I have just bought a Hitachi HDB 70-S Freeview box and after sorting all the settings I´m getting the following message: "Interactive services cannot be sed while subtitles are on. Would you like to turn subtitles off now?" Yes no The remote does not work and it is not possible to choose any option or change channel. The batteries have just been replaced. Any suggestions on how to resolve this matter? Kind regards Alicia
    Top Expert:
  • Televison & ... Master
  • 77,169 Answers
You need to replace the remote.
Posted on Jun 24, 2017
SOURCE: TV not working with remote from Cox cable/Scientific Atlanta
Try the code 052.
Posted on May 18, 2007
sumthin
  • 71 Answers
SOURCE: error message: battery cover open
Hi X,
There's a little piece of plastic on the battery cover, that presses a switch when you slide the cover closed. Check that manually with a tooth pick and the the battery in place. Don't smash it. I have a Olympus FE -280 and it only happens when I put the cheap Chinese battery in.
If you are in the least uncertain, call Customer Service.
Best regards, Paul
Posted on Jun 13, 2008
SOURCE: I can't get comcast remote to work with tv
Try insignia's website (http://www.insignia-products.com/universalcontrolcodes.aspx). They have codes for all of their equipment.
t.
Posted on Oct 19, 2008
crayzeetrayn
  • 837 Answers
SOURCE: Unable to access subtitles whilst watching digital channels
Contact your TV service supplier to be sure that subtitles are available in HD ...
Posted on Jan 07, 2009
SOURCE: Freeview channels (DTV) on a Sharp Aquos TV
I have a Sharp Aquos 26-D44E. The factory preset PIN on this one is 1234.
Posted on Feb 10, 2009
I want an instruction manual for an Hitachi HDR505 set top box
My Hitachi freeview + recorder hdr505 keeps freezing when i go to tv guild to set to record programs
Mar 31, 2012 | Televison & Video
I cant make the freeview box work without the operating instructions
OK - please follow these instructions carefully to setup the Freeview box. If you get stuck at any point in the instructions - or anything I've said doesn't make sense or match what you can see - just post another message here and I'll deal with each problem as it arises.
1. Switch the TV and Freeview box to STANDBY. There should be a red light on the Freeview box;
2. Connect the aerial cable to the freeview box. Make sure you are connecting this to the correct socket. This should be labelled "RF IN", "IN" or "Aerial/Antenna". If you have connected to a socket marked "RF/TV OUT" or "TO TV" or something similar, it wont work;
3. Connect the SCART cable to Freeview box and the back of the TV;
4. Switch the TV on;
5. Switch the Freeview box on - you should get a green light on the front of the box;
Most TVs will automatically switch to the external input when a SCART device is switched on while the TV is already on. This is why you should switch the TV on first.
At this point you should be able to see the installation / setup screen for the Freeview box displayed on your TV. If you cannot see this:
A. Press the INPUT button once on your SAMSUNG remote control once. This is the button in the top-right corner of your remote control.
B. If you still cannot see the installation / setup screen, press the MENU or SETUP button on the remote control supplied with the Freeview box.
The instructions from this point forward will be different if you had to press the MENU / SETUP button on the Freeview remote before anything appeared on the TV screen. If this Freeview box has been used before the installation screen will not appear, but you will get at on-screen menu after pressing the MENU / SETUP button. If this happens, please let me know and I will provide alternative instructions for setup.
Assuming you have been able to access the installation screen, it should be easy enough to follow the instructions on screen from this point. Use the UP / DOWN / LEFT / RIGHT arrow keys on the Freeview remote to highlight the relevant options and then press OK / SELECT to choose that option.
I don't want to make this too complicated by providing alternative instructions for every possible scenario. Please run through the instructions above and make sure you are getting an installation screen or "menu/list" displayed on the TV. If you need further instructions from there, I will provide them in another message.
Good luck - I'll await your reply.
Regards,
BElectric
Feb 09, 2011 | Televison & Video
Cannot retune freeview on flat screen samsung
Hello Terri
Let's see if we can get you sorted out.
Make sure that you first of all have an aerial cable plugged into the TV.
Secondly make sure that you have it on a DTV (freeview channel) once you are at this stage press the MENU button on the remote. then go down to CHANNEL then across to Auto store and then follow the on screen messages.
That should be you all sorted out. If not then you may not be getting a strong enough signal from you aerial.
Hope all goes well. Please leave a thumbs up
Cheers
Little Dish Fitter.
Oct 07, 2009 | Samsung LE32R41BD 32 in. HD-Ready LCD...
No user manual for CE28DN9-B. Bought TVonics
HELLO
Follow these instructions:
Select a spare channel on your TV say 6 on your remote.
Press MENU.
Scroll down and select PRESET.
Using RIGHT button of F/OK/ENTER press it and this will go to TUNING.
Press RIGHT button again which will let you go to SEMI or AUTO tuning (for your purpose select "SEMI").
Scroll DOWN to highlight the actual UHF channel number or CH:C21 as it may appear on the screen.
Press the RIGHT button again yourself manually and you will see the channel number change anywhere from 21 to 69 until you come to your freeview box's RF channel output.
When you have done that scroll down to Memory and you'll see a box beside it. Press the RIGHT button and a tick will appear in the box.
You have stored your Freeview box RF channel on your TV.
Press MENU button THREE time to come out of the MENU setting.
Use this procedure again if you wish to change the RF channel on your TVONICS box.
GOOD LUCK (:-)
Oct 03, 2009 | Televison & Video
I have a Panasonic Quintrix which only seems to store some channels when you retune for new channels, eg BBC 1 has gone and been replaced with 4tv interactive. Any ideas how to get it back?
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
http://www.freeview.co.uk/_retuneinfo/
If the above process does not work then check the link above for additional information and also visit the accompanying site links below to find more information for your model of TV / FREEVIEW box.
For troubleshooting the retune procedure visit http://tvretune.co.uk/troubleshooting/
For specific model information visit http://tvretune.co.uk/productmanuals/
Oct 02, 2009 | Panasonic TX-32PL10 32" TV
Built in freeview doesn't work but digibox does
Have you done a channel search on both tv sources(atv and dtv). most new tv's will automatically start will "New Install". If you havent had a digital installed recently then this could the problem. set top boxes and TV's will pick up the signal ok but others wont.
Sep 16, 2009 | Hitachi Televison & Video
Televison & Video Logo
51 people viewed this question
Top Televison & Video Experts
Electro Med Services...
