Question about Sanyo DS25390 TV
Have the horizontal line but by tapping ( lately smacking) top or side of set,picture will resume. Been getting steadily worse.
    Master:
  • 473 Answers
Issue ...with Connection.. Check IC Logic Regulator..Possibility Over Heat ..Also check Capacitor for leakage Check Horizontal Holder for bad Resistance signal..
Posted on Oct 06, 2010
JVC AV-27730: horizontal bright line across screen in the
it could be an electrolytic capacitor or the vertical output I.C. in the vertical circuitry,if you remove the rear cover tap on the board in different places and see if the picture fills out or atleast jitters like it might fill out,then it could be just a cold solder joint,then remove the main board and resolder all joints and this should repair the condition you have
Nov 18, 2009 | JVC AV-27730 27" TV
I have a Sanyo and it has a horizontal line in the middle with no picture, but with sound. what could be the problem? I have noticed that if we tap the side or top of the TV, the picture resumes;; but now...
You have a frame collapse, if you had previously been tapping it to come on then it sounds as if there is a dry solder connection most probably on the frame IC or surrounding component. If you are competent with the use of a soldering iron, then remove the back & gain access to the underside (circuit print board) of the TV. Look for an IC that is attached to a heat sink & carefully resolder the pin connections. Look closely at the surrounding solder connections & if any of them look dry then re-solder them also. Without knowing the model of your TV then I can't be more precise as to the specific component location. If you do not want to attempt this then a local repair shop should be able to easily fix it for you.
Jul 29, 2009 | Sanyo DS31520 31" TV
Toshiba 50A61 Horizontal Lines in picture
You have bad connections somewere need to look further for sure
Nov 08, 2008 | Toshiba 50A61 50" Rear Projection...
Sony KV-32S66 Picture Rolling Up/Black Horizontal Lines
the problem there is a loose connection on the board,you said that you smacked the right side of the tv and it goes normal.there are parts that should be resolder on the board in order to back into normal operation.
Oct 22, 2008 | Sony KV-32S66 32" TV
Panasonic CT-32G6E Intermittent single horizontal line
I would suggest to locate a part that looks like the one on this link and re solder all the pins, also check for any high power resistor nearby the IC295890 and put some fresh solder.
Let me know if you need further assistance.
Aug 07, 2008 | Panasonic CT-32G6 32" TV
Horizontal blue line
The intermittent horizontal line is cause by a loose solder connection in the vertical amplifier IC.
The IC is mounted on a heatsink nearby or around the flyback transformer.
The way to fix this failure is to add fresh solder where you see some brown spots on the circuitry that were cause by components getting hot.
Good Luck.
Jun 20, 2008 | Sharp 25R-S100 25" TV
GE 31
check electrolitc capacitors in horizontal circuit
May 09, 2008 | GE 31GT659 31" TV
Picture Jumps/flashes for first 5 minutes
There is a module called a hyper board that is vertically mounted near the jack panel. Inside the module are 10mf/25v capacitors they are grtting weak. The module is fully shielded and pluggs into a socket. the module has 4 tabs (2 on each end) that must be unsoldered before it can be unplugged. This repair should be done by a qualified technician. The caps are surface mounts and very small. Unless you have excellent soldering skills and a rock steady hand DO NOT ATTEMPT to repair this problem on your own.
Nov 16, 2007 | Toshiba 57H81 57" Rear Projection...
Lines in picture
I had this problem around the time my TV was 3 years old. I ended up having to get it repaired at a TV repair place, it cost me $375.
Sep 24, 2007 | Toshiba 57H83 57" Rear Projection HDTV
I had the same problem and followed the instructions from Jack and my 57h81 is bak up and running. Thanks Jack. RonD
Jul 02, 2007 | Toshiba 36HF72 36" TV
Televison & Video Logo
226 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
