Question about Magnum Fitness Treadmill w/ Contact Heart Rate-110V
Treadmill runs then stops suddenly/ shows ER3 BELT
Everytime I stand onto my treadmill, it works, and then all of a sudden stops and runs very slow. When there is weight on it, it doesn't work. When weight is off it, it works fine. Whats the problem?
Try to clean the dust inside the running belt and silicone them after.
Then try to increase the belt tension. all treadmills have these adjustment.
If it still slip, then problem with the motor.
Feb 10, 2016 | Nordic Track Exercise & Fitness
I am either walking or running already for a few minutes and the treadmill part of the treadmill just stops suddenly but computer part still shows all right info. My wife weighs 130lbs. and doesn't have...
If the machine is over 7 years old then you need to replace the walking belt. Most proform treadmills are not meant to be run on, especially by anyone over 220lbs. Forget what the manual says, they are a terrible company.
Sep 07, 2017 | Proform XP Weight Loss 620 Treadmill
When i get on the treadmill the belt stops all of a sudden
Try to tension the tredmill's belt. For that you need an allen wench. Watch the following video to adjust the running belt. All the treadmills uses the same way to adjust the belt.
Oct 10, 2011 | Reebok Vista Treadmill - RBTL13305
Proform 350s crosstrainer treadmill; surges 3 MPH to 4MPH
Walking Belt is Worn: The only certain way to test for a worn walking belt is to take a DC amp draw (if you have a DC treadmill) or an AC draw (for AC). Trying to look at the belt or a feel test is highly unreliable. Better tests, if you lack a DC ammeter (they are expensive for a good one), are a coast test or an incline test. The coast test is to get on the treadmill as the lowest incline setting and walk on the treadmill at 3 MPH. Pull the safety key and it should take you 2-3 full steps to stop (this is a general rule…some like a few Tunturi models stop on a dime even with a healthy belt but for most models, this tests works well upon). Fewer steps indicate high friction. The incline test is to put the treadmill at max incline and walk on it at 3 MPH. If the treadmill operates normally at max incline but bogs down at minimum incline, replace the walking belt. Gravity takes over for the drive system eliminating much of the friction problem. On some heavily worn walking belts, this test will not eliminate the problem. Go to your local hard ware store and purchase silicone spray. Apply Lubricant by lift one side of the running belt spray contents length wise starting at motor shroud to the back end repeat this process on the other side. If this unit bogs down again then you will have replace the running belt and possibly the deck
May 27, 2010 | Proform CrossTrainer Treadmill
I have a 6 year old Reebok RX5000. At speeds
They walkbelt is most likely worn out causing too much friction overheating the motor.
Jan 15, 2010 | Exercise & Fitness
The belt stopped suddenly and now won't work anymore
I would check your speed sensor. I've never seen one of these just stop suddenly. But running for a min or so is one of the signs a speed sensor gives you.( especially if the treadmill want speed up while it running) Check this out and if it"s not the problem get as much info as poss to help diag.
Nov 16, 2009 | NRS Golds Gym Preview 1000 Treadmill
My Proform 650v treadmill stop when running after couple of miles
Most likely a bad drive belt. Take the cover off the motor area. If you see black dust near the left side of the motor, replace the drive belt.
Oct 29, 2009 | Proform CrossTrainer Treadmill
The belt on my ProForm Crosstrainer treadmill stops while using i
Sometimes the tread needs to be lubricated. This was the case with ours. You can get a lubrication kit at ****'s Sporting Goods or other larger sport stores and it will instruct you on how to do it.
May 13, 2009 | Proform CrossTrainer Treadmill
Magnum Fitness  Treadmill w/ Contact Heart Rate-110V Logo
Top Magnum Fitness Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you a Magnum Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
