Question about ASUS P5B-VM DO Motherboard
Are there any known issues or problems with this motherboard (ASUS P5B-VM DO) and Windows 2003 std. server.
Raid 1
4gb of memory
Please update your BIOS if necessary to do some fixes, optimization, and even hardware or software support.
Posted on May 29, 2008
Audio driver for atx in xp
http://support.asus.com/Download.aspx?SLanguage=en&m=P5B-VM
Dec 22, 2012 | ASUS P5B-VM SE LGA775 Micro-ATX Intel...
Would an Extreme power plus 500W work on a asus p5b-vm main board^
Yes, the Coolermaster Extreme Power Plus 500w has the required connectors to work with the ASUS P5B-VM Motherboard.
Sep 12, 2011 | ASUS P5B-VM Motherboard
My asus p5B motherboard doesn't want to install audio drivers and networkdriver
check for the right driver which comes with your computer cpu.
Apr 01, 2010 | ASUS P5B-VM DO Motherboard
User guide for a p5b-vm many thanks rob selsig
heres a link to the support site http://support.asus.com/download/download.aspx?model=P5B-VM&SLanguage=en-us
You can then click on manuals and choose the manual in which ever language you require
heres a direct link to the English version of the user manual http://dlcdnet.asus.com/pub/ASUS/mb/socket775/P5B-VM/e2833_p5b-vm.pdf
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Mar 31, 2010 | ASUS P5B-VM Motherboard
I need to conekt my chassis cabels to a P5B-VM asus motherboard :/ cant fina anny manual to this
Diagram of Mother Board
Please see the above link. In the top right corner of the board you will see CHA_FAN. However you could also plug it into the PWR_FAN located more in the top left of the diagram.
Nov 10, 2009 | ASUS P5B-VM Motherboard
P5b-vm se asus driver
You can download the drivers for your motherboard from asus here:
http://support.asus.com/download/download.aspx?modelname=P5B-VM SE&SLanguage=en-us
just select your operating system
Mar 31, 2009 | ASUS P5B-VM SE SKT775 G965 MATX...
AHCI
choose RAID mode.. that should enable AHCI. (as per wikipedia) on your motherboard so that means.. that if you're installing the os on this hdd you may want to use the raid driver for it which is likely what's in the ASUS cd you got so your os get to use the hdd as it's meant to be used.
you may also want to make sure you're using the right sata connector on your motherboard: check page 33
http://dlcdnet.asus.com/pub/ASUS/mb/socket775/P5B-VM/e2642p5b-vm.pdf
http://support.asus.com/download/download.aspx?SLanguage=en-us&model=P5B-VM
the problem could laso lay in your cables.. it's know the average may be affected by faulty SATA cable or faulty SATA power cable (powersupply issue)
you may also want to run a backup of your data and then run a defrag and a checkdisk on the drive, and it's probably also worth it to rung Seatools (download from this page: http://www.seagate.com/www/en-us/support/downloads/ ) to check the health of your hd.
Also try to update the SATA controller drivers or the motherboard chipset
lastly, post the results of your tests here on fixya or better yet: in here: http://forums.seagate.com for further follow up.
try each recommendation one at a time and then test the speed of your hd to see if there's improvement.. make sure you back up before you do anything drastic.
good luck (it took me 2 hours to pos
Dec 14, 2008 | Computers & Internet
Asus p5b-vm se power problem
i had this problem before also...how old is your power supply?
Dec 08, 2008 | Computers & Internet
Is the ASUS P5B-TMX Motherboard PWM compliant?
Most fans of the same size run at the same speeds and will have a noise level about the same
If you can get a larger fan that runs at a slower speed and will fit this will be the best method
Nov 24, 2008 | ASUS P5S800-VM Motherboard
ASUS P5B-VM DO Motherboard Logo
337 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
