranty. A known issue with certain models. You will also need serial # if you call.
Mar 23, 2017 | GE Refrigerators
Fan runs then compressor kicks in. instant 66 amp draw,clunks and shuts down ??
Sounds like the compressor is seized up or starting to. You could try a hard start kit to give it an extra boost and maybe it will snap out of it.
Jul 15, 2010 | Dometic Rooftop RV Air Conditioner
I have amana bottem freezer,1 month ago i
Hello, Unfortunately the compressor likely is seized now. There are a couple of reasons that the original start device failed, 1) faulty connection. 2) poor quality part. 3) compressor was running non-stop due to other deficiencies in the unit or 4) the compressor was failing to begin with. The compressor may indeed check out ok as far as electrically ( windings ) but the mechanical component ( rotor ) has locked/seized up. You can determine whether it is the windings by checking the ohm value between common to start, common to run and run to start ( c-s, c-r, r-s ) and look for values similar to 6ohms, 3ohms, & 9ohms. Then check the start and run & common windings against the compressor casing to see if windings are shorted. In order to double check the mechanical component you'd need another hard start, ( or a test cord direct to 120vac, but that should only be done by an experienced tech ). nothing else will start it at this point obviously or you wouldn't be using a hard start already. The other unfortunate issue is this, many of these compressor's have a 10yr. parts only warranty but that was voided as soon as the 3in1 hard start was installed. In the end I'm likely not telling you anything you didn't already suspect or know in fact, but it is likely the compressor. I sympathsize, seized compressors **** ! Hope this answers your question and moves you forward. good luck macmarkus :)
May 08, 2010 | Amana ABB1927DE Bottom Freezer...
Compressor shut down very quick then it turn on again after 3-5 sec it's off.., what is the solution?
MY HAVE A LOOSE SPADE CONNECTION AT MAIN THERMOSTAT RELAY. MOST OF THESE UNITS DONT HAVE HIGH OR LOW FREON PRESURE SWITCHES BUT YOU NEVER KNOW ON NEW UNITS CARRIER MAY HAVE THEM WHICH MY MEAN LOW FREON OR CLOGGED CONDENSER COIL  THE OUTSIDE COIL LAYERS IN DIRT,BUT THATS NOT A QUICK ON OFF .BURNT WIRES ON COMPRESSOR OR BLOWN RUN CAPACAROR CAN CAUSE QUICK ON OFF. WE HAVE INSTALLED A START CAPACATOR WHEN COMPRESSOR DOES NOT START AT ALL. CHECK FOR LOOSE WIRES ON TERMINALS THEY MUST BE PULLED TO CHECK THEM,THEY CAN SEEM CONNECTED BUT THEY ARE LOOSE. OTHER CAUSES MAY BE THE PROBE IN FRONT OF EVAP COIL WHICH IS TSTAT BULB. STICK IT IN HOT WATER AND IT SHOULD KEEP STAT CALLING FOR COOL.
Apr 20, 2010 | Samsung AW1203B Air Conditioner
GE Monogram side by side compressor runs loud - sounds like rapid knocking. what can i do?
check if it is the fan make that noise and not the compressor but if it is the compressor then you might need a new starter unit to the compressor
Jan 01, 2010 | GE Monogram Side by Side Refrigerator
GE GSH25JSTASS doesn't freeze or cool
Ok, first off, replace all thermistors, freezer (2) & refrig (2). Then check that evap fan is working properly. This is a DC volt fan, not ac volt. There have been some issues with these, I would replace if problem continues.
How this box works, main control board monitors everything from how many times doors are open, how long they are open, how and when I/M drops ice, etc.... Every so many hours, depending on how many times the doors are open, you got ice thru the door, etc... it will shut down and go into defrost mode. When it is time for defrost mode it will run refrig into a "sub zero" state, shut down evap fan, run deeper into sub zero effect, shut down compressor when the thermistors say it's cold enough, turn on defrost heater that melts any frost in evap, then turn compressor back on for a few minutes, then turn evap fan back on. Most techs think that the mother board is defective when in fact the thermistors are not measuring temps correctly within the whole unit. If the thermistor say, hey mother board I'm only 60 degrees in the freezer, then it will keep running the compressor trying to get to zero or -1 or till the darn thing freezes up and stops moving air.
Find another tech to work on your unit, one that has some electronics background and/or computer knowledge. It takes a electronics & computer degree to work on these units and understand how they function.
Doors, some of the new frigs have magnetic door gaskets, if it is not staying shut, replace door gaskets. If door stay open or is leaking air (especially around ice shoot) it can cause some really weird stuff to occur, like thermistors saying I'm cold at the inlet to evap but not at the top of evap and mother board will try to correct it's self by running longer. One other thing about door gaskets, if the drain plug in the evap area is frozen or plugged up, doors won't shut properly and stay shut.
For one thousand dollars, I'll come to Florida and fix for you, 200 to fix refrig and the rest for a good time at Disney World (LOL). Good luck. Contact GE for repair on this unit if you can't get good results from your repairman. Their people, like me, go thru extensive training on these boxes. You can thank our goverment for the energy codes that have gone into effect over the years requiring mfgs to have to keep the cost of running these refrigs down as low as possible, the only way to do this was to computerize these boxes. Good luck
Sep 30, 2009 | GE Monogram ZISS420NRSS 42" Built-In...
System not cooling space it cooled once before?
Hi, could be compressor loosing efficiency, i think suction pressure is to high at 85, also it could be moisture in your system, did mechanic replaces filter drier on high side of system , when he replaces evap. install filter drier on liquid line, if there isn't one, also check compressor valve, you can do that by cutting or desoldering the high side from compressor, connect charging port to compressor, conect your gauge charging port, start compressor, pump up to between 150- 200 psi shut off gauge, and leave for about 1 hr. then check pressure, if pressure decreases, then your compressor valve are leaking, if it maintain same pressure, then compressor valve is o/k. you can do same on suction side, this time in vacuum, if it holds vacuum pressure, then valve is o. k, RLA(LRA) lock rotor amps, is amount of amps compressor used to start, but will drop once compressor is running, 11.6 when operating is o/k, does your evap. compatible with condensing unit?, is it right size. check also that you're using right type of freon, check condensing unit & evap labels for right type of freon, make sure they can handle same type of freon. but check compressor valve carefully, i think your comperssor could be loosing it efficiency, compressor could be your problem. good luck.good luck
Aug 07, 2009 | Goodman CLQ36AR49 Air Conditioner
Ge Monogram ZISS420DMAS compressor and fan not running
ICE CREAM WON'T FREEZE
The ice cream does not freeze, it stays soft. I have a GE Monogram 42" Built-in-Side-by-Side Refrigerator.
Nov 28, 2008 | GE Monogram ZISS420NRSS 42" Built-In...
GE Monogram ZISS420NRSS 42" Built-In Side-By-Side Refrigerator (ZIS-S420NRSS, ZIS S420NRSS) Logo
227 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
