The screen reads "Transfer Belt Error" - Office Equipment & Supplies
Remove transfer belt from printer. Remove the tow screws and open the black shiney plastic plate on the side with the BLUE POST STICKING OUT. Remove the Two screws and the black shiney plate from the side with the GREEN post. On the green side there is a chrome silver metal strip overhanging the cover bar. remove it by lifting it in a sliding manner toward the crossbar that straddles the belt across the bottom of the transfer assembly. Remove the four screws and remove the crossbar. Spin the belt forward or backward untill you see a tiny window inside the edge of the tranfer belt itself Clean both sides of the window with a q-tip with a light alcohol. also, there is an optical gap device on the bottom of the blue side. one screw will remove the entire assembly. there is powdered toner stuck in the optical gap on the receiver side. Blow it out anyway you can. high pressure works good. Dont use heat at all or the powder will magically turn into hard plastic and you will never be able to remove it. then re assemble the unit and make sure the little window aligns with the optical gap assembly that is hiding under the crossbar. Problem solved.
Posted on Oct 30, 2010
How can I resolve error code C-2451
Release new transfer belt unit
• A new installation is not detected when a new transfer cleaner unit (image transfer belt unit) is installed. Remedy 1 Reinstall unit. 2 Check there is a short circuit in the fuse of the transfer belt unit. 3 Check the PRCB connector for proper connection and correct as necessary. 4 Change PRCB
Feb 02, 2015 | Konica Minolta Bizhub C550
Minolta ep 1030 error e1
Imaging unit toner detection failure - during concentration read operation (F8), the result is less than 1v. Replace the developer and retry the F8 procedure.
Konica Minolta Error Codes & Solutions - http://www.kmcodes.com
Drum, Transfer Belt and Fusing Unit Firmware Reset - http://www.bizhubreset.com
Drum and Toner Chip Reset - http://www.chipreset.eu
Transfer Belt and Fusing Unit Reset Kit - http://www.resetkit.eu
Aug 18, 2014 | Konica Minolta Office Equipment & Supplies
E000070-0002
this error is for ITB belt( transfer belt ). Probably because it needs to be changed along with the ITB cleaning blade.
In error, the 0002 means that second sensor cant read the Itb belt.
As first aid, you can clean the back of the Itb belt and the driving roller.
Hope that helps!
May 01, 2011 | Canon imageRunner C3100N Copier
I receive the following error message, when I power on my Copystar CS 300ci: Machine Failure C1950 Any suggestions
Transfer belt unit EEPROM error No response is issued from the device in reading/writing for 5 ms or more and this problem is repeated five times successively. Mismatch of reading data from two locations occurs eight times successively.
Mismatch between writing data and reading data occurs eight times successively
1. Poor contact in the connector terminals.
- Check the connection of connector YC28 on the engine PWB and the connector of the transfer belt unit, and the continuity across the connector terminals. Repair or replace if necessary.
2. Defective transfer belt speed PWB (inner transfer belt unit).
- Replace the transfer belt unit.
I hope this is helpful,
Shawn
Mar 14, 2011 | Kyocera Copystar CS2540 Copier
Describe your GESTETNER DSC232 ERROR SC481 Problem
sc481 is an error relating to how the transfer belt moves. The first thing to check is to make sure the transfer belt is not out of position -- it should be riding flat on its rollers, with no wrinkling or shifting. If the belt looks fine, you may need to replace either the belt (there is a detection mark on it that needs to be read by a sensor) or the main motor. Since this is such an old copier, it may be hard to find replacement parts for it, however.
Hope that helps!
Apr 19, 2010 | Gestetner DSc232 Copier
I have some ricoh aficio 1224c with errors c481
SC481
Transfer belt mark detection error
• The main motor is operating; and
the lock signal is detected. → The
belt mark sensor signal does not
change for 120 milliseconds.
• Defective main motor
• Image transfer belt out of position
• Belt mark blurred or absent
I would remove the pcu unit (3 screws)and check the transfer assy belt mark and clean the sensor that reads the belt mark. Worst case senerio is replaceing the entire pcu unit.
Mar 07, 2010 | Ricoh Aficio 450 Copier
Re Samsung CLX-3160FN & Transfer Belt Error
Take out the Imaging unit ,transfer belt and fix it properly.
Also take care that you will keep the printer on even surface.
IF nothing is solving the problem then you need to replace the transfer belt as a final solution.
Jun 18, 2009 | Samsung CLX 3160fn All-In-One Printer
Transfer roller
Use the keys on the control panel to select the following menus: setup|maintenance|check others|transfer belt|reset then press [enter]. The LCD should read "reset now" and the printer will return to the ready prompt.
This assumes the error message you have is for the transfer belt near end and not the transfer roller itself (which is NOT part of the transfer belt, it's actually attached to the RH door as you look at the control panel).
Oct 16, 2008 | Samsung CLP-500 Laser Printer
Power Off/On Fatal Error : 917
The 917 fatal error is a belt **** se sensor error. This could be caused by the belt not installed correctly or the belt at the end of its life, or the belt being torn. Please power the printer off and then reseat the transfer belt and then power the printer back on. If the error remains then I will need you to check the life remaining on the transfer belt. Also make sure the transfer belt is not torn.
Aug 08, 2008 | Xante Ilumina Digital Color Press Printer
Samsung printer, transfer belt error message
Check on you drim uint the gears damaged.
Aug 06, 2008 | Samsung CLP-500 Laser Printer
331 people viewed this question
k24674
