THE UNIT DOES NOT COOL - Heating & Cooling
    Master:
  • 473 Answers
Check Thermistor Sensor For fail reading ... unplug for 10 min... then plug-in power on check reading Temperature...Then set unit
Also If it Air Mobile Conditioners.. Check for Water Level if it full ...The Sensor inside the unit will keep the Compressor Off.. Due to Overflow..
Posted on Oct 06, 2010
WK[L] 3000 unit can not change the set temperature. It is stuck on 64 degrees. The unit continues to run and the temperature shows 55.
IVE SEN THIS ISSUE BEFORE
THE FACT THAT YOU CANT CHANGE THE SET COOL POINT ON THE UNIT BELOW 64 IS A SYMPTOM OF A DAMAGED CONTROL BOARD (SENTRY III), NOW THE UNIT CONTINUING TO COOL DOWN BELOW THE SET COOL POINT OF 64 AND GOING ALL THE WAY DOWN TO 55 IS MOST LIKELY THE RELAY.
I HAVE FIXED THIS EXACT SAME ISSUE BY REPLACING THE CONTROL BOARD AND RELAY ON THE UNIT.
Sep 23, 2014 | Breezaire WKL-3000 Wine Cellar Cooling...
I meant the AC does not cool
Make sure the mode is set to freeze and temperature is set to below the room temperature.
If it is a split system, check the outdoor unit whether it is running. If it is running, see if you can reach and feel the temperature of the pipes connecting between the indoor and the outdoor unit. It should be cool.
If it is not cool, you may need to get somebody to check the refrigerant.
May 22, 2014 | Dometic 57915531 Air Conditioner
My Hitachi indoor unit model RAS-26CHA1 is not giving out any cool air. The fan is working and have checked via manual. But manual does not have a trouble shooting section. Can you please assist me in...
To get cool keep temp setting 23 degree and mode in "cool" position. After compressor start, keep your hand on discharge pipe line (Smaller pipe), if it's warm your unit is starting cool. And also check with Amps meter for reading as per in name plate with the unit. If amps very less than specified, it's under gas leak.You have find out leak and arrest. Then charge gas.
Dec 28, 2010 | Hitachi Heating & Cooling
True GDM-12 - Unit runs, but won't cool below 60 degrees,
Is it very hot out side the unit.recharging may not hurt is it cleaned the lint could be trapping the radiator were the coolan goes through to cool down try cleanning underneath before recharging
Jul 26, 2010 | True GDM-12 Refrigerator Commercial
Ac unit will not cool.
Yes, that is normal operation if you have the fan setting to "on"
heatman101
Jul 09, 2010 | Heating & Cooling
My Sanyo KS1211W split air conditioning unit does not cool
u r compressor is not functioning,sure u need the service technician
May 17, 2009 | Heating & Cooling
No cooling after power out, indicator lights pattern not in manual
The Mitsubishi units have to be reset by turning off the indoor units by switching the remote or thermostat to off. Then turn off the breaker to the outside unit(s). After 30 seconds,turn on the breaker and then you can turn on the remote for cool. If no lights come on on the inside units, most likely you have blown a fuse soldered on the main PC board. At this point, call your technician. A goos tech will be able to wire in an in-line fuse holder so if it should happen again, you can easily replace the fuse. If you do see a light or two come on at the indoor unit but the outdoor unit does not start after 3 or 4 minutes, sounds like you will need to call a technician. Most likely you have a blown fuse on the main PC board of the outside unit. It is not an easy one to replace. Good Luck!
Aug 31, 2007 | Mitsubishi MSH09TW Air Conditioner
Heating & Cooling Logo
27 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
