Question about Toshiba Computers & Internet
My toshiba problem is cracked the lcd waaaaaaaaaaaaa!!!!!!!!!!!! model L30-10Y TOSHIBA SATTELIE.how much the lcd so i can fixed it? ty....
    Master:
  • 473 Answers
Laptops Are Cheap from these Day ...Just buy Another One ..
LCD Screen it Betwen $35 to $200 dollards
Posted on Oct 06, 2010
MY TOSHIBA LCD TV SCREEN IS CRACKED DOES IT HAVE A
Hi Erika,
If your LCD is cracked, you will need to unfortunately replace the entire LCD. Simply putting a screen protector (which is just a thin film) will not stop the crack from getting worse. There is unfortunately no magical way to fix your screen other than simply replacing the LCD panel itself, which is totally doable. Many electronics repair shops can fix your TV pretty easily. In some cases, you can even mail it into Toshiba.
Oct 03, 2013 | Toshiba 32AV502U 31.5 in. LCD HDTV
Toshiba AA67-00136B
It depends on the model---older rear projection sets maybe---newer LCD or Plasma---NO----cracked or damaged screen on those is the end as part costs are more than set was new.
Mar 21, 2012 | Toshiba Televison & Video
Help with LCD screen
Replace the LCD or the laptop. It is not repairable beyond doing those things.
Jan 07, 2012 | Toshiba Satellite 2400-S201 Notebook
I have a 52" Toshiba
in general cracked lcd panels cost more than the tv is worth.. depending on model panel replacment run 1500 to 2000.. and physical damage is not a warrenty item. do you have a toshiba or a rca the decription says you have rca r52wm24 which is not a lcd. that is a tube tv. and if it is cracked that definatly can be fix or replaced cost effective.
Oct 27, 2010 | RCA R52WM24 52" HDTV Projection Television
Where is the service center of toshiba regza t.v here in manila
regza 32pb1e tv looks like there's a crack in the lcd.how to repair this and how much?
Apr 07, 2010 | Toshiba REGZA 32XV515DG 32 in. LCD HDTV
Screen black & with no power
hi there,
you can follow this instruction and try to your laptop to resolved the problem.
A bad connection between DC-IN power jack on the system board and the system board is a very common problem with Toshiba Satellite M35X and Toshiba Satellite A70/A75 notebooks. If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN jack on the system board. If it’s still under warranty, it would be fixed at no charge to you.
Problem symptoms:
  1. Laptop randomly shuts down without any warning.
  2. Power LED and battery charge LED start flickering when you wiggle the power cord or the AC adapter tip on the back or your laptop.
  3. The battery will not get charged.
  4. When you plug AC adapter, the laptop appears to be dead and there is no LED activity at all (DC-IN jack on the system board is broken).
To fix the problem, you have to take your laptop apart, remove the system board to resoleder or replace the DC-IN jack. Toshiba Satellite M35X and Toshiba Satellite A70/A75 disassembly guides will help you to remove the system board. Take a closer look at the power jack on the system board with a magnifying glass. In most cases you get the power problem because of a bad connection between the DC jack and the system board, you’ll see a crack between the DC jack connector and the system board.
Here is an example of Toshiba Satellite M35X power jack. The crack occurs between the DC jack pin and the system board.
satellite-m35x-crack.jpg satellite-m35x-contact.jpg In some cases the connection is good, but the DC jack is bad itself. You can find a new DC jack for Toshiba Satellite M35X and Toshiba Satellite A70/A75 laptops here. Search for DC jack M35X or DC jack A75.
How to resolder laptop power jack yourself.
UPDATE:
Sometimes, after you replace the jack, you can see that the system board doesn’t get power at all. The battery will not charge and the power LED will not light when you plug in the AC adapter. So, here’s a possible explanation.
When a connection between the positive pin and the motherboard breaks (cracks), the power jack gets loose. You can feel it when you plug in the adapter plug. A loose power jack can damage the trace inside the hole in the system board. Take a look at the picture.
power-jack.gif As you see, the positive pin goes through the hole in the system board and you solder it on the top side. Right? What if the trace between the top side and the bottom side is broken somewhere inside the hole? I’ve seen it before a few times. In this case everything looks nice and clean on the top side. When you plug in the AC adapter, you get normal voltage readings between “+” and “-“ pins on the top side, but the power DOESN’T go to the motherboard at all, because there is no connection between the top and bottom sides. Test with a multimeter if there is a connection between the top and the bottom.
If the trace inside the hole is broken you still can fix it. You can run a wire to connect the top and the bottom sides. Be careful not to short something on the board.
Update:
Here’s another solution to fix the power jack problem, it shows how to relocate the power jack outside the laptop base. Check it out here: Toshiba Satellite A75 failed power jack workaround.
When you repair a loose power jack, it’s a good idea to check the jack on both sides of the motherboard. When you remove the top cover from a Toshiba Satellite A70/A75 laptop you can see only points where the jack is soldered to the motherboard as it shown on the second picture in this post, but you cannot see the jack itself as it shown on the first picture.
Removing the motherboard from Satellite A70/A75 laptop is a good idea because the jack itself might has a broken “+” pin, as it shown on the picture below. If the “+” broke off the base, you’ll have to replace the jack.
Feb 15, 2009 | Toshiba Satellite A75-S229 Notebook
Cracked screen
The LCD screen itself often cost more then the tv set itself. If you have accidental insurance you might see if they cover this, otherwise this will make a nice lava lamp like art display for a bedroom wall.......
Apr 22, 2008 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Johnnyhotrodcamaro@yahoo.com
Mit has screens that are second to none, if you can't find an official Tosh one. It might need to be cut to size, but no biggie -
Mr Bob
Jan 11, 2008 | Toshiba 55H70 55" Rear Projection...
Toshiba 32cf650
hi there, there maybe a arcking of high-voltage form the FBT. or an amplifier section problem, do some test and check-up. ty
Jan 10, 2008 | Toshiba CF32H50 TV
Computers & Internet Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
