Question about Car Audio & Video
Hi! in my marques 1995, anntena is disconnected in the trank, how to put it back and where?
  • 959 Answers
Remove the inner trunk liner on the side of the trunk the ant. is...
You will beable to see all there is to see with the linner off.
Reconnect ant. cable.
If there is further assistance required... please check back with an update !
Thanks!
Posted on Oct 06, 2010
Trank door can't open with kyeeless enyry remote
If you can open the trunk with a key or by the switch on the driver side then look in the trunk for a switch that disables the remote key entry.
Mar 10, 2013 | Cars & Trucks
Cobra XL 29 Anntena Warning Light
If you have a SWR meter.put meter in line with coax. Dubble check coax and make sure its not pinched,cut. Antenna mount is tight and clean. No electrolysis build up At connection. Warning light is coming on for a reason. something is wrong in between radio and connection at the antenna.
Nov 23, 2012 | Cobra Radio Communications
My husbend can,t open trank.The battery dead and no key for the trank.How he can open trank and get battery charge?
USE PORTABLE BATTERY JUMPER.PLUG IT IN THE CIGARETTE LIGHTER.IT WILL BOOST UP BATTERY POWER THROUGH ELECTRICAL SYSTEM TO OPEN TRUNK.
Jan 15, 2011 | 2000 Mercedes-Benz S-Class
Hi -\r\n2007 Grand Marque Auto trans stuck in Park. Wont move to gear. Case study: Just have remoate start put in, Steering wheel is easy to turn, car starts, Back lights operate (Except 1 bulb in third...
Check brake light switch behind brake pedal remote start has to be wired into switch so vehicle will shut down when brake is depressed when put into gear without ignition switch turned on. possible bad connection on switch or wires are not attached.
Nov 27, 2010 | 2007 Mercury Grand Marquis GS Sedan
95 mercury grand marque window stuck in down position
i had the same problem on another ford product, i had to replace window motor again, that time i lubricated the tracks and all of the parts that move when window raises, have had no problems since
Sep 16, 2009 | 1995 Mercury Grand Marquis
The front drivers door window has fallen off its track and fallen inside the door panel. My car is a 1995 mercury marque. I'm trying to take off the door panel. PS I'm a female so this is new for me . It's...
You'll need to remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. If needed, you can pull back the weather seal (can't reuse it, but it's not that important) and you will be able to access everything inside the door
Dec 12, 2008 | 1995 Mercury Grand Marquis
Need help with digital converter box hookup
I located my owners manual and was able to resolve the issue
May 23, 2008 | Televison & Video
Trying to hook up dvd player with sanyo tv. Also hook this up to satellite and surround sound. No picture, just audio.
Well are you ready for this I hope you can under stand if not maybe I can draw a diagram. Starting with your stereo take the component video out and goto component on the back of your tv to component in then the stereo coaxial in to the digatl audio out on the DVD player then DVD player anntena out to TV anntena in then DVD anntena in to reciever anntena out and Sat cable to reciever. also s-video on Dvd componet to s-video on TV DVD player Audio out to Audio in on TV. Set Stereo to TV and DVD player to channal 3 or do auto scan and TV will work on 3 with the reciever and also TV works with Video 2 I hope this works for you good luck
Jan 03, 2008 | Sanyo DS31590 31" TV
Car Audio & Video Logo
12 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
