Question about Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum
Hoover deep cleaner brush won't work - Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum
    Sergeant:
  • 198 Answers
If the vacuum cleaner comes on but the brush will not spin, try replacing the belt and clean each end of the brush from lint , string, carpet materials.
Posted on Oct 06, 2010
Where is the belt located on my hoover steam shampoer
There is probably not a belt. The brushes on the carpet cleaner head and attachments work from air and there is a roller bearing deep inside that will wear out and the brushes won't turn. I've found no way to fix this. I consider it a design defect.
Apr 20, 2011 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover carpet cleaner won't dispense solution or water. Everything else works.
1.Remove bottom tank and look for pinched hose. 2.Use small screwdriver or toothpick on small holes which disperse solution-remove rotating brush first. These were problems with my steamvac (f5861-900 model).
Mar 16, 2011 | Hoover SteamVac Carpet/Upholstery Deep...
My hoover carpet scrubber the brushes won
(1) Remove the brush block and assure the presence of the square drive pin on top of one brush. It should be about 1/4 inch square, two inches long to connect o the drive mechanism.
(2) Remove and clean the filter screen from the base, behind the brushes. Squeeze the two red tabs together, and pull down from the base. Clean the hiar/debris from the screen.
(3) Assure the Brush Speed knob on the hood is NOT set to the OFF position.
Aug 30, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
I have a hoover spinscrub carpet cleaner model F7221-900 I need to download a user manual for.But hoover website tells me they can,t find this model number. I have checked # several times and it is...
I just needed to clean the brushes I finally just found the clips on each side of the brush roller and pressed in towards center and was able to pull brushes out.
Mar 19, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover steam vac legacy
Hello tmc68cam. I will need the Mgfr., model & serial# to research for the part or parts you may need.
Oct 06, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
My steam vac won"t **** up the water
Check the hose and make sure it is clear of debre and there are no kinks in the hose.
Aug 28, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover terrain steam cleaner, brushes wont spin
The primary problem is that the turbine is seized. One way to verify this is to try to manually move the brushes by hand (with it off, unplugged). If not then your problem is with the turbine. This usually requires professional service. I would recommend to take it to a trusted vac shop which is familiar with these cleaners. or go to the hoover web site to locate a hoover dealer near you.
Jul 15, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Belt replacement Hoover carpet cleaner
Hoover steamvacs don't use belts. If the brushes are not turning, pull the brush block out, turn the machine on and see if the square hole where the brush block was, is turning. If not then the turbine is bad. Sometimes you can take the turbine apart and clean it out. most times I have found , replace it.
May 24, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover cleaner model f5865-900
There is no belt, either the turbine part #43191003, or the brush block, the shaft that goes up into the turbine broke off part #48437022. The turbine is what drives the brushes.
Feb 02, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum Logo
230 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
